Blocage loading DATA
Bonjour a tous,
J’ai un soucis de Loading DATA depuis quelque jour mais je ne vois pas d’où cela peu venir.
Et du coup impossible a démarrer. Hier j’ai créer une erreur pour pouvoir démmarer en Safe et restaurer une sauvegarde (ce qui a fonctionné hier soir) mais ca recommence ce soir sans avoir fait quoi que ce sois ???
2023-06-27 09:25:39.025 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.027 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.028 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration remote_homeassistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.031 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.032 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.035 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.037 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration freebox_player which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:39.039 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-27 09:25:57.891 ERROR (MainThread) [homeassistant.setup] Setup failed for browser_mod: Integration not found.
2023-06-27 09:25:57.950 ERROR (MainThread) [homeassistant.setup] Setup failed for nodered: Integration not found.
2023-06-27 09:26:10.031 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Mon domicile for smartthings
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 387, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/smartthings/__init__.py", line 122, in async_setup_entry
    token = await api.generate_tokens(
  File "/usr/local/lib/python3.11/site-packages/pysmartthings/smartthings.py", line 209, in generate_tokens
    result = await self._service.generate_tokens(
  File "/usr/local/lib/python3.11/site-packages/pysmartthings/api.py", line 424, in generate_tokens
    raise APIInvalidGrant(data.get("error_description"))
pysmartthings.errors.APIInvalidGrant: Invalid refresh token: f0aa4124-195f-4812-87c9-1432a39f4b8a requested by clientId: e0efc7b6-7a8e-4c4a-a9ac-441af78c74e7 with grantType: refresh_token, e.cause: no cause
2023-06-27 09:26:12.763 WARNING (MainThread) [homeassistant.components.freebox.router] Home access is not granted
2023-06-27 09:26:24.606 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547452962128] Error handling message: Unknown error (unknown_error) Nicolas from 45.137.145.20 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36 OPR/99.0.0.0)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 382, in handle_get_services
    payload = await _async_get_all_descriptions_json(hass)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 363, in _async_get_all_descriptions_json
    descriptions = await async_get_all_descriptions(hass)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 614, in async_get_all_descriptions
    domain_yaml = loaded[domain]
KeyError: 'alarm_control_panel'
2023-06-27 09:26:34.514 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547452962128] Error handling message: Unknown error (unknown_error) Nicolas from 45.137.145.20 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36 OPR/99.0.0.0)
2023-06-27 09:26:50.220 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: androidtv_remote
2023-06-27 09:26:55.379 WARNING (MainThread) [homeassistant.helpers.entity] Update of number.camera_louen_movement_angle is taking over 10 seconds
2023-06-27 09:26:57.286 WARNING (MainThread) [homeassistant.helpers.entity] Update of number.camera_mael_movement_angle is taking over 10 seconds
2023-06-27 09:27:15.379 WARNING (MainThread) [homeassistant.components.number] Updating tapo_control number took longer than the scheduled update interval 0:00:30
2023-06-27 09:27:17.286 WARNING (MainThread) [homeassistant.components.number] Updating tapo_control number took longer than the scheduled update interval 0:00:30
2023-06-27 09:27:50.316 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: androidtv_remote
2023-06-27 09:28:17.659 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Freebox Player POP' for androidtv_remote integration not ready yet: Couldn't connect to 192.168.0.10:6466; Retrying in background
2023-06-27 09:28:17.661 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Téléviseur du salon' for androidtv_remote integration not ready yet: Couldn't connect to 192.168.0.10:6466; Retrying in background
2023-06-27 09:28:24.471 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera_louen_sd] Error from stream worker: Timestamp discontinuity detected: last dts = 247093, dts = 4293762921
2023-06-27 09:28:24.471 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.camera_mael_sd_stream] Error from stream worker: Timestamp discontinuity detected: last dts = 253119, dts = 4292521651
2023-06-27 09:28:24.697 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547012482768] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:28:24.892 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/api/__init__.py", line 302, in get
    services = await async_services_json(request.app["hass"])
  File "/usr/src/homeassistant/homeassistant/components/api/__init__.py", line 397, in async_services_json
2023-06-27 09:28:30.284 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:36.870 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:39.860 ERROR (MainThread) [frontend.js.latest.202306080] blob:https://ha.mamaisondomo.ovh/b6e222ce-d778-4306-a93a-18752281a7c7:1:100 Uncaught ReferenceError: t is not defined
2023-06-27 09:28:40.018 ERROR (MainThread) [frontend.js.latest.202306080] blob:https://ha.mamaisondomo.ovh/d32b3c7f-335f-4b65-aa4e-300a823ed95f:1:100 Uncaught ReferenceError: t is not defined
2023-06-27 09:28:42.424 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:43.997 ERROR (MainThread) [frontend.js.latest.202306080] blob:https://ha.mamaisondomo.ovh/267e0620-7b88-4036-a86e-61028007b15b:1:100 Uncaught ReferenceError: t is not defined
2023-06-27 09:28:44.144 ERROR (MainThread) [frontend.js.latest.202306080] blob:https://ha.mamaisondomo.ovh/2d147f9f-c5e8-43b0-889a-e56416540016:1:100 Uncaught ReferenceError: t is not defined
2023-06-27 09:28:46.132 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:47.758 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:52.530 ERROR (MainThread) [frontend.js.latest.202306080] blob:https://ha.mamaisondomo.ovh/8951acbe-88ea-4b31-8a1c-9b99495c8a7d:1:100 Uncaught ReferenceError: t is not defined
2023-06-27 09:28:52.533 ERROR (MainThread) [frontend.js.latest.202306080] blob:https://ha.mamaisondomo.ovh/c2b629f8-4708-4ea8-94ec-a7c818196572:1:100 Uncaught ReferenceError: t is not defined
2023-06-27 09:28:53.064 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:58.314 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:28:59.918 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546975410704] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:29:03.586 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:08.937 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:14.350 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:16.580 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:19.605 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:24.953 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:30.293 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:35.628 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:36.050 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547017701584] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:29:40.943 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:46.382 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:47.137 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:51.667 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:29:52.256 WARNING (MainThread) [homeassistant.components.automation.allumer_le_chauf_piece_de_vie_fen_ferme_1min] Allumer le chauf piece de vie fen fermé 1min: Already running
2023-06-27 09:29:52.276 WARNING (MainThread) [homeassistant.components.automation.allumer_le_chauf_piece_de_vie_fen_ferme_1min] Allumer le chauf piece de vie fen fermé 1min: Already running
2023-06-27 09:29:56.942 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:02.217 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:07.461 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:09.695 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547068826000] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:30:12.725 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:17.731 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:18.060 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:23.382 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:28.621 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:33.890 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:39.192 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:43.451 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546974097040] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:30:45.282 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:48.155 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:50.594 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:30:55.867 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:01.802 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:07.060 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:12.418 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:16.426 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547040190928] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:31:17.728 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:18.540 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:23.069 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:28.381 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:33.705 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:38.973 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:44.278 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:48.908 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:49.923 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:31:49.949 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546975302992] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:31:55.265 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:00.699 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:06.019 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:11.308 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:16.609 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:19.263 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:21.901 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:22.943 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547017823760] Error handling message: Unknown error (unknown_error) Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2023.06.2 aiohttp/3.8.4 Python/3.11)
2023-06-27 09:32:27.206 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:32.574 ERROR (MainThread) [aiohttp.server] Error handling request
2023-06-27 09:32:37.896 ERROR (MainThread) [aiohttp.server] Error handling request
dur de répondre sans configuration.
Oui mais le problème cest que je ne peux pas le demarrer et donc pas récupérer la config…
Voici l’erreur que j’ai pu détecté qui bloque mon ouverture :
2023-06-27 20:24:13.775 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546728896272] Error handling message: Unknown error (unknown_error) Nicolas from 192.168.0.12 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 Edg/114.0.1823.58)
Réponse complètement au pif, mais qui peut être une piste.
Si cela fonctionne après une restauration, il n’y aurait pas un problème d’espace disque ?
J’ai également déjà eu des conf qui se corrompaient, car la clef USB sur lequel est installée l’application commençait à dysfonctionner (problème de carte sd ? ssd ?).
Pour info j’ai réinstallé l’OS 10.3 et même problème …
On dirais une erreur sur les fichier de démarrage du home assistant (Fichier python ce connection)
Je suis redescendu en 10.2 pour voir depuis hier ca a l’air stable.
Est ce que quelqu’un a le même problème en RPI 4 en 64Bits ?
voici ma config :
version core-2023.6.1
python_version 3.11.3
os_version 6.1.21-v8
GitHub API Calls Remaining 3789
Installed Version 1.32.1
Available Repositories 1277
Downloaded Repositories 29
host_os Home Assistant OS 10.2
supervisor_version supervisor-2023.06.4
agent_version 1.5.1
docker_version 23.0.6
disk_total 219.4 GB
disk_used 7.7 GB
board rpi4-64
installed_addons File editor (5.6.0), MariaDB (2.6.1), NGINX Home Assistant SSL proxy (3.5.0), Samba share (10.0.2), AdGuard Home (4.8.10), Node-RED (14.2.2), Advanced SSH & Web Terminal (15.0.2), Let’s Encrypt (4.12.9), AppDaemon (0.13.1), Samba Backup (5.2.0), Mosquitto broker (6.2.1), Zigbee2MQTT (1.32.0-2), Glances (0.19.2), ESPHome (2023.6.3)
dashboards 2
resources 19
views 4
oldest_recorder_run 2 juillet 2023 à 11:57
current_recorder_run 2 juillet 2023 à 14:15
estimated_db_size 256.17 MiB
database_version 3.41.2
Spotify
api_endpoint_reachable ok
Bon apres de multiple reinstallation et test…
J’ai fini par trouver j’avais installer home assistant remote, et c’est lui qui a créé un conflit du démarrage.
Si ca peu servir a quelqu’un d’autre
Bonsoir. Bon j’ai le même soucis. Jamais eu de soucis jusque la mais il y a 2 jours, l’erreur est arrivée suite à une mise à jour et perte de réseau (mais au final c’est peut etre pas lié). J’ai donc tenté de réinstaller le systeme et remettre ma sauvegarde, l’interface se lance bien mais j’avais des mises à jour a faire d’intégrations donc je le fais et op, a nouveau le soucis, je retente mais cette fois mise à jour du systeme, pareil, ca refonctionne jusqu’au rechargement de la page et à nouveau le soucis. 3eme tentative, tjs avec ma sauvegarde, je ne fais aucune mise à jour, je refresh la page pour voir et c’est a nouveau le soucis.
@Nicog35 tu parles d’avoir retirer HA remote, comment tu as fait avec le systeme en loading comme moi ? directement depuis les fichiers du disque dur ?
