Bonjour suite au passage de ha que j’avais sur vm d’essai a une install sur une debian 11 ha supervised.
Homme assistant ne voit plus mes devices depuis z2m je peux les piloter depuis le tableau de bord.
J’ai essayer mqtt explorer j’accède bien a celui ci et je vois bien mes entités.
Voici un log de mosquitto broker
Merci par avance pour l’aide que vous pourrai m’apporter
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[18:33:16] INFO: Setting up user mqtt
[18:33:16] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[18:33:16] INFO: Starting NGINX for authentication handling...
[services.d] done.
[18:33:17] INFO: Starting mosquitto MQTT broker...
1655051597: Warning: Mosquitto should not be run as root/administrator.
[18:33:18] INFO: Successfully send discovery information to Home Assistant.
[18:33:18] INFO: Successfully send service information to the Supervisor.
1655051597: mosquitto version 2.0.11 starting
1655051597: Config loaded from /etc/mosquitto/mosquitto.conf.
1655051597: Loading plugin: /usr/share/mosquitto/go-auth.so
1655051597: ├── Username/password checking enabled.
1655051597: ├── TLS-PSK checking enabled.
1655051597: └── Extended authentication not enabled.
1655051597: Opening ipv4 listen socket on port 1883.
1655051597: Opening ipv6 listen socket on port 1883.
1655051597: Opening websockets listen socket on port 1884.
1655051597: mosquitto version 2.0.11 running
1655051598: New connection from 127.0.0.1:47178 on port 1883.
1655051598: Client <unknown> closed its connection.
1655051598: New connection from 172.30.32.1:39164 on port 1883.
1655051598: New client connected from 172.30.32.1:39164 as mqttjs_243f2760 (p2, c1, k60, u'mqtt').
1655051631: New connection from 172.30.32.1:57649 on port 1883.
1655051631: Client <unknown> disconnected, not authorised.
1655051752: New connection from 172.30.32.1:42541 on port 1883.
1655051752: Client <unknown> disconnected, not authorised.
1655051793: Client mqttjs_243f2760 closed its connection.
1655051807: New connection from 172.30.32.1:39230 on port 1883.
1655051807: New client connected from 172.30.32.1:39230 as mqttjs_f9c64c33 (p2, c1, k60, u'mqtt').
1655051872: New connection from 172.30.32.1:35319 on port 1883.
1655051872: Client <unknown> disconnected, not authorised.
1655051992: New connection from 172.30.32.1:36697 on port 1883.
1655051992: Client <unknown> disconnected, not authorised.
1655052113: New connection from 172.30.32.1:47491 on port 1883.
1655052113: Client <unknown> disconnected, not authorised.
1655052242: New connection from 172.30.32.1:48137 on port 1883.
1655052242: Client <unknown> disconnected, not authorised.
1655052243: New connection from 172.30.32.1:37489 on port 1883.
1655052243: Client <unknown> disconnected, not authorised.
1655052245: New connection from 172.30.32.1:45005 on port 1883.
1655052245: Client <unknown> disconnected, not authorised.
1655052249: New connection from 172.30.32.1:46349 on port 1883.
1655052249: Client <unknown> disconnected, not authorised.
1655052257: New connection from 172.30.32.1:48161 on port 1883.
1655052257: Client <unknown> disconnected, not authorised.
1655052273: New connection from 172.30.32.1:43817 on port 1883.
1655052273: Client <unknown> disconnected, not authorised.
1655052305: New connection from 172.30.32.1:34211 on port 1883.
1655052305: Client <unknown> disconnected, not authorised.
1655052371: New connection from 172.30.32.1:56943 on port 1883.
1655052371: Client <unknown> disconnected, not authorised.
1655052491: New connection from 172.30.32.1:51457 on port 1883.
1655052491: Client <unknown> disconnected, not authorised.
1655052611: New connection from 172.30.32.1:37899 on port 1883.
1655052611: Client <unknown> disconnected, not authorised.
1655052732: New connection from 172.30.32.1:47667 on port 1883.
1655052732: Client <unknown> disconnected, not authorised.
1655052763: Client mqttjs_f9c64c33 closed its connection.
1655052778: New connection from 172.30.32.1:39606 on port 1883.
1655052778: New client connected from 172.30.32.1:39606 as mqttjs_e66a3d20 (p2, c1, k60, u'mqtt').
1655052852: New connection from 172.30.32.1:49415 on port 1883.
1655052852: Client <unknown> disconnected, not authorised.
1655052972: New connection from 172.30.32.1:60935 on port 1883.
1655052972: Client <unknown> disconnected, not authorised.
1655053093: New connection from 172.30.32.1:51783 on port 1883.
1655053093: Client <unknown> disconnected, not authorised.
1655053130: New connection from 172.30.32.1:36399 on port 1883.
1655053130: Client <unknown> disconnected, not authorised.
1655053131: New connection from 172.30.32.1:48067 on port 1883.
1655053131: Client <unknown> disconnected, not authorised.
1655053133: New connection from 172.30.32.1:53505 on port 1883.
1655053133: Client <unknown> disconnected, not authorised.
1655053137: New connection from 172.30.32.1:50575 on port 1883.
1655053137: Client <unknown> disconnected, not authorised.
Log de ha supervisor
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-06-12 19:39:18 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-06-12 19:39:20 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-06-12 19:39:20 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-06-12 19:39:20 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
22-06-12 19:39:20 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-06-12 19:39:21 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 0 new - 0 remove
22-06-12 19:39:58 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
22-06-12 19:39:58 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Unknown option 'homeassistant' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Unknown option 'permit_join' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:43:58 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:45:59 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
22-06-12 19:46:00 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'homeassistant' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'permit_join' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:49:00 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:51:20 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-06-12 19:52:00 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
22-06-12 19:52:01 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'homeassistant' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'permit_join' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:54:02 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:58:01 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
22-06-12 19:58:02 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Unknown option 'homeassistant' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Unknown option 'permit_join' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:04 WARNING (MainThread) [supervisor.addons.options] Option 'availability' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-12 19:59:18 INFO (MainThread) [supervisor.host.info] Updating local host information
22-06-12 19:59:19 INFO (MainThread) [supervisor.host.services] Updating service information
22-06-12 19:59:19 INFO (MainThread) [supervisor.host.network] Updating local network information
22-06-12 19:59:20 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-06-12 19:59:20 INFO (MainThread) [supervisor.host.manager] Host information reload completed
Log core
Journaux complets
2022-06-12 19:13:39 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-12 19:13:46 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:13:46 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:13:47 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:13:47 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:13:49 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:13:50 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:13:54 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:13:54 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:14:02 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:14:02 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:14:18 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:14:18 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:14:51 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:14:51 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:15:55 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:15:55 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:17:55 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:17:55 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:19:55 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:19:55 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:21:56 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:21:56 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:23:56 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:23:56 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:25:56 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:25:56 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:26:49 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from OPPO-Reno2 (192.168.1.41). (Home Assistant/2022.6.0-2398 (Android 11; CPH1907))
2022-06-12 19:26:49 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from OPPO-Reno2 (192.168.1.41). (Mozilla/5.0 (Linux; Android 11; CPH1907 Build/RKQ1.200903.002; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/102.0.5005.78 Mobile Safari/537.36 Home Assistant/2022.6.0-2398 (Android 11; CPH1907))
2022-06-12 19:27:57 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:27:57 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:29:57 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:29:57 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:31:57 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:31:57 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:33:58 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:33:58 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:35:58 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:35:58 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:37:58 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:37:58 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:39:59 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:39:59 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:41:59 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:41:59 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:43:59 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:43:59 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:46:00 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:46:00 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:48:00 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:48:00 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:50:00 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:50:00 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:52:01 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:52:01 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:54:01 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:54:01 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:56:01 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:56:01 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 19:58:02 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 19:58:02 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 20:00:02 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 20:00:02 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 20:02:02 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 20:02:02 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 20:04:03 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 20:04:03 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 20:06:03 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 20:06:03 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2022-06-12 20:08:03 ERROR (Thread-3) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2022-06-12 20:08:03 WARNING (Thread-3) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
