Erreur nodered au démarrage
Mon nodered ne démarre plus. Il me donne des erreurs, j’ai cherché, mais ne comprends pas d’où cela peut venir.
Si vous pouviez m’aiguiller svp
Merci d’avance
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.0.0
You are running the latest version of this add-on.
System: Home Assistant OS 9.4 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.12.7
Home Assistant Supervisor: 2022.11.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
[10:34:30] INFO: Starting installation of custom NPM/Node-RED packages…
s6-rc: info: service init-nginx successfully started
npm WARN config optional Use --omit=optional to exclude optional dependencies, or
npm WARN config --include=optional to include them.
npm WARN config
npm WARN config Default value does install optional deps unless otherwise omitted.
npm WARN config only Use --omit=dev to omit dev dependencies from the install.
npm ERR! code 1
npm ERR! path /opt/node_modules/@serialport/bindings
npm ERR! command failed
npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! prebuild-install warn install No prebuilt binaries found (target=18.12.1 runtime=node arch=arm64 libc=musl platform=linux)
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.3.0
npm ERR! gyp info using node@18.12.1 | linux | arm64
npm ERR! gyp ERR! find Python
npm ERR! gyp ERR! find Python checking Python explicitly set from command line or npm configuration
npm ERR! gyp ERR! find Python - « –python= » or « npm config get python » is « /usr/bin/python3 »
npm ERR! gyp ERR! find Python - « /usr/bin/python3 » is not in PATH or produced an error
npm ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
npm ERR! gyp ERR! find Python checking if « python3 » can be used
npm ERR! gyp ERR! find Python - « python3 » is not in PATH or produced an error
npm ERR! gyp ERR! find Python checking if « python » can be used
npm ERR! gyp ERR! find Python - « python » is not in PATH or produced an error
npm ERR! gyp ERR! find Python **********************************************************
npm ERR! gyp ERR! find Python You need to install the latest version of Python.
npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
npm ERR! gyp ERR! find Python you can try one of the following options:
npm ERR! gyp ERR! find Python - Use the switch --python=« /path/to/pythonexecutable »
npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)
npm ERR! gyp ERR! find Python - Set the environment variable PYTHON
npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
npm ERR! gyp ERR! find Python npm config set python « /path/to/pythonexecutable »
npm ERR! gyp ERR! find Python For more information consult the documentation at:
npm ERR! gyp ERR! find Python GitHub - nodejs/node-gyp: Node.js native addon build tool
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Could not find any Python installation to use
npm ERR! gyp ERR! stack at PythonFinder.fail (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:330:47)
npm ERR! gyp ERR! stack at PythonFinder.runChecks (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:159:21)
npm ERR! gyp ERR! stack at PythonFinder. (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:202:16)
npm ERR! gyp ERR! stack at PythonFinder.execFileCallback (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:294:16)
npm ERR! gyp ERR! stack at exithandler (node:child_process:420:5)
npm ERR! gyp ERR! stack at ChildProcess.errorhandler (node:child_process:432:5)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:289:12)
npm ERR! gyp ERR! stack at onErrorNT (node:internal/child_process:476:16)
npm ERR! gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
npm ERR! gyp ERR! System Linux 5.15.76-v8
npm ERR! gyp ERR! command « /usr/bin/node » « /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js » « rebuild »
npm ERR! gyp ERR! cwd /opt/node_modules/@serialport/bindings
npm ERR! gyp ERR! node -v v18.12.1
npm ERR! gyp ERR! node-gyp -v v9.3.0
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-12-18T09_34_33_062Z-debug-0.log
[10:34:47] FATAL: Failed to install a specified npm package
s6-rc: warning: unable to start service init-customizations: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
prog: fatal: stopping the container.
s6-rc: info: service init-nginx: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
quel est le contexte?
Ces erreur sont-elles apparues juste comme ça? Après la MaJ à la v14.0.0 ?
Ou alors la V14 tournait et c’est venu après un plantage de NR?
Écoutes, honnêtement je l’avais pas remarqué de suite…
Mais je pense que c’est suite à une mise à jour…
Ma version de python est 3.10.9 pour info
