Connection mosquito broker et opendtu (TCP disconnected)
j’avais HA installé sur un VIM1S pour gérer un opendtu et une centrale meteo (tout fonctionnait), J’ai remplacé le VIM1S par une GREEN BOX avec une clé SONOFF ZigBee 3.0 USB ( avec thermometre); tout fonctionne sauf la liaison entre l’OPENDTU et le Mosquito Broker;
La liaison TCP est déconnecté constamment, Dans la conf de l’opendtu, je n’ai changé que l’adresse de HA
console opendtu
16:13:52.306] I (4990889) hoymiles: RX Period End
[16:13:59.747] I (4990890) hoymiles: Success
[16:13:59.747] W (4998653) mqtt: Disconnected from MQTT. Reason: TCP_DISCONNECTED
[16:14:01.430] I (5000332) hoymiles: Fetch inverter: 114491121898
[16:14:01.593] I (5000333) hoymiles: Queue size - NRF: 0 CMT: 1
[16:14:01.593] D (5000347) hoymiles: TX RealTimeRunData 865.00 MHz --> 15 91 12 18 98 00 01 14 49 80 0B 00 69 55 3D B9 00 00 00 00 00 00 00 00 09 E3 93
[16:14:01.593] V (5000431) hoymiles: Interrupt received
[16:14:01.593] D (5000437) hoymiles: RX 865.00 MHz --> 95 91 12 18 98 00 01 14 49 01 00 01 01 45 01 42 00 43 00 46 00 DC 00 E1 00 0D F8 | -41 dBm
[16:14:01.593] V (5000481) hoymiles: Interrupt received
[16:14:01.593] D (5000486) hoymiles: RX 865.00 MHz --> 95 91 12 18 98 00 01 14 49 02 E8 75 00 0D 90 B5 01 DE 01 8B 09 4D 13 85 01 A5 5E | -42 dBm
[16:14:01.987] V (5000528) hoymiles: Interrupt received
[16:14:01.987] D (5000533) hoymiles: RX 865.00 MHz --> 95 91 12 18 98 00 01 14 49 83 00 00 00 11 03 E7 00 44 00 0A 38 45 8F | -42 dBm
[16:14:01.987] I (5000654) mqtt: Connecting to MQTT...
version core-2025.12.5
container_arch aarch64
python_version 3.13.9
os_version 6.12.51-haos
Installed Version 2.0.5
Available Repositories 2500
Downloaded Repositories 6
supervisor_version supervisor-2025.12.3
agent_version 1.7.2
docker_version 28.3.3
disk_total 28.0 GB
disk_used 6.2 GB
nameservers 192.168.1.1
virtualization
board green
installed_addons Samba share (12.5.4), Samba Backup (5.2.0), Terminal & SSH (9.21.0), MQTT Explorer (browser-1.0.1), Zigbee2MQTT (2.7.1-1), Mosquitto broker (6.5.2)
dashboards 3
resources 3
views 1
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), docker0 (disabled), hassio (disabled), vetha5b836d (disabled), veth0fe04b1 (disabled), veth0bd6200 (disabled), veth957c57e (disabled), veth17576a5 (disabled), veth79060fe (disabled), veth6b4772e (disabled), vethdd94ce9 (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (192.168.2.6/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vetha5b836d (), veth0fe04b1 (), veth0bd6200 (), veth957c57e (), veth17576a5 (), veth79060fe (), veth6b4772e (), vethdd94ce9 ()
ipv6_addresses lo (::1/128), end0 (fe80::d13d:a4d1:de8b:1b6e/64), docker0 (fe80::d076:a9ff:fe25:ee71/64), hassio (fd0c:ac1e:2100::1/48, fe80::6c74:b9ff:fe78:a7a0/64), vetha5b836d (fe80::8035:69ff:fe76:beb/64), veth0fe04b1 (fe80::a4e5:bdff:fe83:206f/64), veth0bd6200 (fe80::940e:77ff:fe3c:f0a5/64), veth957c57e (fe80::3c7c:88ff:fe83:e051/64), veth17576a5 (fe80::9c66:5eff:fe53:bb16/64), veth79060fe (fe80::584e:7ff:feee:ccc1/64), veth6b4772e (fe80::d846:b1ff:fe5e:7142/64), vethdd94ce9 (fe80::2c51:3ff:fea7:b9df/64)
announce_addresses 192.168.2.6, fe80::d13d:a4d1:de8b:1b6e
oldest_recorder_run 20 décembre 2025 à 08:54
current_recorder_run 31 décembre 2025 à 14:48
estimated_db_size 180.47 MiB
database_version 3.49.2
Le problème semble venir du pare-feu de mon routeur
