Container docker Zigbee2mqtt s'arrête presque une fois par jour
J’utilise home Assistant sous docker. Mon container Z2M s’arrête quasiment une fois par jour avec le code « exit code 2 »
version core-2026.4.2
hassio false
container_arch amd64
python_version 3.14.2
os_version 6.12.74+deb13+1-amd64
arch x86_64
timezone Europe/Brussels
dashboards 5
resources 0
views 2
Network Configuration
adapters lo (disabled), enp88s0 (enabled, default, auto), br-cd41923337d0 (disabled), docker0 (disabled), veth860a8d4 (disabled), veth0682768 (disabled), vethf534042 (disabled), veth81ebd76 (disabled), veth475d145 (disabled)
ipv4_addresses lo (127.0.0.1/8), enp88s0 (192.168.1.107/24), br-cd41923337d0 (172.18.0.1/16), docker0 (172.17.0.1/16), veth860a8d4 (), veth0682768 (), vethf534042 (), veth81ebd76 (), veth475d145 ()
ipv6_addresses lo (::1/128), enp88s0 (2a01:cc00:c680:500:743e:18c5:e2d8:40d9/64, fdb3:ee03:bcc:0:bc2a:a26:7968:2f85/64, 2a01:cc00:c680:500:6821:686:3904:a133/64, fdb3:ee03:bcc:0:80ac:1da9:921d:50d3/64, fdb3:ee03:bcc::959/128, 2a01:cc00:c680:500::959/128, 2a01:cc00:c680:500:a488:b871:d3a8:f4b9/64, 2a01:cc00:c680:500:4a21:bff:fe33:1dcd/64, fdb3:ee03:bcc:0:1814:72ce:15a:2ba9/64, fdb3:ee03:bcc:0:4a21:bff:fe33:1dcd/64, fe80::4a21:bff:fe33:1dcd/64), br-cd41923337d0 (fe80::349d:49ff:fe61:9774/64), docker0 (), veth860a8d4 (fe80::449:2cff:fe16:43e/64), veth0682768 (fe80::c7f:64ff:febe:bdf0/64), vethf534042 (fe80::b4b5:2ff:fe6b:a76f/64), veth81ebd76 (fe80::545d:99ff:fe1b:1663/64), veth475d145 (fe80::461:ff:fe07:c9f5/64)
announce_addresses 192.168.1.107, 2a01:cc00:c680:500:743e:18c5:e2d8:40d9, fdb3:ee03:bcc:0:bc2a:a26:7968:2f85, 2a01:cc00:c680:500:6821:686:3904:a133, fdb3:ee03:bcc:0:80ac:1da9:921d:50d3, fdb3:ee03:bcc::959, 2a01:cc00:c680:500::959, 2a01:cc00:c680:500:a488:b871:d3a8:f4b9, 2a01:cc00:c680:500:4a21:bff:fe33:1dcd, fdb3:ee03:bcc:0:1814:72ce:15a:2ba9, fdb3:ee03:bcc:0:4a21:bff:fe33:1dcd, fe80::4a21:bff:fe33:1dcd
oldest_recorder_run 23 avril 2026 à 05:02
current_recorder_run 1 mai 2026 à 08:00
estimated_db_size 214.83 MiB
database_version 3.49.2
J’utilise une clé Zigbee 3.0 ZBDongle-E
Voici les Logs:
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash: Port closed, error=Error: bad file descriptor
[2026-04-17 23:04:11] error: 	zh:ember:ezsp: Fatal error, status=ERROR_SERIAL_INIT. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=29 Len=10]
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash: ASH COUNTERS since last clear:
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Total frames: RX=10, TX=13
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   DATA frames : RX=10, TX=3
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   DATA bytes  : RX=279, TX=82
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Retry frames: RX=0, TX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   ACK frames  : RX=0, TX=10
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2026-04-17 23:04:11] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2026-04-17 23:04:11] info: 	zh:ember:ezsp: ======== EZSP stopped ========
[2026-04-17 23:04:11] info: 	zh:ember: ======== Ember Adapter Stopped ========
[2026-04-17 23:04:11] error: 	z2m: Adapter disconnected, stopping
[2026-04-17 23:04:11] info: 	z2m: Stopping Zigbee2MQTT (restart=false, code=2, signal=undefined)
[2026-04-17 23:04:11] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2026-04-17 23:04:11] info: 	z2m: Disconnecting from MQTT server
[2026-04-17 23:04:11] info: 	z2m: Stopping zigbee-herdsman...
[2026-04-17 23:04:11] info: 	z2m: Stopped zigbee-herdsman
[2026-04-17 23:04:11] info: 	z2m: Stopped Zigbee2MQTT
Au plaisir de vous lire!
Tu sembles perdre la connexion à ta clef, ce qui met z2m en vrac. À voir ce quoi c’est du mais comme tu ne donnes pas trop d’info, ça peut être un problème d’alimentation, un port USB défaillant, un problème de conflit d’accès (si tu as zha toujours actif, par exemple)…
  • ZHA est ignoré
  • Le dongle est connecté sur une allonge USB qui est branchée sur un hub USB (TP-Link UH720 7 ports USB 3.0) avec alimentation électrique.
Teste un autre port (sans alimentation extérieure si possible) car l’erreur est écrite en noir sur blanc…
C’est pas plutôt blanc sur noir :grin:
Tout ça c’est blanc bonnet et bonnet blanc :wink:
Ok, je teste et j’attends. Il faut parfois 1 jour ou deux avant que ça plante !
pour en ajouter une couche c’est clair la connexion avec ton dongle est perdue
Je l’ai branché sur un autre port sans alim et ça tourne depuis une semaine sans planter. Ca a l’ai de fonctionner :slight_smile:
Merci pour votre aide!
Passe ton sujet en résolu si c’est OK pour toi
