J’ai un souci avec de connexion avec un iPhone sur HA, le problème ne vient pas du mot de passe car il fonctionne sur d’autres appareils. Je pense que problème vient sûrement des certificats ou d’une blacklist mais je ne sais vraiment pas où chercher.
Pour information, j’ai 2 autres iPhone et 2 autres iPad qui se connectent sans soucis.
Logs du problème :
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:81
Integration: HTTP (documentation, issues)
First occurred: 20:33:53 (2 occurrences)
Last logged: 20:53:10
Login attempt or request with invalid authentication from 192.168.1.1 (192.168.1.1). Requested URL: ‹ /auth/login_flow/78b7876719b870d3546c284d54d97c40 ›. (Mozilla/5.0 (iPhone; CPU iPhone OS 16_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.3 Mobile/15E148 Safari/604.1)
version | core-2023.1.7 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.7 |
os_name | Linux |
os_version | 5.15.80 |
arch | x86_64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 5000 |
Installed Version | 1.30.0 |
Stage | running |
Available Repositories | 1197 |
Downloaded Repositories | 24 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 9.4 |
update_channel | stable |
supervisor_version | supervisor-2022.12.1 |
agent_version | 1.4.1 |
docker_version | 20.10.19 |
disk_total | 30.8 GB |
disk_used | 20.6 GB |
healthy | true |
supported | true |
board | ova |
supervisor_api | ok |
version_api | ok |
installed_addons | deCONZ (6.18.0), Samba share (10.0.0), CEC Scanner (3.0), File editor (5.5.0), Node-RED (14.0.1), Let’s Encrypt (4.12.7), InfluxDB (4.5.0), Grafana (8.1.0), motionEye (0.18.0), Z-Wave JS (0.1.74), Home Assistant Google Drive Backup (0.110.1) |
dashboards | 3 |
resources | 11 |
views | 14 |
mode | storage |
oldest_recorder_run | 21 janvier 2023 à 17:07 |
current_recorder_run | 22 janvier 2023 à 21:31 |
estimated_db_size | 777.41 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
