Je serai curieux de savoir comment faites-vous pour gérer la multitude d’erreurs qui arrive sur le journal.
En voici l’une d’entre elle:
Logger: homeassistant.components.alexa.state_report
Source: components/alexa/state_report.py:106
Integration: Amazon Alexa (documentation, issues)
First occurred: 15:40:29 (4 occurrences)
Last logged: 15:41:35
Error when sending ChangeReport for light.yeelight_color_0x800d3d3 to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
Error when sending ChangeReport for light.0x7cb03eaa0a033815 to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
Ces erreurs arrivent de partout. Dois-je les considérer toutes une à une ? J’ai pas l’impression qu’elles soient si grave car tout fonctionne mais ça doit surcharger le serveur au bout d’un moment…
Merci par avance
[center]## System Information
version |
core-2023.4.1 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.10 |
os_name |
Linux |
os_version |
5.15.84-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4995 |
Installed Version |
1.31.0 |
Stage |
running |
Available Repositories |
1315 |
Downloaded Repositories |
2 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 9.5 |
update_channel |
stable |
supervisor_version |
supervisor-2023.04.0 |
agent_version |
1.4.1 |
docker_version |
20.10.22 |
disk_total |
219.4 GB |
disk_used |
4.0 GB |
healthy |
true |
supported |
true |
board |
rpi3-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Z-Wave JS (0.1.77), File editor (5.5.0), SSH & Web Terminal (13.1.0), Mosquitto broker (6.2.0), Zigbee2MQTT (1.30.3-1), AirSend (1.1) |
dashboards |
3 |
resources |
0 |
views |
2 |
mode |
storage |
oldest_recorder_run |
30 mars 2023 à 17:07 |
current_recorder_run |
8 avril 2023 à 09:58 |
estimated_db_size |
43.95 MiB |
database_engine |
sqlite |
database_version |
3.38.5 |
Je ne regarde les erreurs que quand quelque chose ne fonctionne pas, mais en général mon HA ne plante jamais.
La majorité des erreurs récurrentes que j’ai dans le log c’est des timeout ou des limitations en nombre de requêtes. Donc des choses qui se corrigent d’elles mêmes.
Bon dans ton cas, une invalid access token ça peut quand même être un souci de config.
