bonjour a tous,
J’ai deux yeelight parfaitement reconnues par l’integration Yeelight.
Après les avoir integrées à mon dashboard j’ai deux comportement étranges.
L’une d’elle est parfaitement pilotable, ON/OFF, changement de température et de couleur ok, reactif sur le dashboard. Mais a chaque action j’ai un message d’erreur qui apparait et le log donne
Logger: homeassistant.components.websocket_api.http.connection
Source: components/yeelight/light.py:265
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 13:19:48 (1 occurrences)
Last logged: 13:19:48
[281472031412032] Error when calling async_set_default for bulb Yeelight Color 0x7e10610 at 192.168.0.13: {'code': -5006, 'message': 'illegal request'}
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 245, in _async_wrap
return await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 704, in async_set_default
await self._bulb.async_set_default()
File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 38, in wrapper
cmd = await self.async_send_command(
File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 96, in async_send_command
raise BulbException(response["error"])
yeelight.main.BulbException: {'code': -5006, 'message': 'illegal request'}
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1808, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1845, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 686, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 961, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 726, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 572, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 802, in async_turn_on
await self.async_set_default()
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 265, in _async_wrap
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error when calling async_set_default for bulb Yeelight Color 0x7e10610 at 192.168.0.13: {'code': -5006, 'message': 'illegal request'}
Pour la deuxième,
On peut allumer et eteindre mais a chaque action elle apparait sur le dashboard en « indisponible » avec un point d’interogation; puis revient au bout de quelques secondes.
Meme comportement pour tout autre action, et surtout aucune réaction de l’ampoule.
le log :
Logger: homeassistant.core
First occurred: 13:29:57 (1 occurrences)
Last logged: 13:29:57
Error executing service: <ServiceCall light.turn_on (c:01GVWXHM9EKM1XHC8GYWDYQHFN): entity_id=['light.yeelight_color_0x7e3f01a'], params=>
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 456, in wait_for
return fut.result()
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 749, in async_start_music
reader, writer = await asyncio.wait_for(
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
return fut.result()
File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 759, in async_start_music
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 601, in _async_set_music_mode
await bulb.async_start_music()
File "/usr/local/lib/python3.10/site-packages/yeelight/aio.py", line 765, in async_start_music
yeelight.main.BulbException: Timed out enabling music mode on the bulb at 192.168.0.55:55443.
File "/usr/src/homeassistant/homeassistant/core.py", line 1826, in catch_exceptions
await coro_or_task
await coro
await result
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 791, in async_turn_on
await self.async_set_music_mode(True)
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 592, in async_set_music_mode
await self._async_set_music_mode(music_mode)
homeassistant.exceptions.HomeAssistantError: Error when calling _async_set_music_mode for bulb Yeelight Color 0x7e3f01a at 192.168.0.55: Timed out enabling music mode on the bulb at 192.168.0.55:55443.
J’en ai deux autres que je n’ai pas testées…
Merci pour vos lumières! (sans mauvais jeux de mots…)
version | core-2023.3.5 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.10 |
os_name | Linux |
os_version | 5.15.90 |
arch | aarch64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4976 |
Installed Version | 1.31.0 |
Stage | running |
Available Repositories | 1313 |
Downloaded Repositories | 9 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 9.5 |
update_channel | stable |
supervisor_version | supervisor-2023.03.1 |
agent_version | 1.4.1 |
docker_version | 20.10.22 |
disk_total | 27.9 GB |
disk_used | 5.6 GB |
healthy | true |
supported | true |
board | odroid-n2 |
supervisor_api | ok |
version_api | ok |
installed_addons | Terminal & SSH (9.6.1), File editor (5.5.0), TasmoAdmin (0.23.0), Studio Code Server (5.5.4), Mosquitto broker (6.1.3), Node-RED (14.0.4), InfluxDB (4.5.0) |
dashboards | 2 |
resources | 3 |
views | 2 |
mode | storage |
oldest_recorder_run | 12 mars 2023 à 10:24 |
current_recorder_run | 18 mars 2023 à 14:58 |
estimated_db_size | 182.30 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
Sonoff
version | 3.4.0 (5406fa7) |
cloud_online | 0 / 2 |
local_online | 2 / 2 |
