Le module complémentaire Gazpar2HAWS ne fonctionne plus depuis 1 semaine.
C’est un module que j’utilise depuis plusieurs maintenant sans aucun problème.
J’ai d’installé le module puis réinstallé mais sans succès.
voici les logs:
[12:46:34] INFO: HOMEASSISTANT_HOST: supervisor
[12:46:34] INFO: HOMEASSISTANT_PORT: 80
[12:46:34] INFO: HOMEASSISTANT_ENDPOINT: /core/websocket
[12:46:34] INFO: HOMEASSISTANT_TOKEN: 21e0646e060b7306ee012de35e78db2fa9ec22d787a5d5443cb87b6cf08f8aa08a24d2183307ce2592c90d27b6c4872998bbd5a557fecf16
/app/run.sh: line 58: 118 Segmentation fault (core dumped) python3 -m gazpar2haws --config config/configuration.yaml --secrets config/secrets.yaml
[11:46:34] WARNING: Halt add-on with exit code 139
version
core-2026.1.3
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
container_arch
amd64
user
root
virtualenv
false
python_version
3.13.11
os_name
Linux
os_version
6.12.63-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
5000
Installed Version
2.0.5
Stage
running
Available Repositories
2680
Downloaded Repositories
58
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 17.0
update_channel
stable
supervisor_version
supervisor-2026.01.1
agent_version
1.8.1
docker_version
29.1.3
disk_total
97.7 GB
disk_used
62.2 GB
nameservers
192.168.1.254, 192.168.1.135, fd0f:ee:b0::1
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
kvm
board
ova
supervisor_api
ok
version_api
ok
installed_addons
Samba share (12.5.4), Let’s Encrypt (5.4.9), Samba Backup (5.2.0), Home Assistant Google Drive Backup (0.112.1), File editor (5.8.0), MQTT Explorer (browser-1.0.1), ESPHome Device Builder (2025.12.7), Zigbee2MQTT (2.8.0-1), Matterbridge (2.9.0-PSA-121), Grafana (12.1.0), Home-Assistant-Matter-Hub (3.0.4), IAction (1.8), Node-RED (20.2.4), Gazpar2HAWS (0.5.0a2)
dashboards
5
resources
40
views
27
mode
storage
Network Configuration
adapters
lo (disabled), enp0s18 (enabled, default, auto), docker0 (disabled), hassio (disabled), veth5c1b63f (disabled), vethd01440f (disabled), veth374baa1 (disabled), veth3d38d11 (disabled), veth863390f (disabled), vethea4efb1 (disabled), vethb1d767b (disabled), vethe267a67 (disabled), vethc9f4324 (disabled), vetha483f5b (disabled), vethc14aa12 (disabled), vethac9cddb (disabled)
ipv4_addresses
lo (127.0.0.1/8), enp0s18 (192.168.1.132/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), veth5c1b63f (), vethd01440f (), veth374baa1 (), veth3d38d11 (), veth863390f (), vethea4efb1 (), vethb1d767b (), vethe267a67 (), vethc9f4324 (), vetha483f5b (), vethc14aa12 (), vethac9cddb ()
ipv6_addresses
lo (::1/128), enp0s18 (2a01:e0a:b5c:a370:b83e:1ca7:b95d:58ab/64, fe80::7a61:6ab8:a04e:ebc/64), docker0 (fe80::3c4d:d2ff:fe16:cb4a/64), hassio (fe80::7c29:fff:fe56:475f/64), veth5c1b63f (fe80::5851:71ff:fe59:b634/64), vethd01440f (fe80::2c95:51ff:fef0:58b4/64), veth374baa1 (fe80::1469:14ff:fe28:8db9/64), veth3d38d11 (fe80::4eb:f1ff:fe5f:cc4c/64), veth863390f (fe80::1c48:f9ff:fe7f:eb9c/64), vethea4efb1 (fe80::78c9:b9ff:fefe:b0c/64), vethb1d767b (fe80::bc4a:80ff:fe05:89ec/64), vethe267a67 (fe80::9027:a4ff:feaf:54fc/64), vethc9f4324 (fe80::ac1b:cbff:fedb:a7de/64), vetha483f5b (fe80::2c18:4cff:fee1:8cdd/64), vethc14aa12 (fe80::48a6:61ff:fee0:65cb/64), vethac9cddb (fe80::87c:dcff:feb9:4a95/64)
announce_addresses
192.168.1.132, 2a01:e0a:b5c:a370:b83e:1ca7:b95d:58ab, fe80::7a61:6ab8:a04e:ebc
oldest_recorder_run
1 janvier 2026 à 09:06
current_recorder_run
3 février 2026 à 06:22
estimated_db_size
1162.08 MiB
database_engine
mysql
database_version
10.11.5
Sonoff
version
3.9.3 (7c75c46)
cloud_online
0 / 1
local_online
0 / 0
GuiPoM
Février 3, 2026, 1:34
2
Quand on intéragit avec un produit open-source, il vaut mieux s’adresser au mainteneur: L'add-on ne démarre pas (exit code 139) · Issue #105 · ssenart/gazpar2haws · GitHub
Salut, j’ai exactement le meme soucis depuis quelques jours, apparement un soucis dans le module d’un ancienne version python qui n’est plus à jour……donc temps que l’auteur ne modifie pas bah ça marchera plus
GuiPoM
Février 6, 2026, 4:34
4
l’auteur ne modifiera pas !
J’ai donné le lien vers l’issue. Il ne peut pas reproduire le problème.
