bonjour
je cherche a domotiser un compteur d’eau
j’ai acheter un capteur tcrt5000 comme celui la:
https://www.amazon.fr/gp/product/B07TZ782F4/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
j’ai un nodemcu que je voudrais configurer si possible sous esphome
j’ai trouver des infos sur ce github :
GitHub - hugokernel/esphome-water-meter: Measurement of water consumption directly from your water meter with a TCRT5000 like sensor and ESPHome.
j’ai essayer de compiler le fichier mais j’ai des erreurs dans la validation .
esphome:
platform: ESP8266
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "cxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx2"
wifi:
ssid: "xxxxxx"
password: "xxxxxxxx"
ap:
ssid: "Eau Fallback Hotspot"
password: "fmZ7VoIouND7"
captive_portal:
logger:
level: INFO # Flashing effect generate too many debug log
# Documentations:
# https://github.com/esphome/issues/issues/664
# https://esphome.io/components/sensor/integration.html
# https://community.home-assistant.io/t/using-esphome-to-build-a-water-flow-rate-meter/119380/64
globals:
- id: main_counter_pulses
type: int
restore_value: yes
initial_value: '0'
- id: secondary_counter_pulses
type: int
restore_value: yes
initial_value: '0'
- id: daily_counter_pulses
type: int
restore_value: yes
initial_value: '0'
- id: weekly_counter_pulses
type: int
restore_value: yes
initial_value: '0'
- id: monthly_counter_pulses
type: int
restore_value: yes
initial_value: '0'
- id: yearly_counter_pulses
type: int
restore_value: yes
initial_value: '0'
- id: event_quantity
type: int
restore_value: no
initial_value: '0'
- id: last_event_quantity
type: int
restore_value: no
initial_value: '0'
- id: event_counter
type: int
restore_value: no
initial_value: '0'
- id: current_event_quantity
type: int
restore_value: no
initial_value: '0'
- id: higher_resistance
type: float
restore_value: yes
initial_value: '0'
i2c:
sda: GPIO21
scl: GPIO22
script:
- <<: *flashing
- id: reset_main_counter
then:
- lambda: |-
id(main_counter_pulses) = 0;
id(water_main_consumption).publish_state(id(main_counter_pulses));
- id: reset_secondary_counter
then:
- lambda: |-
id(secondary_counter_pulses) = 0;
id(water_secondary_consumption).publish_state(id(secondary_counter_pulses));
- id: publish_states
then:
- lambda: |-
id(water_daily_consumption).publish_state(id(daily_counter_pulses));
id(water_weekly_consumption).publish_state(id(weekly_counter_pulses));
id(water_monthly_consumption).publish_state(id(monthly_counter_pulses));
id(water_yearly_consumption).publish_state(id(yearly_counter_pulses));
id(current_water_consumption).publish_state(id(event_quantity));
- id: test_ldr
then:
# Leave time to LDR
- delay: 5sec
- lambda: |-
id(higher_resistance) = max(id(ldr_sensor).state, id(higher_resistance));
- logger.log:
level: INFO
format: "> Resistance: %.1f < %.1f"
args: ['id(ldr_sensor).state', 'id(higher_resistance) / 3']
- if:
condition:
lambda: "return (id(ldr_sensor).state < id(higher_resistance) / 3);"
then:
- binary_sensor.template.publish:
state: ON
else:
state: OFF
- platform: uptime
- platform: wifi_signal
name: "${friendly_name} WiFi signal"
- platform: am2320
# Fix the "Communication with AM2320 failed!" problem
# From https://github.com/esphome/issues/issues/192#issuecomment-481171704
# Fixed: the initial problem was fixed by adding external 4.7kOhms pullups
# on SDA/SCL lines.
#setup_priority: -100
temperature:
name: "${friendly_name} temperature"
humidity:
name: "${friendly_name} humidity"
update_interval: 60s
# TCRT5000 pulse counter
# IO18 / GPIO18
- platform: pulse_counter
name: "${friendly_name} water consumption"
pin: GPIO18
update_interval: 2sec
internal_filter: 10us
unit_of_measurement: "L/min"
accuracy_decimals: 0
icon: "mdi:water"
filters:
# Divide by 60
- multiply: 0.0167
- lambda: return abs(x);
# Value calculated are not consistent
#- platform: integration
# id: water_integration_sensor
# name: "${friendly_name} integrated water consumption"
# sensor: water_pulse_counter
# time_unit: min
# unit_of_measurement: "L"
# accuracy_decimals: 0
# icon: "mdi:water"
name: "${friendly_name} main water consumption"
icon: "mdi:water"
name: "${friendly_name} secondary water consumption"
icon: "mdi:water"
name: "${friendly_name} daily water consumption"
icon: "mdi:water"
name: "${friendly_name} weekly water consumption"
icon: "mdi:water"
name: "${friendly_name} monthly water consumption"
icon: "mdi:water"
name: "${friendly_name} yearly water consumption"
icon: "mdi:water"
name: "${friendly_name} current water consumption"
icon: "mdi:water"
name: "${friendly_name} last water consumption"
icon: "mdi:water"
- platform: adc
pin: GPIO33
attenuation: 11db
internal: true
update_interval: 200ms
filters:
- multiply: 0.846153 # 3.9 (11db attenuation full-scale voltage) -> 3.3V
- median:
window_size: 5
send_every: 3
- platform: resistance
sensor: source_sensor
configuration: UPSTREAM
resistor: 10kOhm
reference_voltage: 3.3V
name: "${friendly_name} LDR resistance"
binary_sensor:
# IO18 / GPIO18
- platform: gpio
pin: GPIO18
internal: true
filters:
- delayed_on_off: 50ms
- lambda: |-
id(main_counter_pulses) += x;
id(secondary_counter_pulses) += x;
id(daily_counter_pulses) += x;
id(weekly_counter_pulses) += x;
id(monthly_counter_pulses) += x;
id(yearly_counter_pulses) += x;
id(event_quantity) += x;
return x;
on_state:
- script.execute: publish_states
name: "${friendly_name} light detector"
device_class: light
switch:
name: "${friendly_name} reset main counter button"
icon: "mdi:restart"
turn_on_action:
- script.execute: reset_main_counter
name: "${friendly_name} reset secondary counter button"
icon: "mdi:restart"
turn_on_action:
- script.execute: reset_secondary_counter
- platform: restart
light:
- platform: fastled_clockless
chipset: WS2812
name: "${friendly_name} status light"
pin: GPIO27
num_leds: 1
rgb_order: GRB
restore_mode: ALWAYS_OFF
on_turn_off:
- script.execute: test_ldr
time:
- platform: sntp
on_time:
- seconds: 0
minutes: 0
hours: 0
then:
- globals.set:
value: '0'
- lambda: id(water_daily_consumption).publish_state(id(daily_counter_pulses));
- seconds: 0
minutes: 0
hours: 0
days_of_week: MON
then:
- globals.set:
value: '0'
- lambda: id(water_weekly_consumption).publish_state(id(weekly_counter_pulses));
- seconds: 0
minutes: 0
hours: 0
days_of_month: 1
then:
- globals.set:
value: '0'
- lambda: id(water_monthly_consumption).publish_state(id(monthly_counter_pulses));
- seconds: 0
minutes: 0
hours: 0
days_of_month: 1
months: JAN
then:
- globals.set:
value: '0'
- lambda: id(water_yearly_consumption).publish_state(id(yearly_counter_pulses));
interval:
# Save the last consumption
# An event is published when a water flow (>= 1L / 15 seconds) is
# detected and followed by a stop of consumption for a defined time.
- interval: 15sec
then:
- lambda: |-
if (id(event_quantity) != id(last_event_quantity)) {
// Water continues to flow
// Reset event counter
id(event_counter) = 0;
} else {
// Water no longer flows
if (id(event_quantity)) {
// 4 * 15 * 5 = 5min
if (id(event_counter) < 4 * 5) {
// Timeout is not reaches
id(event_counter)++;
} else {
// Timeout is reaches
id(last_water_consumption).publish_state(id(event_quantity));
// Send event to Home Assistant
api::HomeAssistantServiceCallAction<> *api;
api = new api::HomeAssistantServiceCallAction<>(api_apiserver, true);
// Event id length limit is 32 characters
api->set_service("esphome.last_consumption_changes");
api->play();
id(event_quantity) = 0;
id(last_event_quantity) = id(event_quantity);
# Track the current consumption
- interval: 2sec
then:
- lambda: |-
if (id(event_quantity) != id(current_event_quantity)) {
id(current_event_quantity) = id(event_quantity);
pouvez vous m’aidez ?
merci
