Esphome ajout esp32 erreur
Bonjour je m’arrache les cheveux depuis hier, j’ai acheté un esp32-vroom-32 je veux l’ajouter à esphome mais impossible de compiler et de l’installer.
Le fichier yaml et Résultat de l’erreur ci-dessous
Merci de votre aide
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "W+QyabKKvQ+SWsIRDnc33wA6XwhabIujHaEh6LCvP10="
ota:
  password: "e20fa74e09061a50ddff6c6d5c85cd17"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Bncvhjvhhj Fallback Hotspot"
    password: "W3XxS8KRhjIZ"
captive_portal:
INFO Reading configuration /config/esphome/bncvhjvhhj.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing bncvhjvhhj (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
Library Manager: Installing Hash
INFO Installing Hash
Library Manager: Installing ESP8266WiFi
INFO Installing ESP8266WiFi
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 1.0
|-- FS @ 1.0
|-- Update @ 1.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 1.1.0
|-- ESPmDNS @ 1.0
|-- noise-c @ 0.1.4
|   |-- libsodium @ 1.10018.1
Compiling /data/bncvhjvhhj/.pioenvs/bncvhjvhhj/src/esphome/components/api/api_connection.cpp.o
Compiling /data/bncvhjvhhj/.pioenvs/bncvhjvhhj/src/esphome/components/api/api_server.cpp.o
Compiling /data/bncvhjvhhj/.pioenvs/bncvhjvhhj/src/esphome/components/api/list_entities.cpp.o
Compiling /data/bncvhjvhhj/.pioenvs/bncvhjvhhj/src/esphome/components/api/proto.cpp.o
xtensa-esp32-elf-g++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
*** [/data/bncvhjvhhj/.pioenvs/bncvhjvhhj/src/esphome/components/api/list_entities.cpp.o] Error 4
version core-2022.11.1
python_version 3.10.7
os_version 5.15.61-v8
Installed Version 1.28.3
Available Repositories 1135
Downloaded Repositories 7
logged_in true
subscription_expiration 10 octobre 2023 à 02:00
relayer_connected true
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled false
remote_server eu-central-1-3.ui.nabu.casa
host_os Home Assistant OS 9.3
supervisor_version supervisor-2022.10.2
agent_version 1.4.1
docker_version 20.10.18
disk_total 57.8 GB
disk_used 7.4 GB
board rpi3-64
installed_addons Mosquitto broker (6.1.3), Samba share (10.0.0), Terminal & SSH (9.6.1), Node-RED (13.5.1), Samba Backup (5.2.0), File editor (5.4.1), ESPHome (2022.10.2)
dashboards 2
resources 4
views 6
oldest_recorder_run 26 octobre 2022 à 12:14
current_recorder_run 4 novembre 2022 à 15:20
estimated_db_size 104.26 MiB
database_version 3.38.5
Tu es certain de ce paramétre ? Parce que ton code ne contient rien de spécifique au format arduino
EDIT
D’ailleurs
C’est normal que j’ai pas l’onglet « compil »
Bonsoir @denisv
Je ne l’ai pas non plus et tout fonctionne.
J’ai bien aussi ceci:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
Mais tu as quoi après :
captive_portal:
Tu as quoi comme capteur sur cet ESP32 ?
Bob
Bonjour, après captive_portal: rien , sur le esp32 j’ai un capteur de température dht22
Bonsoir, je fournis un exemple d’un de mes codes.
Obligé de fixer les IP sinon ca ne fonctionner pas pour ma part.
esphome:
esp32:
  board: esp32dev
# Enable logging
logger:
api:
ota:
  password: "7f0ae868b0fd199366cee7cfe7a0f21c"
wifi:
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: 192.168.1.64
    # Set this to the IP address of the router. Often ends with .1
    gateway: 192.168.1.1
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
  ap:
    ssid: "Ble-Tracker Fallback Hotspot"
    password: "p7PkXENZfllV"
captive_portal:
esp32_ble_tracker:
  - platform: xiaomi_hhccjcy01
    mac_address: C4:7C:8D:6E:1F:64
    temperature:
      name: "Xiaomi MiFlora Temperature Ficus"
    moisture:
      name: "Xiaomi MiFlora Moisture Ficus"
    illuminance:
      name: "Xiaomi MiFlora Illuminance Ficus"
    conductivity:
      name: "Xiaomi MiFlora Soil Conductivity Ficus"
    battery_level:
      name: "Xiaomi MiFlora Battery Level Ficus"
    mac_address: C4:7C:8D:6D:C6:FB
    temperature:
      name: "Xiaomi Fraises Temperature"
    moisture:
      name: "Xiaomi Fraises Moisture"
    illuminance:
      name: "Xiaomi Fraises Illuminance"
    conductivity:
      name: "Xiaomi Fraises Soil Conductivity"
    battery_level:
      name: "Xiaomi Fraises Battery Level"
button:
  - platform: restart
Te faut ce code après captive portal donc.
https://esphome.io/components/sensor/dht.html
toujours pareil et voici ce que j’ai qunad je fait upload all
Updating /config/esphome/cgghcvhh.yaml
INFO Reading configuration /config/esphome/cgghcvhh.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing cgghcvhh (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Dependency Graph
|-- WiFi @ 1.0
|-- FS @ 1.0
|-- Update @ 1.0
|-- ESPmDNS @ 1.0
|-- noise-c @ 0.1.4
Compiling /data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/api_connection.cpp.o
Compiling /data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/api_server.cpp.o
Compiling /data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/list_entities.cpp.o
See http://gcc.gnu.org/bugs.html for instructions.
*** [/data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/api_pb2.cpp.o] Error 4
*** [/data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/list_entities.cpp.o] Error 4
*** [/data/cgghcvhh/.pioenvs/cgghcvhh/src/esphome/components/api/api_connection.cpp.o] Error 4
========================= [FAILED] Took 41.26 seconds =========================
========== [ERROR] /config/esphome/cgghcvhh.yaml ==========
======================== [SUMMARY] ========================
  • /config/esphome/cgghcvhh.yaml: FAILED
C’est quelle version de esphome installée sur ton instance Ha ? Car ce n’ai pas normal…
Bonjour et merci voici ma version de
ESPHome
Current version: 2022.10.2
de plus il reste offline
En cliquant sur les trois petits points, un « validate » est bien OK ?
Ton esp32 est connecté sur ton ordinateur ou en wifi, si oui le vois-tu sur ton interface de Box ?
J’en ai reçu un défectueux sur lequel la wifi ne fonctionnait pas, sinon en connexion sur ordi attention, certains câbles ne sont adaptés que pour la charge.
Bob
Oui le validate est bien ok, oui mon ESP32 est connecté à mon pc. Vu que je ne peux pas installer la la config je ne peux pas le voir sur ma box ??
le cable est bon j’ai mis une config sur ide arduino et je remonte bien les températures
Il y a quelques jours il y a eu un message sur le forum (que je ne retrouve pas) et il me semble bien qu’il avait le même message d’erreur. Si je me souviens bien c’était lié à un manque de ressources sur la machine de compilation et c’était une RPi3, comme toi visiblement.
Il a dû installer esphome sur son PC pour compiler…
@AlexHass tu as raison, c’était sur cette discussion :
Et dans ce topic @Barnouille a dû compiler depuis une machine plus puissante que celle qui remontait ce message d’erreur.
Bonjour et bon dimanche à tous,
Merci pour votre aide, alors c’etait bien ça j’ai compilé sur mon pc et tout fonctionne merci encore à tous.
Pour remédier à tout ça il faut que je passe sur un raspberry pi4 ??
Je voulais au départ l’installer sur ma freebox delta mais ma clé SONOFF zigbee n’est pas reconnu !!
Denisv
