Detecteur de mouvent et moment d'allumage
Bonjour tout le monde,
J’ai reçus mes détecteur de mouvement Sonoff ( SNZB-03 ) j’ai réussi a les intégré la n’est pas le problème j’ai essayer de faire une automatisation avec un allumage a partir d’une certaine heure mais c’est la que ça ne vas pas malgré l’utilisation d’un blueprint la lumière s’allume peut importe l’heure alors soit j’ai mal compris une chose soit le blueprint est pas bon.
Merci pour votre aide.
Tom
Le blueprint
blueprint:
  description: Turn on a light when motion is detected.
  domain: automation
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    light_target:
      selector:
          entity:
            domain: light
    no_motion_wait:
      description: Time to leave the light on after last motion is detected.
      default: 120
      selector:
        number:
          min: 0
          max: 3600
          unit_of_measurement: seconds
    start_time:
      description: Time action should start
      default: '17:00:00'
      selector:
        time: {}
    end_time:
      default: 00:00:00
      description: Time action should stop
      selector:
        time: {}
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input motion_entity
  to: "on"
  - alias: "Turn on the light"
    service: light.turn_on
    target: !input light_target
  - alias: "Wait until there is no motion from device"
    wait_for_trigger:
      platform: state
      to: "off"
  - alias: "Wait the number of seconds that has been set"
    delay: !input no_motion_wait
  - alias: "Turn off the light"
    service: light.turn_off
L’automatisation
- id: '1662494882303'
  alias: 'Lumière cuisine '
  description: ''
  use_blueprint:
    path: homeassistant/test.yaml
    input:
      motion_entity: binary_sensor.mouvement_cuisine_iaszone
      end_time: 08:00:00
      light_target:
        entity_id:
        - scene.cuisine_matin
      start_time: 01:01:00
      no_motion_wait: 120
- id: '1662537470248'
  alias: Lumière cuisine  (Dupliquer)
  description: ''
  use_blueprint:
    input:
      end_time: '01:00:00'
      light_target:
        device_id: 6d8a02986c184ffa4d729c8338a128c7
      start_time: '17:00:00'
      no_motion_wait: 120
Version de l’intégration: 1.27.1
Version de l’interface: 20220825160758
Dépôts: 1179
Dépôts téléchargés: 25
Home Assistant 2022.8.7 Supervisor 2022.08.5 Operating System 8.5 Interface utilisateur : 20220802.0 - latest
Juste comme ça il considère pas que 0h00 c’est le même jour que 17h00 (comme dans la vraie vie)
Essaye avec 23h59
Ça fonctionne et j’avais aussi oublié des ’ au niveau des heures a un endroit
Merci Pulpy
