Helo,
Récemment, Blakadder a mis à jour le template pour le GD-W32 diffuser, qui est approprié pour un diffuseur Maxcio comme celui que j’ai.
Le lien : GD-30W 300ml Aroma Diffuser Configuration for Tasmota
L’intégration finale me va mieu, cependant pour paraphraser Blakadder il semble que le dpid pour la diffusion ait plus de deux valeurs.
Source : Maxcio 400ML aroma diffuser: doesn't seem to publish dpid updates if the physical button is used · Issue #1029 · blakadder/templates · GitHub
J’ai bien collecté une tone de données, c’est pire qu’un cour de math :
18:05:16.964 {"TuyaReceived":{"Data":"55AA010700050C050001001E","Cmnd":7,"CmndData":"0C05000100","DpType5Id12":"0x00","12":{"DpId":12,"DpIdType":5,"DpIdData":"00"}}}
18:05:16.979 TYA: fnId=0 is set for dpId=12
18:05:16.984 {"TuyaReceived":{"Data":"55AA01070005670400010078","Cmnd":7,"CmndData":"6704000100","DpType4Id103":0,"103":{"DpId":103,"DpIdType":4,"DpIdData":"00"}}}
18:05:16.992 TYA: fnId=61 is set for dpId=103
18:05:16.995 SRC: Switch
18:05:16.998 CMD: Group 0, Index 1, Command "TUYAENUM", Data "0"
18:05:17.001 MQT: stat/diffuseur_bureau/RESULT = {"TuyaEnum1":0}
18:05:17.011 {"TuyaReceived":{"Data":"55AA01070005010100010110","Cmnd":7,"CmndData":"0101000101","DpType1Id1":1,"1":{"DpId":1,"DpIdType":1,"DpIdData":"01"}}}
18:05:17.020 TYA: fnId=11 is set for dpId=1
18:05:17.022 TYA: RX Relay-1 --> MCU State: On Current State:Off
18:05:17.024 SRC: Switch
18:05:17.030 MQT: stat/diffuseur_bureau/RESULT = {"POWER1":"ON"}
18:05:17.035 MQT: stat/diffuseur_bureau/POWER1 = ON
18:05:17.555 CFG: Saved to flash at F5, Count 23, Bytes 4096
18:05:21.181 TYA: Send "55aa00000000ff"
18:05:21.190 {"TuyaReceived":{"Data":"55AA010000010102","Cmnd":0,"CmndData":"01"}}
18:05:21.199 TYA: Heartbeat
18:05:21.588 {"TuyaReceived":{"Data":"55AA010700050C050001001E","Cmnd":7,"CmndData":"0C05000100","DpType5Id12":"0x00","12":{"DpId":12,"DpIdType":5,"DpIdData":"00"}}}
18:05:21.598 TYA: fnId=0 is set for dpId=12
18:05:21.602 {"TuyaReceived":{"Data":"55AA01070005670400010179","Cmnd":7,"CmndData":"6704000101","DpType4Id103":1,"103":{"DpId":103,"DpIdType":4,"DpIdData":"01"}}}
18:05:21.610 TYA: fnId=61 is set for dpId=103
18:05:21.613 SRC: Switch
18:05:21.616 CMD: Group 0, Index 1, Command "TUYAENUM", Data "1"
18:05:21.623 MQT: stat/diffuseur_bureau/RESULT = {"TuyaEnum1":1}
18:05:21.635 {"TuyaReceived":{"Data":"55AA01070005010100010110","Cmnd":7,"CmndData":"0101000101","DpType1Id1":1,"1":{"DpId":1,"DpIdType":1,"DpIdData":"01"}}}
18:05:21.646 TYA: fnId=11 is set for dpId=1
18:05:21.648 TYA: RX Relay-1 --> MCU State: On Current State:On
18:05:25.240 {"TuyaReceived":{"Data":"55AA0107000567040001027A","Cmnd":7,"CmndData":"6704000102","DpType4Id103":2,"103":{"DpId":103,"DpIdType":4,"DpIdData":"02"}}}
18:05:25.249 TYA: fnId=61 is set for dpId=103
18:05:25.252 SRC: Switch
18:05:25.255 CMD: Group 0, Index 1, Command "TUYAENUM", Data "2"
18:05:25.265 MQT: stat/diffuseur_bureau/RESULT = {"Command":"Error"}
18:05:25.277 {"TuyaReceived":{"Data":"55AA0107000501010001000F","Cmnd":7,"CmndData":"0101000100","DpType1Id1":0,"1":{"DpId":1,"DpIdType":1,"DpIdData":"00"}}}
18:05:25.287 TYA: fnId=11 is set for dpId=1
18:05:25.289 TYA: RX Relay-1 --> MCU State: Off Current State:On
18:05:25.292 SRC: Switch
18:05:25.298 MQT: stat/diffuseur_bureau/RESULT = {"POWER1":"OFF"}
18:05:25.303 MQT: stat/diffuseur_bureau/POWER1 = OFF
Du coup, quelqu’un saurait-il ce qu’il faudrait adapter exactement et coment SVP ? Je suis carrément perdu, comme d’hab quoi et si en plus quelqu’un arrive à me faire comprendre ça, ça serait un sacré exploit.
Je soupçone qu’il faut adapter un tuyaenum mais je préfère un avis éclairé.
