je suis l’heureux nouveau propriétaire d’une clé Phoscon ZIGbee2Mqtt.
J’ai suivi le tuto du « journal de Thomas ».
Et je bloque sur un 502 bad gateway sur l’UI Zigbee2 mqtt.
Pourriez vous m’aider svp? (j’ai déjà chercher pas mal de sujet surle forum, sans jamais trouver la bonne solution pour mon pb.
merci d’avance,
mon fichier de cong zigbee2mqtt :
data_path: /config/zigbee2mqtt
external_converters:
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: /dev/ttyACM0
adapter: deconz
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist:
availability_passlist:
device_options: {}
blocklist:
passlist:
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: ‹ -d -d ›
log: false
zigbee_herdsman_debug: true
voici mon log après redémarrage de l’add-on zigbee2mqtt :
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] socat.sh: executing…
[17:23:27] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing…
[17:23:28] INFO: MQTT available, fetching server detail …
[17:23:28] INFO: MQTT server settings not configured, trying to auto-discovering …
[17:23:29] INFO: Configuring ‹ mqtt://core-mosquitto:1883 › mqtt server
[17:23:29] INFO: MQTT credentials not configured, trying to auto-discovering …
[17:23:29] INFO: Configuring’addons’ mqtt user
[17:23:29] INFO: Previous config file found, checking backup
[17:23:29] INFO: Creating backup config in ‹ /config/zigbee2mqtt/.configuration.yaml.bk ›
[17:23:29] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks …
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[17:23:31] INFO: Handing over control to Zigbee2mqtt Core …
zigbee2mqtt@1.22.2 start
node index.js
CREATED DECONZ ADAPTER
Zigbee2MQTT:error 2022-01-14 17:23:47: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-01-14 17:23:47: Failed to start zigbee
Zigbee2MQTT:error 2022-01-14 17:23:47: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2022-01-14 17:23:47: Exiting…
Zigbee2MQTT:error 2022-01-14 17:23:47: undefined
[17:23:48] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2022-01-14 17:24:04: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-01-14 17:24:04: Failed to start zigbee
Zigbee2MQTT:error 2022-01-14 17:24:04: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2022-01-14 17:24:04: Exiting…
Zigbee2MQTT:error 2022-01-14 17:24:04: undefined
[17:24:05] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:error 2022-01-14 17:24:21: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-01-14 17:24:21: Failed to start zigbee
Zigbee2MQTT:error 2022-01-14 17:24:21: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2022-01-14 17:24:21: Exiting…
Zigbee2MQTT:error 2022-01-14 17:24:21: undefined
[17:24:21] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
