Esphome home assistant code Yaml ne veut plus s'integrer après version 2023.12.9
Le code de mon thermostat fonctionne bien mais il n’accepte plus la mise à jour des version esphome depuis la version 2023.12.9. quelqu’un peut m’aider? Il m’indique maintenant (sans que j’ai rien changé) qu’il ya une erreur pour cette ligne :
sensor: internal_temperature
et ces lignes :
lambda: |-
      if (id(fire).state) {id(ani_fire).next_frame(); it.image(0, 0, id(ani_fire));}
      else if (id(cool).state) {id(ani_fan).next_frame(); it.image(0, 0, id(ani_fan));}
      else {it.image(0, 0, id(home_thermometer));}
      it.print(64, 0,  id(font1), TextAlign::TOP_CENTER, "${room}");
      it.printf(128, 0,  id(font4), TextAlign::TOP_RIGHT, " %.1f%% ", id(internal_humidity).state);
      it.printf(64, 4, id(font2), TextAlign::TOP_CENTER, " %.1f°", id(internal_temperature).state);
      it.printf(0, 64, id(font3), TextAlign::BASELINE_LEFT, "L:%.1f°", id(this_thermostat).target_temperature_low);
      it.printf(128, 64, id(font3), TextAlign::BASELINE_RIGHT, "H:%.1f°", id(this_thermostat).target_temperature_high);
      if (id(brightness).state) {it.image(56, 51, id(bulb));}
      else if (id(heat_cool).state) {it.image(56, 51, id(arrow_right));}
      else {it.image(56, 51, id(arrow_left));}
animation:`
mon code entier :
esphome:
  friendly_name: D1minithermostat1
  platform: esp8266
  board: d1_mini
  on_boot:
    priority: -100.0
    then:
      - lambda: "id(oled_contrast).publish_state(0.4);"
substitutions:
  room: JX # Room Name
  entity_heater: input_boolean.tut_thermo_fire    ### Change for your 'Heating' Entity
  entity_cooler: input_boolean.tut_thermo_cool    ### Change for your 'Cooling' Entity
  default_low: "20"
  default_hi: "25"
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "D1Minithermostat1"
    password: "xxxxxxxxxxxx"
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
  # id: bus_a
  frequency: 400kHz
captive_portal:
switch:
    optimistic: true
  - platform: gpio
    pin: GPIO16
    # inverted: true
  - platform: gpio
    pin: GPIO14
    # inverted: true
    optimistic: true
# Déclaration d'une variable globale
globals:
  - id: on_off
    type: int
    restore_value: yes
    initial_value: '1'
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO2
      inverted: true
    on_press:
      then:
        - switch.toggle: heat_cool
        - lambda: |-
            if (id(on_off) == 0) {
              id(oled1).turn_on();
              id(on_off) = 1;
            else {
              id(oled1).turn_off();
              id(on_off) = 0;
    on_click:
      - min_length: 1000ms
        max_length: 20000ms
        then:
          - switch.toggle: brightness
climate:
  - platform: thermostat
    min_cooling_off_time: 0s
    min_cooling_run_time: 0s
    min_heating_off_time: 0s
    min_heating_run_time: 0s
    min_idle_time: 0s
    visual:
      min_temperature: 15 °C
      max_temperature: 30 °C
    name: "${room} Thermostat"
### Updated for ESPHome v2022.10.0 Onwards
    default_preset: Home                      ### NEW! Use this to set Preset
    # on_boot_restore_from: memory            ### Use this to "Restore From Memeory" (A Saved State) OR...
    on_boot_restore_from: default_preset      ### Use this to set Preset to start on every Boot
    preset:
      - name: Home
        default_target_temperature_low: $default_low
        default_target_temperature_high: $default_hi
        mode: AUTO
    cool_action:
      - switch.turn_on: relay_cooler
      - lambda: id(cool).publish_state(true);
      - homeassistant.service:
          service: homeassistant.turn_on
            entity_id: $entity_cooler
    heat_action:
      - switch.turn_on: relay_heater
      - lambda: id(fire).publish_state(true);
            entity_id: $entity_heater
    idle_action:
      - switch.turn_off: relay_cooler
      - switch.turn_off: relay_heater
      - lambda: id(cool).publish_state(false);
      - lambda: id(fire).publish_state(false);
          service: homeassistant.turn_off
  - platform: uptime
  - platform: bme280_i2c
    temperature:
      name: "BME280 Temperature"
      oversampling: 16x
    pressure:
      name: "BME280 Pressure"
    humidity:
      name: "BME280 Humidity"
    address: 0x77
    update_interval: 15s
  - platform: rotary_encoder
    pin_a:
      number: GPIO12
      mode: INPUT_PULLUP
    pin_b:
      number: GPIO13
      mode: INPUT_PULLUP
    on_clockwise:
      - if:
          condition:
            switch.is_on: brightness
          then:
            - sensor.template.publish:
                state: !lambda "return id(oled_contrast).state + 0.02;"
            - lambda: |-
                id(oled1).set_contrast( id(oled_contrast).state );
          else:
            - if:
                condition:
                  switch.is_on: heat_cool
                then:
                  - climate.control:
                      target_temperature_high: !lambda "return id(this_thermostat).target_temperature_high + 0.5;"
                else:
                  - climate.control:
                      target_temperature_low: !lambda "return id(this_thermostat).target_temperature_low + 0.5;"
    on_anticlockwise:
      then:
        - if:
            condition:
            then:
                  state: !lambda "return id(oled_contrast).state - 0.02;"
              - lambda: |-
                  id(oled1).set_contrast( id(oled_contrast).state);
            else:
              - if:
                  condition:
                  then:
                    - climate.control:
                        target_temperature_high: !lambda "return id(this_thermostat).target_temperature_high - 0.5;"
                  else:
                    - climate.control:
                        target_temperature_low: !lambda "return id(this_thermostat).target_temperature_low - 0.5;"
display:
  - platform: ssd1306_i2c
    update_interval: 1.0s
    contrast: 0.4
    model: "SSD1306 128x64"
    rotation: 180
    address: 0x3C
    lambda: |-
animation:
  - file: 'fan.gif'
  - file: 'fire.gif'
image:
  - file: 'home-thermometer.png'
  - file: 'arrow-left-circle-outline.png'
  - file: 'arrow-right-circle-outline.png'
  - file: 'lightbulb-on-outline.png'
font:
  - file: 'nasalization.ttf'
  - file: 'refsan.ttf'
Bonjour @morinxav,
un bonjour ne fais pas de mal, un oubli arrive, mais fais attention les prochaines fois quand tu créer un sujet.
Partage l’erreur que tu obtiens, ca donne un indice.
Parce que la, ca aide pas:
Excuse moi, j’avais tellement de mal a mettre mon code en code dans le forum que j’en ai oublié de dire bonjour!
mais ce n’est absolument pas mon habitude.
par contre ce sont des erreurs de syntaxes. Mais qui fonctionnaient avant… Les nouvelle version de ESPHOME n’accepte plus cette syntaxe mais je ne sais pas par quoi la remplacer.
ceci dit ça fonctionne très bien sans mise à jour, mais bon ça fait désordre et si je veux en refaire un…
Cordialement
internal_temperature c’est pas censé être un ID? Tu y fait référence 2fois mais il n’est pas défini
Bonsoir,
Merci pour ta reponse, je comprends ta reponse mais malheureusement pas assez compétant pour savoir par quoi ou comment rectifier le problème. Tu pourrais m’aiguiller plus?
pour info, je ne sais pas non plus comment dessiner le schèma car je trouve que mon thermostat vaut bien ceux à plusieurs centaines d’euros et je veux bien le partager mais je ne sais pas comment.(gestion manuelle ventillateur ou chaufage avec afficheur et automatisation par home assistant inspiré de : Home Assistant and ESPHome Digital OLED Thermostat v3)
Cordialement
je ne pense pas que ce soit lié à la partie fonctionnement physique de ton thermostat
Moi je corrigerai ces lignes pour voir :
  - platform: uptime
    temperature:
      oversampling: 16x
    pressure:
    humidity:
      address: 0x77
Regarde bien les différence (texte et espaces)
@Pulpy-Luke a raison, le * sensor est pour utiliser une source de température externe , donc ton bme280 a ce que vois dans le code.
Faut utiliser un ID, dans senor:. Faut créer un id pour ton capteur de température et l’utiliser dans sensor: du climate. le id: est au même niveau que name:
j’utilise un SHT30. Exemple pour l’indexion avec un ID.
  - platform: sht3xd
    i2c_id: i2c_external
    temperature:
      filters:
        - offset: -1.4
    humidity:
      filters:
        - offset: 6.0
    address: 0x44
    update_interval: 60s
  - platform: qmp6988
    pressure:
      filters:
        - offset: 7.2
    address: 0x70
    iir_filter: 2x
C’est d’ailleurs écrit dans ce sens sur le git d’origine (vieux de 2 ans)
Comment ça fonctionner, vu qu’il avais pas de ID ??? :shushing_face:
Je suis d’accord, c’est du code qui compile pas … La seule explication, l’absence de mise à jour de l’esp depuis un moment… c’est en plus cohérent avec la date de l’ancienne version 2023.12.9
rien ne s’affiche, vu que internal_temperature est pas un ID
La OK, ca affichera bien la température:
    temperature:
      oversampling: 16x
oui, j’ai vu aussi, d’où la correction des 2 id d’un coup
merci à tous les deux. je regarde ça dès que possible et vous ferais un retour.
il faut que je prenne un nouveau d1 mini, sinon je vais perdre le seul qui fonctionne…
mais, je vous affirme que j’ai sous les yeux le thermostat qui fonctionne. Est-ce que j’ai un moyen d’extraire le code de mon D1 mini, pour savoir si entre temps j’aurais modifié quelque chose?
Je sais qu’a l’époque, j’avais passé enormement de temp pour arriver a faire une fonction qui eteigne juste l’ecran et le rallume en appuyant sur le switch du codeur tout en continuant à fonctionner.
Cordialement
Je n’ai pas connaissance d’un moyen d’extraite la config actuelle. En plus c’est du compilé donc c’est même pas toujours utilisable facilement sur un autre appareil (ip, gpio etc)
