je suis encore newbie en domotique et j’ai commandé une clé zigbee cc2531 que j’ai flashée.
j’ai installé un raspberry avec zigbee2mqtt.
j’ai aussi fait une VM debian avec mosquitto.
L’installation avait l’air de bien se passer jusqu’à ce que je tente la connection entre le zigbee2mqtt et le serveur mosquitto.
Voici ce qui se passe lorsque je lance ‹ npm start › :
> node index.js
Zigbee2MQTT:info 2021-11-16 20:58:15: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2021-11-16.20-58-12' filename: log.txt
Zigbee2MQTT:info 2021-11-16 20:58:15: Starting Zigbee2MQTT version 1.22.0 (commit #945b72b9)
Zigbee2MQTT:info 2021-11-16 20:58:15: Starting zigbee-herdsman (0.13.164)
Zigbee2MQTT:info 2021-11-16 20:58:17: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2021-11-16 20:58:17: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20201127,"transportrev":2},"type":"zStack12"}'
Zigbee2MQTT:info 2021-11-16 20:58:17: Currently 0 devices are joined:
Zigbee2MQTT:warn 2021-11-16 20:58:17: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2021-11-16 20:58:17: Allowing new devices to join.
Zigbee2MQTT:warn 2021-11-16 20:58:17: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2021-11-16 20:58:17: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2021-11-16 20:58:17: Connecting to MQTT server at mqtt://192.168.1.52:1883
Zigbee2MQTT:error 2021-11-16 20:58:17: MQTT failed to connect: Connection refused: Not authorized
Zigbee2MQTT:error 2021-11-16 20:58:17: Exiting...
Zigbee2MQTT:info 2021-11-16 20:58:17: Stopping zigbee-herdsman...
Zigbee2MQTT:info 2021-11-16 20:58:18: Stopped zigbee-herdsman
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.22.0 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.22.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2021-11-16T19_58_18_206Z-debug.log
saisissez ou collez du code ici
alors à priori la connection est refusée par le broker, mais je ne trouve pas pourquoi.
Pour info, j’ai également essaye de me connecter via MQTT explorer, mais impossible.
Quelqu’un a-t-il déjà rencontré le même problème.
Dites moi si vous voulez un fichier de log en particulier.
Merci d’avance.
