Ça donne ceci.
2022-10-06 19:37:03,696 INFO 200 GET / (0.0.0.0) 2.56ms
2022-10-06 19:37:03,733 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (0.0.0.0) 3.74ms
2022-10-06 19:37:03,749 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2?hash=570eb838 (0.0.0.0) 2.68ms
2022-10-06 19:37:03,766 INFO 200 GET /static/css/vendor/materialize/materialize.min.css?hash=ec1df3ba (0.0.0.0) 3.01ms
2022-10-06 19:37:03,773 INFO 200 GET /static/css/esphome-2.css?hash=615a3cb4 (0.0.0.0) 4.77ms
2022-10-06 19:37:03,781 INFO 200 GET /static/js/esphome/index-0718df31.js (0.0.0.0) 10.69ms
2022-10-06 19:37:03,857 INFO 304 GET /devices (0.0.0.0) 2.65ms
2022-10-06 19:37:03,880 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2 (0.0.0.0) 3.21ms
2022-10-06 19:37:03,906 INFO 200 GET /static/js/esphome/c.8f72d879.js (0.0.0.0) 45.11ms
2022-10-06 19:37:04,694 INFO 200 GET /static/js/esphome/c.cefb4322.js (0.0.0.0) 3.40ms
2022-10-06 19:37:04,700 INFO 200 GET /static/js/esphome/c.644c7642.js (0.0.0.0) 2.92ms
2022-10-06 19:37:43,611 INFO 304 GET / (0.0.0.0) 2.20ms
2022-10-06 19:37:43,675 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (0.0.0.0) 3.13ms
2022-10-06 19:37:43,690 INFO 200 GET /static/css/esphome-2.css?hash=615a3cb4 (0.0.0.0) 2.43ms
2022-10-06 19:37:43,704 INFO 200 GET /static/js/esphome/index-0718df31.js (0.0.0.0) 3.44ms
2022-10-06 19:37:43,712 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2?hash=570eb838 (0.0.0.0) 4.58ms
2022-10-06 19:37:43,716 INFO 200 GET /static/css/vendor/materialize/materialize.min.css?hash=ec1df3ba (0.0.0.0) 7.33ms
2022-10-06 19:37:43,816 INFO 304 GET /devices (0.0.0.0) 4.04ms
2022-10-06 19:37:43,830 INFO 200 GET /static/js/esphome/c.8f72d879.js (0.0.0.0) 38.79ms
2022-10-06 19:37:43,836 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2 (0.0.0.0) 3.15ms
2022-10-06 19:37:44,137 INFO 200 GET /static/js/esphome/c.cefb4322.js (0.0.0.0) 3.56ms
2022-10-06 19:37:44,145 INFO 200 GET /static/js/esphome/c.644c7642.js (0.0.0.0) 3.02ms
2022-10-06 19:37:44,858 INFO 200 GET /static/js/esphome/c.ee05ac6e.js (0.0.0.0) 2.36ms
2022-10-06 19:37:44,892 INFO 200 GET /static/js/esphome/c.39d4a8b9.js (0.0.0.0) 3.50ms
2022-10-06 19:37:44,909 INFO 200 GET /static/js/esphome/c.f4500ca6.js (0.0.0.0) 3.28ms
2022-10-06 19:37:44,920 INFO 200 GET /static/js/esphome/c.1b7fdd9b.js (0.0.0.0) 6.90ms
2022-10-06 19:37:44,922 INFO 200 GET /static/js/esphome/c.dd6ca16a.js (0.0.0.0) 6.64ms
2022-10-06 19:37:44,929 INFO 200 GET /static/js/esphome/c.a5dc75d4.js (0.0.0.0) 4.30ms
2022-10-06 19:37:44,932 INFO 200 GET /static/js/esphome/c.2deb9764.js (0.0.0.0) 5.62ms
2022-10-06 19:37:44,970 ERROR Uncaught exception GET /secret_keys (0.0.0.0)
HTTPServerRequest(protocol='http', host='homeassistant.local:8123', method='GET', uri='/secret_keys', version='HTTP/1.1', remote_ip='0.0.0.0')
File "/esphome/esphome/yaml_util.py", line 386, in _load_yaml_internal
return loader.get_single_data() or OrderedDict()
File "/usr/local/lib/python3.9/dist-packages/yaml/constructor.py", line 51, in get_single_data
return self.construct_document(node)
File "/usr/local/lib/python3.9/dist-packages/yaml/constructor.py", line 55, in construct_document
data = self.construct_object(node)
File "/usr/local/lib/python3.9/dist-packages/yaml/constructor.py", line 100, in construct_object
data = constructor(self, node)
File "/esphome/esphome/yaml_util.py", line 75, in wrapped
res = fn(loader, node)
File "/esphome/esphome/yaml_util.py", line 161, in construct_yaml_map
raise yaml.constructor.ConstructorError(
yaml.constructor.ConstructorError: Duplicate key "wifi_ssid"
in "/config/esphome/secrets.yaml", line 5, column 1:
wifi_ssid: "!secret wifi_ssid"
NOTE: Previous declaration here:
in "/config/esphome/secrets.yaml", line 1, column 1:
wifi_ssid : XXX
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/dist-packages/tornado/web.py", line 1702, in _execute
result = method(*self.path_args, **self.path_kwargs)
File "/esphome/esphome/dashboard/dashboard.py", line 136, in decorator
return func(self, *args, **kwargs)
File "/esphome/esphome/dashboard/dashboard.py", line 912, in get
secret_keys = list(yaml_util.load_yaml(filename, clear_secrets=False))
File "/esphome/esphome/yaml_util.py", line 378, in load_yaml
return _load_yaml_internal(fname)
File "/esphome/esphome/yaml_util.py", line 388, in _load_yaml_internal
raise EsphomeError(exc) from exc
esphome.core.EsphomeError: Duplicate key "wifi_ssid"
wifi_ssid : XXX
2022-10-06 19:37:44,976 ERROR 500 GET /secret_keys (0.0.0.0) 10.54ms
2022-10-06 19:37:48,794 INFO 304 GET /devices (0.0.0.0) 1.72ms
2022-10-06 19:37:53,804 INFO 304 GET /devices (0.0.0.0) 1.60ms
2022-10-06 19:37:58,818 INFO 304 GET /devices (0.0.0.0) 1.53ms
2022-10-06 19:38:03,835 INFO 304 GET /devices (0.0.0.0) 1.75ms
Et c’est moi qui l’arrête en cliquant ailleurs, sinon ça tourne pendant un bon moment.
