Erreur Z2M
Erreur démarrage Z2M
Assez fréquemment, je dois redémarrer mon mini pc car l’addon Z2M ne veut plus démarrer.
J’ai un dongle sonoff 3.0 USB Dongle Plus branché sur un port usb2, avec une rallonge.
Il est flashé en version 7.4 sachant que j’ai essayé les 2 autres firmwares.
Mon journal:
[10:47:46] INFO: Preparing to start...
[10:47:46] INFO: Socat not enabled
[10:47:47] INFO: Starting Zigbee2MQTT...
[2026-02-06 10:47:48] info: 	z2m: Logging to console, file (filename: log.log)
[2026-02-06 10:47:48] info: 	z2m: Starting Zigbee2MQTT version 2.6.3 (commit #unknown)
[2026-02-06 10:47:48] info: 	z2m: Starting zigbee-herdsman (6.3.2)
[2026-02-06 10:47:48] info: 	zh:ember: Using default stack config.
[2026-02-06 10:47:48] info: 	zh:ember: ======== Ember Adapter Starting ========
[2026-02-06 10:47:48] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2026-02-06 10:47:48] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 10:47:48] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-02-06 10:47:48] info: 	zh:ember:uart:ash: Serial port opened
[2026-02-06 10:47:48] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 10:47:53] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 10:47:53] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 10:47:58] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 10:47:58] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 10:48:03] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 10:48:03] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 10:48:08] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 10:48:08] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 10:48:13] error: 	z2m: Error while starting zigbee-herdsman
[2026-02-06 10:48:13] error: 	z2m: Failed to start zigbee-herdsman
[2026-02-06 10:48:13] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-02-06 10:48:13] error: 	z2m: Exiting...
[2026-02-06 10:48:13] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:665:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1547:24)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/app/lib/zigbee.ts:67:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5)
version core-2026.1.1
container_arch amd64
python_version 3.13.11
os_version 6.12.51-haos
arch x86_64
Installed Version 2.0.5
Available Repositories 2695
Downloaded Repositories 51
supervisor_version supervisor-2026.01.1
agent_version 1.7.2
docker_version 28.3.3
disk_total 30.8 GB
disk_used 12.6 GB
nameservers 192.168.50.1
virtualization kvm
board ova
installed_addons Samba Backup (5.2.0), ESPHome Device Builder (2025.10.5), Duck DNS (1.26.0), File editor (5.8.0), Terminal & SSH (9.22.0), InfluxDB (5.0.2), Mosquitto broker (6.5.2), Zigbee2MQTT (2.6.3-1), Z-Wave JS UI (6.0.0), Grafana (11.0.0), Linky (1.7.0), go2rtc (1.9.14), Frigate Proxy (1.6), Music Assistant (2.7.6), SONOFF Dongle Flasher (1.2.3)
dashboards 3
resources 32
views 13
Network Configuration
adapters lo (disabled), enp0s18 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth23f86f9 (disabled), veth0425a44 (disabled), veth97e224c (disabled), veth1f171ce (disabled), vethb1b304d (disabled), vethb7e81e6 (disabled), vethf431a9b (disabled), veth6459f60 (disabled), vethcd96542 (disabled), veth76d298d (disabled), vethec2ac14 (disabled), veth1f7c573 (disabled), veth316cd96 (disabled), veth27c1f35 (disabled), veth4cf4e37 (disabled), vetha275b8d (disabled), vethf36b672 (disabled)
ipv4_addresses lo (127.0.0.1/8), enp0s18 (192.168.50.201/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth23f86f9 (), veth0425a44 (), veth97e224c (), veth1f171ce (), vethb1b304d (), vethb7e81e6 (), vethf431a9b (), veth6459f60 (), vethcd96542 (), veth76d298d (), vethec2ac14 (), veth1f7c573 (), veth316cd96 (), veth27c1f35 (), veth4cf4e37 (), vetha275b8d (), vethf36b672 ()
ipv6_addresses lo (::1/128), enp0s18 (fe80::7af9:2f36:46f0:3040/64), hassio (fe80::e0c4:9cff:fe5e:e19e/64), docker0 (fe80::2c7e:dff:fee8:571f/64), veth23f86f9 (fe80::eca6:cfff:fe8f:1dc/64), veth0425a44 (fe80::e4d1:e3ff:fe79:8cc3/64), veth97e224c (fe80::3863:5dff:fe18:d97f/64), veth1f171ce (fe80::1851:beff:fe79:deff/64), vethb1b304d (fe80::7807:f3ff:fe1d:27be/64), vethb7e81e6 (fe80::b815:adff:fe21:a616/64), vethf431a9b (fe80::2c72:c9ff:fe0e:7784/64), veth6459f60 (fe80::48f8:beff:fe64:7b16/64), vethcd96542 (fe80::b067:86ff:fe22:91df/64), veth76d298d (fe80::78f0:c3ff:fe21:8143/64), vethec2ac14 (fe80::8ca8:b6ff:fe38:3f0f/64), veth1f7c573 (fe80::cc0f:7fff:fe21:212a/64), veth316cd96 (fe80::3031:88ff:fefe:5a76/64), veth27c1f35 (fe80::e8fd:46ff:feab:d5a5/64), veth4cf4e37 (fe80::805f:a1ff:fe87:ab5a/64), vetha275b8d (fe80::50e4:48ff:fed7:a146/64), vethf36b672 (fe80::c452:2aff:fe92:c9a4/64)
announce_addresses 192.168.50.201, fe80::7af9:2f36:46f0:3040
oldest_recorder_run 24 janvier 2026 à 18:50
current_recorder_run 5 février 2026 à 12:06
estimated_db_size 425.69 MiB
database_version 3.49.2
regarde ce post, as tu verifier tout ces points ?
la Sonoff E, est en firmware 8.0.2, le 7.4 est un peu ancien. Tu peux utiliser le web flasher :
https://dongle.sonoff.tech/sonoff-dongle-flasher/
il faudrais aussi montrer ta configuration de Z2M.
Hello. Pour être certain, tu as quel modèle exactement ?
« ZBDongle-P » ou un « ZBDongle-E »? auquel cas tu devrais rentrer zstack au lieu de ember.
vu le message c’est une Sonoff E. La P n’as pas cette version de firmware.
Merci pour vos réponse.
Oui c’est la E.
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt: {}
serial:
  port: >-
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221031105652-if00
  adapter: ember
  baudrate: 115200
  rtscts: false
J’ai lu le sujet que tu as relayé @WarC0zes et vérifier ces points, avant de publier ce sujet, j’avais déjà regardé.
Tu devrais essayer avec rtscts: true :wink:
Même chose, je vais devoir redémarrer mon mini pc.
Ca fonctionne à nouveau jusqu’au prochain plantage.
Pour moi c’était simplement le rtscts qui était en cause dans ta configuration.
C’est comme un « watchdog » matériel. Ca permet d’éviter ce qu’il t’arrivait quand on regarde tes logs: ça faisait une boucle ASH reset.
RTS = Request To Send
CTS = Clear To Send
Comme il était coupé dans tes réglages, il essayait de manière logicielle et fail…
D’accord, merci pour tes explications, en espérant que tu es raison.
Merci pour vos disponibilités.
je me demande si tu n’as pas un soucis d’alimentation sur ton port USB pour que ça se comporte de la sorte .?
C’est un Dell Optiplex 3050. Tu penses que si je change de port, ça va changer quelque chose?
aucune idée c’est juste un « ressenti »
mais ça ne coute rien d’essayer
c’est sur false pour la Sonoff E :
Bonjour, en 2 jours de temps, à nouveau mon problème.
Je vais changer de port USB et je vous tiens au courant.
