Depuis que j’ai fait la MAJ HA 2021.5.4 Grafana (6.3.4) ne veux plus démarrer.
Le message d’erreur et mon système ci-dessous.
Avez-vous une idée ?
D’avance merci
Fabien
21-05-19 06:31:28 WARNING (SyncWorker_4) [supervisor.docker] Can't attach addon_a0d7b954_grafana to hassio-network!
21-05-19 06:31:29 ERROR (SyncWorker_4) [supervisor.docker] Can't start addon_a0d7b954_grafana: 403 Client Error for http+docker://localhost/v1.40/containers/262e0d53625dd7132f88863a36f7af4b56f73624550e24638089773a2ff62442/start: Forbidden ("endpoint with name addon_a0d7b954_grafana already exists in network bridge")
System Health
version: core-2021.5.4
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.9
os_name: Linux
os_version: 5.4.83-v7
arch: armv7l
timezone: Europe/Paris
GitHub API: ok
Github API Calls Remaining: 5000
Installed Version: 1.11.3
Stage: startup
Available Repositories: 842
Installed Repositories: 6
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 5.13
update_channel: stable
supervisor_version: supervisor-2021.04.3
docker_version: 19.03.15
disk_total: 55.7 GB
disk_used: 10.6 GB
healthy: true
supported: true
board: rpi3
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.3.0), Samba share (9.3.1), SSH & Web Terminal (8.2.1), InfluxDB (4.1.0), Node-RED (9.0.1), Mosquitto broker (5.1.1), Zigbee2mqtt (1.18.3-1), ESPHome (1.17.2), Let’s Encrypt (4.11.0), Grafana (6.3.4)
dashboards: 1
resources: 1
mode: storage
