Plutôt qu’ouvrir un nouveau post je continue ici.
Voici mon code:
substitutions:
device_name: co2-temp
time_timezone: "Europe/Paris"
friendly_name: co2
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "dC5e8iZGcjBOnqNESrzmBDPVbYde3g36op3sUlGfrXc="
ota:
- platform: esphome
password: "01f0d019d6f0eacc1a6e88ddaa595092"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.234
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Co2 Fallback Hotspot"
password: "URtgpx24B9jE"
captive_portal:
uart:
tx_pin: GPIO12
rx_pin: GPIO13
baud_rate: 9600
time:
- platform: homeassistant
binary_sensor:
- platform: status
switch:
- platform: restart
- platform: mhz19
co2:
filters:
- sliding_window_moving_average:
window_size: 30
send_every: 30
automatic_baseline_calibration: false
temperature:
update_interval: 60s
- platform: wifi_signal
name: "${friendly_name} WiFi Signal"
unit_of_measurement: ppm
lambda: |-
return id(co2_valeur).state;
filters:
window_size: 120
send_every: 1
on_value:
then:
- script.execute: update_co2
text_sensor:
script:
- id: update_co2
mode: restart
then:
- if:
condition:
or:
- sensor.in_range:
above: 1200
then:
- text_sensor.template.publish:
state: Mauvais
- script.execute: show_tr_bad
else:
- if:
condition:
or:
- sensor.in_range:
above: 800
then:
state: Mediocre
- script.execute: show_bad
else:
- if:
condition:
or:
- sensor.in_range:
above: 400
then:
state: Acceptable
- script.execute: show_acceptable
else:
state: Bon
- script.execute: show_good
# Configuration for showing AQI status with the RGB LED
- id: show_tr_bad
then:
- if:
condition:
- lambda: 'return id(ha_time).now().hour < 23 && id(ha_time).now().hour > 7 ;'
then:
- light.turn_on:
brightness: 30%
red: 80%
green: 0%
blue: 20%
else:
- light.turn_off:
- id: show_bad
then:
- if:
condition:
then:
- light.turn_on:
brightness: 30%
red: 100%
green: 60%
blue: 20%
else:
- light.turn_off:
- id: show_acceptable
then:
- if:
condition:
then:
- light.turn_on:
brightness: 30%
red: 100%
green: 87%
blue: 20%
else:
- light.turn_off:
- id: show_good
then:
- if:
condition:
then:
- light.turn_on:
brightness: 30%
red: 0%
green: 60%
blue: 40%
else:
- light.turn_off:
light:
- platform: neopixelbus
type: GRB
variant: WS2812x
pin: GPIO4
num_leds: 4
mon souci est que les leds passent au bleu ou vert pendant 3,4 secondes tous les minutes.
J’ai un montage similaire avec un PMS5003 et il fonctionne correctement ici
Des idées?
