Pour ceux qui souhaiteraient passer par un template plus générique (sans nommer chaque batterie à surveiller)
ce qui donne pour moi
automation:
# # https://community.home-assistant.io/t/battery-alert-automation-stuck-with-syntax/141216
- alias: 'Battery alert'
- platform: time
at: '07:03:00'
condition:
- condition: template
value_template: >-
{%- set threshold = 40 -%}
{%- for item in states
if (item.attributes.battery_level is defined and
item.attributes.battery_level | int < threshold) or
("battery" in item.name | lower and
((item.state | int < threshold and item.state|int != 0) or
item.state | lower == "low" or
item.state | lower == "unknown"))-%}
{%- if loop.first -%} {{ true }} {%- endif -%}
{%- endfor -%}
- service: notify.HA
data_template:
title: '{{ as_timestamp(now()) | timestamp_custom("%d-%m-%Y, %H:%M:%S",True) }}'
message: >-
Les appareils suivants ont un niveau de batterie faible :
{%- for item in states -%}
{% if item.attributes.battery_level is defined and
item.attributes.battery_level | int < threshold %}
{{ item.name }} ({{ item.attributes.battery_level }}),
{% elif "battery" in item.name | lower and
item.state | lower == "unknown") %}
{{ item.name }} ({{ item.state }}),
{%- endif -%}
{%- endfor -%}
