Le non de mon sensor: sensor.shelly_shem_485519c9c2da_2_current_consumption
Je ne savais pas que c’était possible d’avoir deux graphique avec un seul sensor! ![]()
J’ai essayer de suivre ce lien Configuration sensor Energie mais je n’arrive pas a configurer les entitées de production et de consomation.
# consommation énergie
sensors:
solar_consumption:
friendly_name: "solar_conso_net"
value_template: >-
{% set solar = states('sensor.envoy_122012103733_current_energy_consumption') | int %}
{% set house = states('sensor.envoy_122012103733_current_energy_production') | int %}
{{ solar if house > solar else house }}
device_class: power
unit_of_measurement: W
sensors:
energy_import_export:
friendly_name: "Energy"
value_template: "{% if (states('sensor.envoy_122012103733_current_energy_production') | int - states('sensor.envoy_122012103733_current_energy_consumption') | int) > 0 %}Exporting{% else %}Importing{% endif %}"
icon_template: "{% if (states('sensor.envoy_122012103733_current_energy_production') | int - states('sensor.envoy_122012103733_current_energy_consumption') | int) > 0 %}mdi:arrow-up-box{% else %}mdi:arrow-down-box{% endif %}"
# calcul power export
sensors:
energy_exporting:
friendly_name: "Current Energy Exporting"
value_template: "{{ [0, (states('sensor.envoy_122012103733_current_energy_production') | int - states('sensor.envoy_122012103733_current_energy_consumption') | int)] | max }}"
unit_of_measurement: 'W'
icon_template: 'mdi:flash'
# calcul power import
sensors:
energy_importing:
friendly_name: "Current Energy Importing"
value_template: "{{ [0, (states('sensor.envoy_122012103733_current_energy_consumption') | int - states('sensor.envoy_122012103733_current_energy_production') | int)] | max }}"
# Création de l'énergie exportée sur le réseau en Wh
- platform: integration
source: sensor.energy_exporting
unit_prefix: k
round: 2
method: left
# Création de l'énergie importée du réseau en Wh
source: sensor.energy_importing
unit_prefix: k
round: 2
method: left
# history demarrage panneaux solaire
- platform: history_stats
name: temps de production aujourd'hui
entity_id: binary_sensor.solar_run
state: "on"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0) }}"
end: "{{ now() }}"
#energy
#enphase special Net energy. calcul pour l’energie exporte ou importe avec un changement de nom et d’icon suivant si c’est de l’import ou de l’export
sensors:
inst_energy_difference:
friendly_name: Instant Energy Difference
icon_template: >
{% if (states("sensor.inst_energy_difference") | int > 0) -%}
mdi:solar-panel
{%- elif (states("sensor.inst_energy_difference") | int < 0) -%}
mdi:transmission-tower
{%- else -%}
mdi:power-off
{%- endif %}
friendly_name_template: >
Currently Exporting
Currently Importing
{%- else -%}
Balanced
{%- endif %}
unit_of_measurement: "W"
device_class: power
value_template: >
{{ '%0.0f' | format(states('sensor.envoy_122012103733_current_energy_production') | int - states('sensor.envoy_122012103733_current_energy_consumption') | int) }}
#production consommation en KWh
sensors:
pv_solar_production_kwh:
friendly_name: "production_solaire_kwh"
unit_of_measurement: 'kWh'
value_template: "{{ states('sensor.envoy_122012103733_today_s_energy_production') | float / 1000 }}"
pv_solar_todays_consumption_kwh:
friendly_name: "pv_solar_todays_consumption_kwh"
value_template: "{{ states('sensor.envoy_122012103733_today_s_energy_consumption') | float / 1000 }}"
