J’ai actuellement 4 caméras que j’ai connectées à une instance Frigate montée en Docker dans mon NAS Synologie 218++ (10Go de Ram).
Je récupère directement les flux rtsp dans Frigate et j’ai ensuite mis la card HA_frigate pour récupérer les informations.
mqtt:
host: 192.168.1.30
port: 1883
user: mqtt
password: zzzzzzzz
stats_interval: 60
#enabled: false
birdseye:
enabled: false
rtmp:
enabled: false
detectors:
coral:
type: edgetpu
device: usb
record:
enabled: true
retain:
days: 3
mode: motion
events:
retain:
default: 7
mode: motion
snapshots:
enabled: true
retain:
default: 3
cameras:
garage: # <------ Name the camera
enabled: true
ffmpeg:
inputs:
- path: rtsp://yyyyyy:zzzzzzz@192.168.1.14:554 # <----- The stream you want to use for detection
roles:
- detect
onvif:
host: 192.168.1.14
port: 8899
user: yyyyyy
password: zzzzzzz
detect:
enabled: true
objects:
track:
- person
- dog
- cat
filters:
person:
# Optional: minimum score for the object to initiate tracking (default: shown below)
min_score: 0.7
# Optional: minimum decimal percentage for tracked object's computed score to be considered a true positive (default: shown below)
threshold: 0.8
record:
enabled: true
snapshots:
enabled: true
piscine: # <------ Name the camera
enabled: true
ffmpeg:
inputs:
- path: rtsp://zzzzzzz:yyyyyyyy@192.168.1.63:554 # <----- The stream you want to use for detection
roles:
- detect
onvif:
host: 192.168.1.63
port: 8899
user: zzzzzzz
password: yyyyyyyy
detect:
enabled: true
objects:
track:
- person
- dog
- cat
filters:
person:
min_score: 0.7
threshold: 0.8
record:
enabled: true
snapshots:
enabled: true
motion:
mask:
- 0,0,888,0,914,539,0,990
- 2304,0,2304,597,890,543,886,0
- 0,1303,2174,1294,2159,1670,0,1831
salon: # <------ Name the camera
enabled: true
ffmpeg:
inputs:
- path: rtsp://zzzzzzz:yyyyyyyy@192.168.1.32:554/stream1 # <----- The stream you want to use for detection
roles:
- detect
#onvif:
# host: 192.168.1.32
# port: 8899
# user: zzzzzzz
# password: yyyyyyyy
detect:
enabled: true
objects:
track:
- person
- dog
- cat
filters:
person:
min_score: 0.7
threshold: 0.8
record:
enabled: true
snapshots:
enabled: true
bureau: # <------ Name the camera
enabled: true
ffmpeg:
inputs:
- path: rtsp://192.168.1.150:554/ch0_0.h264 # <----- The stream you want to use for detection
roles:
- detect
detect:
enabled: true
objects:
track:
- person
- dog
- cat
filters:
person:
min_score: 0.7
threshold: 0.8
record:
enabled: true
snapshots:
enabled: true
J’ai également installé un CORAL pour l’aider un peu mais ça n’est pas flagrant. Le container consomme allègrement 70% du CPU Comment controler que le CORAL joue bien son rôle ?
Sur quoi pourrai-je jouer pour limiter un peu la consommation de CPU ?
Au hazard de lecture, j’ai vu que l’on pouvait passer via Go2RTC mais je ne comprends pas l’interêt. Pouvez vous m’en dire un peu plus que l’interêt ?
