juju
1
J’ai deux Shelly plug S sur mes panneaux solaires. Comment puis je les additionner pour avoir la valeur cumulée
Shelly plug s X2
Nom du capteur:
Sensor.panneaux_solaire_energy
sensor.panneau_solaire_1_energy
version |
core-2023.5.4 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.11 |
os_name |
Linux |
os_version |
6.1.21-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4922 |
Installed Version |
1.32.1 |
Stage |
running |
Available Repositories |
1283 |
Downloaded Repositories |
12 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 10.1 |
update_channel |
stable |
supervisor_version |
supervisor-2023.04.1 |
agent_version |
1.5.1 |
docker_version |
23.0.3 |
disk_total |
28.5 GB |
disk_used |
5.8 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Terminal & SSH (9.7.0), File editor (5.6.0), Duck DNS (1.15.0), Mosquitto broker (6.2.1), Studio Code Server (5.6.0) |
dashboards |
1 |
resources |
9 |
views |
6 |
mode |
storage |
oldest_recorder_run |
15 mai 2023 à 07:34 |
current_recorder_run |
25 mai 2023 à 17:51 |
estimated_db_size |
266.34 MiB |
database_engine |
sqlite |
database_version |
3.40.1 |
Merci à vous
Sujet qui a été souvent abordé… mais essaie un sensor:
avec qq chose du genre :
sensors:
sejour_cumul:
friendly_name: "Séjour Cumul"
unit_of_measurement: 'kWh'
value_template: '{{
states("sensor.shelly_shsw_pm_afaf361_total_consumption") | float(0) +
states("sensor.shelly_shsw_pm_afaf543_total_consumption") | float(0) +
states("sensor.convecteur_cuisine_energy") | float(0) | round(0) }}'
sensors:
sejour_puissance:
friendly_name: "Séjour Puissance"
unit_of_measurement: 'W'
value_template: '{{ (
states("sensor.shelly_shsw_pm_afaf361_current_consumption") | float(0) +
states("sensor.shelly_shsw_pm_afaf543_current_consumption") | float(0) +
states("sensor.convecteur_cuisine_power") | float(0) ) | round(0) }}'
juju
4
J’essaie avec ton code en modifiants les paramètres avec mes sensors
Mais je pense que c’est le “template” qui me bloque.
Je copie ton Conde dans ma configuration mais ca veux pas.
Je suis un peu perdu
Il suffit que tu mettes tes sensor… et que tu le colle au bon endroit…
sensors:
sejour_cumul:
friendly_name: "Cumul Solaire"
value_template: '{{
states("sensor.panneaux_solaire_energy") | float(0) +
states("Sensor.panneaux_solaire_1_energy") | float(0) + | round(0) }}'
Tu doit aussi pouvoir utiliser Welcome to Powercalc documentation! — Powercalc documentation
