Démarrage Node Red
J’ai installé Node Red sur HA.
J’ai rempli les lignes de la configuration avec les mots de passe.
J’ai redémarré HA
Dans la page Node Red, j’ai lancé le démarrage, le bouton en haut à droite passe en vert.
Mais quand je clique dans le menu Node Red du bandeau HA, il me dit qu’il faut le démarrer et le bouton en haut à droite de la page Node Red est repassé en rouge.
Merci pour votre aide,
patrickp78
poste les journaux de node red on verra ce qui ce passe
Désolé, je m’étais absenté.
Le voici :
s6-rc: info: service base-addon-banner: starting
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 14.0.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 9.4  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2022.12.8
 Home Assistant Supervisor: 2022.12.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
patching file nodes/ui_base.html
Hunk #1 succeeded at 1164 (offset 633 lines).
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
[12:54:56] FATAL:
[12:54:56] FATAL: SSL has been enabled using the 'ssl' option,
[12:54:56] FATAL: this requires a SSL certificate file which is
[12:54:56] FATAL: configured using the 'certfile' option in the
[12:54:56] FATAL: add-on configuration.
[12:54:56] FATAL:
[12:54:56] FATAL: Unfortunately, the file specified in the
[12:54:56] FATAL: 'certfile' option does not exists.
[12:54:56] FATAL:
[12:54:56] FATAL: Please ensure the certificate file exists and
[12:54:56] FATAL: is placed in the '/ssl/' directory.
[12:54:56] FATAL:
[12:54:56] FATAL: In case you don't have SSL yet, consider getting
[12:54:56] FATAL: a SSL certificate or setting the 'ssl' option
[12:54:56] FATAL: to 'false' in case you are not planning on using
[12:54:56] FATAL: SSL with this add-on.
[12:54:56] FATAL:
[12:54:56] FATAL: Check the add-on manual for more information.
[12:54:56] FATAL:
s6-rc: warning: unable to start service init-nginx: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
prog: fatal: stopping the container.
s6-rc: info: service nodered: stopping
[12:54:56] INFO: Service Node-RED exited with code 256 (by signal 15)
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
Les lignes qui commencent par “FATAL” décrivent le problème et la solution.
Si je comprends bien, je dois désactiver SSL pour le moment.
Comment ensuite puis-je obtenir un certificat si je veux une connexion SSL par la suite ?
Pour info, je dois en avoir un avec mon provider car j’ai un site dont la connexion se fait en https
Est-ce qu’il est à votre avis récupérable pour HA et Node Red ?
Sinon, y a t-il une autre solution ?
Merci pour vos conseils,
Comme on ne sait rien de ton installation, impossible de répondre aux questions…
