Bonsoir à tous,
Voici mon problème, j’ai réalisé deux capteurs de qualité de l’air sur la base du capteur Ikea, en suivant le tuto de rem81
J’ai donc configurer deux capteurs esphome
Le premier celui du Bureau
esphome:
platform: ESP8266
board: d1_mini_pro
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Test Fallback Hotspot"
password: "XXXXXXXX"
reboot_timeout: 5min
fast_connect: true
manual_ip:
static_ip: 192.168.2.48
gateway: 192.168.2.1
subnet: 255.255.255.0
dns1: 192.168.0.10
dns2: 192.168.0.1
# Enable logging
logger:
baud_rate: 0
api:
ota:
web_server:
port: 80
uart:
- id: uart_a
rx_pin: D2
baud_rate: 9600
- id: uart_b
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 9600
#Etat de la connection
binary_sensor:
- platform: status
switch:
- platform: restart
- platform: wifi_signal
name: "AQB WiFi Signal Sensor"
update_interval: 60s
- platform: pm1006
uart_id: uart_a
pm_2_5:
name: "Concentration Particules 2.5µm"
accuracy_decimals: 2
filters:
- sliding_window_moving_average:
window_size: 50
send_every: 10
send_first_at: 10
- platform: mhz19
uart_id: uart_b
co2:
name: "MH-Z19 CO2 Value"
temperature:
name: "MH-Z19 Temperature"
update_interval: 120s
automatic_baseline_calibration: false
Le deuxième celui de la salle à manger
esphome:
platform: ESP8266
board: d1_mini
wifi:
ap:
password: "XXXXXXXXXX"
fast_connect: true
manual_ip:
static_ip: 192.168.2.55
dns1: 192.168.0.10
dns2: 192.168.0.1
# Enable logging
logger:
baud_rate: 0
api:
ota:
web_server:
port: 80
uart:
- id: uart_a
rx_pin: D2
baud_rate: 9600
- id: uart_b
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 9600
binary_sensor:
- platform: status
switch:
- platform: restart
name: "WiFi Signal_air-qualite-salle-a-mangerrr"
- platform: pm1006
uart_id: uart_a
pm_2_5:
name: "Concentration Particules 2.5µm salle à manger"
filters:
window_size: 50
send_every: 10
send_first_at: 10
- platform: mhz19
uart_id: uart_b
co2:
name: "MH-Z19 CO2 Value_salle à manger"
temperature:
name: "MH-Z19 Temperature_salle à manger"
Mon problème est que je ne retrouve dans HA que les sensor du capteur du Bureau, mais pas celui de la salle à manger.
Auriez-vous une petite idée du pourquoi ?
D’avance merci
