### What happened?
After upgrading firmware version from 1.0.24 (20200708) stoc…k firmware at device delivery to newest firmware 2.5.4 (20221028), Styrbar remote does not work anymore. Pairing is working but after that no message are received and power status is reported as 255 instead of 0-100.
Update done using IKEA hub (zigbee2mqtt did not want to update saying 1.0.24 is newer that online version). Remote is working fine when paired with IKEA hub. Version 1.0.24 was working correctly throught zigbee2mqtt (and other ones not yet upgraded still works).
Log below show pairing and configuration, then a few OTA request from the device then nothing else happens even when pressing buttons.
### What did you expect to happen?
Remote with latest firmware working
### How to reproduce it (minimal and precise)
upgrade a remote to latest firmware from IKEA (2.5.4)
### Zigbee2MQTT version
1.28.4
### Adapter firmware version
20210708
### Adapter
Sonoff Zigbee 3 USB
### Debug log
debug 2022-12-23 23:04:29: Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"ercpe-2","value":true}'
info 2022-12-23 23:04:29: Zigbee: allowing new devices to join.
info 2022-12-23 23:04:29: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"ercpe-2"}'
info 2022-12-23 23:04:33: Device '0x385b44fffe38ba50' joined
info 2022-12-23 23:04:33: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x385b44fffe38ba50","ieee_address":"0x385b44fffe38ba50"},"type":"device_joined"}'
info 2022-12-23 23:04:33: MQTT publish: topic 'homeassistant/sensor/0x385b44fffe38ba50/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","name":"0x385b44fffe38ba50 battery","state_class":"measurement","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
info 2022-12-23 23:04:33: MQTT publish: topic 'homeassistant/sensor/0x385b44fffe38ba50/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","name":"0x385b44fffe38ba50 action","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
info 2022-12-23 23:04:33: MQTT publish: topic 'homeassistant/sensor/0x385b44fffe38ba50/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"0x385b44fffe38ba50 linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
info 2022-12-23 23:04:33: MQTT publish: topic 'homeassistant/sensor/0x385b44fffe38ba50/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"0x385b44fffe38ba50 update state","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
info 2022-12-23 23:04:33: MQTT publish: topic 'homeassistant/binary_sensor/0x385b44fffe38ba50/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":"0x385b44fffe38ba50 update available","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
info 2022-12-23 23:04:33: MQTT publish: topic 'homeassistant/update/0x385b44fffe38ba50/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","latest_version_template":"{% if value_json['update']['state'] == \"available\" %}{{ 'newer' }}{% else %}{{ value_json['update']['installed_version'] }}{% endif %}","latest_version_topic":"zigbee2mqtt/0x385b44fffe38ba50","name":"0x385b44fffe38ba50","payload_install":"{\"id\": \"0x385b44fffe38ba50\"}","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
info 2022-12-23 23:04:33: Starting interview of '0x385b44fffe38ba50'
info 2022-12-23 23:04:33: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x385b44fffe38ba50","ieee_address":"0x385b44fffe38ba50","status":"started"},"type":"device_interview"}'
debug 2022-12-23 23:04:34: Device '0x385b44fffe38ba50' announced itself
info 2022-12-23 23:04:34: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x385b44fffe38ba50","ieee_address":"0x385b44fffe38ba50"},"type":"device_announce"}'
debug 2022-12-23 23:04:34: Received MQTT message on 'homeassistant/sensor/0x385b44fffe38ba50/battery/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","name":"0x385b44fffe38ba50 battery","state_class":"measurement","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
debug 2022-12-23 23:04:34: Received MQTT message on 'homeassistant/sensor/0x385b44fffe38ba50/action/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","name":"0x385b44fffe38ba50 action","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
debug 2022-12-23 23:04:34: Received MQTT message on 'homeassistant/sensor/0x385b44fffe38ba50/linkquality/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"0x385b44fffe38ba50 linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
debug 2022-12-23 23:04:34: Received MQTT message on 'homeassistant/sensor/0x385b44fffe38ba50/update_state/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"0x385b44fffe38ba50 update state","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
debug 2022-12-23 23:04:34: Received MQTT message on 'homeassistant/binary_sensor/0x385b44fffe38ba50/update_available/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":"0x385b44fffe38ba50 update available","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
debug 2022-12-23 23:04:34: Received MQTT message on 'homeassistant/update/0x385b44fffe38ba50/update/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x385b44fffe38ba50"],"manufacturer":"IKEA","model":"STYRBAR remote control (E2001/E2002)","name":"0x385b44fffe38ba50","sw_version":"2.4.5"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","latest_version_template":"{% if value_json['update']['state'] == \"available\" %}{{ 'newer' }}{% else %}{{ value_json['update']['installed_version'] }}{% endif %}","latest_version_topic":"zigbee2mqtt/0x385b44fffe38ba50","name":"0x385b44fffe38ba50","payload_install":"{\"id\": \"0x385b44fffe38ba50\"}","state_topic":"zigbee2mqtt/0x385b44fffe38ba50","unique_id":"0x385b44fffe38ba50_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
debug 2022-12-23 23:04:36: Retrieving state of '0x385b44fffe38ba50' after reconnect
debug 2022-12-23 23:04:38: Device '0x385b44fffe38ba50' announced itself
info 2022-12-23 23:04:38: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x385b44fffe38ba50","ieee_address":"0x385b44fffe38ba50"},"type":"device_announce"}'
debug 2022-12-23 23:04:40: Retrieving state of '0x385b44fffe38ba50' after reconnect
debug 2022-12-23 23:04:48: Received Zigbee message from '0x385b44fffe38ba50', type 'readResponse', cluster 'genPollCtrl', data '{"checkinInterval":172800}' from endpoint 1 with groupID 0
info 2022-12-23 23:04:48: Successfully interviewed '0x385b44fffe38ba50', device has successfully been paired
info 2022-12-23 23:04:48: Device '0x385b44fffe38ba50' is supported, identified as: IKEA STYRBAR remote control (E2001/E2002)
info 2022-12-23 23:04:48: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"STYRBAR remote control","exposes":[{"access":1,"description":"Remaining battery in %","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Triggered action (e.g. a button click)","name":"action","property":"action","type":"enum","values":["on","off","brightness_move_up","brightness_move_down","brightness_stop","arrow_left_click","arrow_right_click","arrow_left_hold","arrow_right_hold","arrow_left_release","arrow_right_release"]},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"E2001/E2002","options":[{"description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"access":2,"description":"Delta per interval, 20 by default","name":"delta","property":"delta","type":"numeric","value_min":0},{"access":2,"description":"Interval duration","name":"interval","property":"interval","type":"numeric","unit":"ms","value_min":0}],"name":"simulated_brightness","property":"simulated_brightness","type":"composite"},{"access":2,"description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true).","name":"legacy","property":"legacy","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"IKEA"},"friendly_name":"0x385b44fffe38ba50","ieee_address":"0x385b44fffe38ba50","status":"successful","supported":true},"type":"device_interview"}'
info 2022-12-23 23:04:48: Configuring '0x385b44fffe38ba50'
debug 2022-12-23 23:04:51: Received Zigbee message from '0x385b44fffe38ba50', type 'readResponse', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":255}' from endpoint 1 with groupID 0
info 2022-12-23 23:04:51: MQTT publish: topic 'zigbee2mqtt/0x385b44fffe38ba50', payload '{"action":null,"battery":255,"linkquality":129,"update":{"installed_version":"2.4.5","state":null},"update_available":null}'
info 2022-12-23 23:04:51: Successfully configured '0x385b44fffe38ba50'
debug 2022-12-23 23:07:12: Received Zigbee message from '0x385b44fffe38ba50', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":1,"fileVersion":33816581,"imageType":4555,"manufacturerCode":4476}' from endpoint 1 with groupID 0
debug 2022-12-23 23:07:12: Device '0x385b44fffe38ba50' requested OTA
debug 2022-12-23 23:07:15: Received Zigbee message from '0x385b44fffe38ba50', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":1,"fileVersion":33816581,"imageType":4555,"manufacturerCode":4476}' from endpoint 1 with groupID 0
debug 2022-12-23 23:07:15: Device '0x385b44fffe38ba50' requested OTA
debug 2022-12-23 23:07:18: Received Zigbee message from '0x385b44fffe38ba50', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":1,"fileVersion":33816581,"imageType":4555,"manufacturerCode":4476}' from endpoint 1 with groupID 0
debug 2022-12-23 23:07:18: Device '0x385b44fffe38ba50' requested OTA
debug 2022-12-23 23:07:21: Received Zigbee message from '0x385b44fffe38ba50', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":1,"fileVersion":33816581,"imageType":4555,"manufacturerCode":4476}' from endpoint 1 with groupID 0
debug 2022-12-23 23:07:21: Device '0x385b44fffe38ba50' requested OTA
debug 2022-12-23 23:07:24: Received Zigbee message from '0x385b44fffe38ba50', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":1,"fileVersion":33816581,"imageType":4555,"manufacturerCode":4476}' from endpoint 1 with groupID 0
debug 2022-12-23 23:07:24: Device '0x385b44fffe38ba50' requested OTA
