Le voilà:
[{"id":"0df17cb55cfd7cab","type":"group","z":"ea8b7ed34ae95eac","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["5526bef985bf46cc","9d298a7b5c8556b7","0a5955d64cb1f021","3f0428d370831ca3","b42912e903ed6137","344c88ed487ba6cb","63329616cb45d337","db3b23461118300d","70fa74f857392644","779434d951fa82b8","d058fe9fa948b920","397ecfc79c15a97b"],"x":34,"y":39,"w":1032,"h":362},{"id":"5526bef985bf46cc","type":"api-current-state","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Octas < 4","server":"6e2e256a.eda18c","version":3,"outputs":2,"halt_if":"4","halt_if_type":"num","halt_if_compare":"lt","entity_id":"sensor.sensor_paris_20eme_arrondissement_cloud_cover_octas","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"msg.payload","valueType":"jsonata"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":160,"y":280,"wires":[["9d298a7b5c8556b7"],[]]},{"id":"9d298a7b5c8556b7","type":"api-current-state","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"wu_temp >= 27","server":"6e2e256a.eda18c","version":3,"outputs":2,"halt_if":"27","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.sensor_wu_current_temp","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"msg.payload","valueType":"jsonata"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":340,"y":280,"wires":[["d058fe9fa948b920"],[]]},{"id":"0a5955d64cb1f021","type":"time-range-switch","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"","lat":"48.856614","lon":"2.3522219","startTime":"14:00","endTime":"sunset","startOffset":"","endOffset":"-90","x":840,"y":80,"wires":[[],[]]},{"id":"3f0428d370831ca3","type":"within-time-switch","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"","nameInt":"","positionConfig":"77f0059917748173","startTime":"15:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"18:30","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeRestrictions":0,"timeRestrictionsType":"none","timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"withinTimeValueType":"msgInput","outOfTimeValueType":"msgInput","tsCompare":"0","x":390,"y":140,"wires":[["397ecfc79c15a97b"],[]]},{"id":"b42912e903ed6137","type":"api-current-state","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"","server":"6e2e256a.eda18c","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"cover.volet_salle_a_manger_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"msg.payload","valueType":"jsonata"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":270,"y":360,"wires":[["344c88ed487ba6cb"]]},{"id":"344c88ed487ba6cb","type":"function","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Current Position","func":"\nvar newMsg = { payload: msg.data.attributes.current_position };\nreturn newMsg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":560,"y":360,"wires":[["63329616cb45d337"]]},{"id":"63329616cb45d337","type":"switch","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Position Auto 99 ?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"99","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":770,"y":360,"wires":[["db3b23461118300d"]]},{"id":"db3b23461118300d","type":"api-call-service","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Volet SaM 42","server":"6e2e256a.eda18c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.volet_salle_a_manger_2"],"data":"{\"position\":42}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":970,"y":360,"wires":[[]]},{"id":"70fa74f857392644","type":"comment","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Descendre le volet si chaleur","info":"","x":180,"y":80,"wires":[]},{"id":"779434d951fa82b8","type":"cron","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Every 10 minutes","crontab":"*/10 * * * *","x":140,"y":140,"wires":[["3f0428d370831ca3"]]},{"id":"d058fe9fa948b920","type":"api-current-state","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Temp biblio > 25","server":"6e2e256a.eda18c","version":3,"outputs":2,"halt_if":"25","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.ewelink_th01_bibliotheque_4b34a523_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"msg.payload","valueType":"jsonata"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":540,"y":280,"wires":[["b42912e903ed6137"],[]]},{"id":"397ecfc79c15a97b","type":"gate","z":"ea8b7ed34ae95eac","g":"0df17cb55cfd7cab","name":"Gate Lumi >=25000 pendant 20 minutes","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":820,"y":140,"wires":[["5526bef985bf46cc"]]},{"id":"6e2e256a.eda18c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30},{"id":"77f0059917748173","type":"position-config","name":"Paris","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12"}]
