Bonjour à tous, voila qu’aujourd’hui j 'essaye d’installer mon modul NODON SIN-4-2-20, acheté il y a quelque temps déjà. Et comme je m’y attendais je n’y suis pas arrivé .
J’ai installé également un dongle Sonoff 3.0 zigbee2mqtt, flashé avec le dernier firmware.
J’arrive à accéder à la page web de zigbee, je clique sur appairage et la message d’erreur suivant :
Info 2022-07-11 18:10:32Zigbee: allowing new devices to join.
Error 2022-07-11 18:10:32Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'SREQ '--> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')'
Info 2022-07-11 18:10:32MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"SREQ '--> ZDO - mgmtPermitJoinReq - {\"addrmode\":15,\"dstaddr\":65532,\"duration\":254,\"tcsignificance\":0}' failed with status '(0xc2: NWK_INVALID_REQUEST)' (expected '(0x00: SUCCESS)')","status":"error","transaction":"2gll8-1"}'
je joins également ma config zigbee récupéré sur je ne sait plus quel discussion forum :
data_path: /config/zigbee2mqtt
socat: null
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: ‹ -d -d ›
log: false
permit_join: true
mqtt:
user: mqtt-user
password: user
keepalive: 60
reject_unauthorized: true
version: 4
base_topic: zigbee2mqtt
server: mqtt://192.168.73.:1883
user: mqtt-user
password: mqtt
serial:
port: /dev/ttyUSB0
adapter: zstack
frontend:
port: 8099
homeassistant:
legacy_entity_attributes: true
legacy_triggers: true
je suis ensuite allé voir ce qu’il ce passe du coté de MQTT et voici le journal :
1657553047: New connection from 172.30.32.2:44320 on port 1883.
1657553047: Client <unknown> closed its connection.
1657553167: New connection from 172.30.32.2:44322 on port 1883.
1657553167: Client <unknown> closed its connection.
1657553287: New connection from 172.30.32.2:44324 on port 1883.
1657553287: Client <unknown> closed its connection.
1657553407: New connection from 172.30.32.2:44326 on port 1883.
1657553407: Client <unknown> closed its connection.
1657553527: New connection from 172.30.32.2:44328 on port 1883.
1657553527: Client <unknown> closed its connection.
1657553647: New connection from 172.30.32.2:44330 on port 1883.
1657553647: Client <unknown> closed its connection.
1657553767: New connection from 172.30.32.2:44332 on port 1883.
1657553767: Client <unknown> closed its connection.
1657553887: New connection from 172.30.32.2:44334 on port 1883.
1657553887: Client <unknown> closed its connection.
1657553905: Client 2iBlAIP1AxF1n5a4A2gUNG closed its connection.
1657553993: New connection from 172.30.32.1:54001 on port 1883.
1657553993: New client connected from 172.30.32.1:54001 as 7IImquWOQ1dKisMv6P0wSk (p2, c1, k60, u'mqtt-user').
1657554007: New connection from 172.30.32.2:44336 on port 1883.
1657554007: Client <unknown> closed its connection.
1657554127: New connection from 172.30.32.2:44338 on port 1883.
1657554127: Client <unknown> closed its connection.
1657554247: New connection from 172.30.32.2:44340 on port 1883.
Voila, je suis un peu deconcerté, je cherche dans tous les coins, mais je ne sait plus ou regarder, si quelqu’un a une petite idée ??
merci beaucoup:
System Health
version |
core-2022.7.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.5 |
os_name |
Linux |
os_version |
5.15.32-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4964 |
Installed Version |
1.25.5 |
Stage |
running |
Available Repositories |
1071 |
Downloaded Repositories |
1 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 8.2 |
update_channel |
stable |
supervisor_version |
supervisor-2022.07.0 |
agent_version |
1.2.1 |
docker_version |
20.10.14 |
disk_total |
6.7 GB |
disk_used |
4.1 GB |
healthy |
true |
supported |
true |
board |
rpi3-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
File editor (5.3.3), Duck DNS (1.15.0), Samba share (10.0.0), Zigbee2MQTT (1.26.0-1), Mosquitto broker (6.1.2) |
dashboards |
1 |
resources |
0 |
views |
4 |
mode |
storage |
oldest_recorder_run |
5 juillet 2022 à 20:18 |
current_recorder_run |
11 juillet 2022 à 17:39 |
estimated_db_size |
16.98 MiB |
database_engine |
sqlite |
database_version |
3.38.5 |
