J’ai ajouté la Température CPU du PI dans Home Assistant:
# Example configuration.yaml entry
- platform: command_line
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
# If errors occur, make sure configuration file is encoded as UTF-8
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(1) }}"
Comment puis-je modifier la fréquence d’acquisition, je souhaite la diminuer.
Bruno
‹ ›'___
System Health
version | core-2021.10.0 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.9.7 |
os_name | Linux |
os_version | 5.10.17-v8 |
arch | aarch64 |
timezone | UTC |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 6.4 |
update_channel | stable |
supervisor_version | supervisor-2021.09.6 |
docker_version | 20.10.7 |
disk_total | 457.7 GB |
disk_used | 5.5 GB |
healthy | true |
supported | true |
board | rpi4-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | deCONZ (6.10.0), Let’s Encrypt (4.11.0), File editor (5.3.3), Samba share (9.5.1), Network UPS Tools (0.8.0), Spotify Connect (0.9.1), Terminal & SSH (9.2.1), Portainer (2.0.0), InfluxDB (4.2.1), Grafana (7.2.0) |
Lovelace
dashboards | 1 |
resources | 0 |
mode | auto-gen |
