Bonjour à tous, et meilleurs vœux pour 2023 !
J’ai acheté un RF link sur Nodo shop ( 433.42MHz), j’ai bien réussi à récupérer les commandes de mes stores sous Windows. Par contre, impossible de l’intégrer à HA… Je le détecte bien dans mon répertoire /dev/serial/by-id/ :
mais j’ai toujours l’erreur :
Logger: homeassistant.components.rflink
Source: components/rflink/__init__.py:277
Integration: RFLink (documentation, issues)
First occurred: 12:08:26 (1460 occurrences)
Last logged: 20:15:14
Error connecting to Rflink, reconnecting in 20
File "/usr/local/lib/python3.10/site-packages/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55139313435351201102-if00'
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 277, in connect
transport, protocol = await connection
File "/usr/local/lib/python3.10/site-packages/serial_asyncio/__init__.py", line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/usr/local/lib/python3.10/site-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55139313435351201102-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55139313435351201102-if00'
HA est installé en docker sur un Raspberry Pi 4.
Mon fichier de configuration :
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
rflink:
port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55139313435351201102-if00
wait_for_ack: true
reconnect_interval: 20
light:
- platform: rflink
automatic_add: true
- platform: rflink
automatic_add: true
zha:
custom_quirks_path: /config/custom_zha_quirks/
zigpy_config:
ota:
ikea_provider: true
ledvance_provider: true
salus_provider: true
inovelli_provider: true
#otau_directory: /config/zigpy_ota
- platform: gazpar
username: zzzzzzzzzzzzzzzzzzzzzzz@gmail.com
password: XXXXXXXXXXX
pce_identifier: YYYYYYYYYYY
tmpdir: /tmp
scan_interval: 08:00:00
- platform: derivative
source: sensor.lixee_zlinky_tic_smartenergy_metering_summation_delivered
round: 3
unit_time: h
unit: kW
time_window: "00:01:00"
- platform: rflink
automatic_add: true
template:
- sensor:
- name: gas_volume
unit_of_measurement: 'm³'
state: >
{{ state_attr('sensor.gazpar', 'daily')[0]['end_index_m3'] | float(0) }}
icon: mdi:fire
device_class: gas
state_class: total_increasing
- name: gas_energy
unit_of_measurement: 'kWh'
state: >
{{ states('sensor.gazpar') | float(0) }}
icon: mdi:fire
device_class: energy
- unique_id: lixee_zlinky_tic_metering_tarif_base
unit_of_measurement: "Wh"
state: available
Ma configuration :
[center]
## System Information
version | core-2022.10.1
installation_type | Home Assistant Container
dev | false
hassio | false
docker | true
user | root
virtualenv | false
python_version | 3.10.5
os_name | Linux
os_version | 5.15.79-v7l+
arch | armv7l
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4836
Installed Version | 1.28.4
Stage | running
Available Repositories | 1271
Downloaded Repositories | 5
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
dashboards | 1
resources | 1
views | 5
mode | storage
</details>
oldest_recorder_run | 30 décembre 2022, 12:54
current_recorder_run | 9 janvier 2023, 08:48
estimated_db_size | 124.14 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
[/center]
