Voilà une façon de faire:
Ca utilise deux noeuds souvent intéressants. Trafic (en gros un feu vert/rouge) et trigger.
L’idée est que la Porte mette le feu « porte 1st » à vert et que le message envoyé par Hall traverse le trafic (feu vert). Le feu redevient rouge au bout de 5s (à ajuster suivant le besoin).
Et l’inverse pour l’autre capteur.
[{"id":"e2f4e474.eea198","type":"trigger-state","z":"d59703d6.87ebf","name":"Porte","server":"d28c9492.f419c8","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"binary_sensor.fenetre_buanderie","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"bool","comparatorValue":"true","propertyValue":"new_state.state"}],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":110,"y":3520,"wires":[["71d21899.7a25e8","dda9263d.99a1e8"],[]]},{"id":"f24d31b5.1f93f","type":"trigger-state","z":"d59703d6.87ebf","name":"Hall","server":"d28c9492.f419c8","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.oeil_salon_presence","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"bool","comparatorValue":"true","propertyValue":"new_state.state"}],"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":110,"y":3680,"wires":[["c2eb3c58.5f126","1155d85b.2daee8"],[]]},{"id":"1155d85b.2daee8","type":"traffic","z":"d59703d6.87ebf","name":"Porte 1st","property_allow":"payload","filter_allow":"On","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"Off","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":480,"y":3560,"wires":[["8926e1a.c23d62"]]},{"id":"71d21899.7a25e8","type":"trigger","z":"d59703d6.87ebf","name":"","op1":"On","op2":"Off","op1type":"str","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":300,"y":3520,"wires":[["1155d85b.2daee8"]]},{"id":"dda9263d.99a1e8","type":"traffic","z":"d59703d6.87ebf","name":"Hall 1st","property_allow":"payload","filter_allow":"On","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"Off","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":480,"y":3640,"wires":[["8af3b2df.8fc53"]]},{"id":"c2eb3c58.5f126","type":"trigger","z":"d59703d6.87ebf","name":"","op1":"On","op2":"Off","op1type":"str","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":300,"y":3680,"wires":[["dda9263d.99a1e8"]]},{"id":"8926e1a.c23d62","type":"debug","z":"d59703d6.87ebf","name":"Porte puis Hall","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":680,"y":3560,"wires":[]},{"id":"8af3b2df.8fc53","type":"debug","z":"d59703d6.87ebf","name":"Hall puis Porte","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":680,"y":3640,"wires":[]},{"id":"d28c9492.f419c8","type":"server","name":"hassio","legacy":false,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
