!include_dir_merge_named themes Je pige pas?
Bonjour à toutes et à tous,
J’ai réussi à intégrer les couleurs Tempo à mon module NRJ mais via mon configuration.yaml, j’aurais souhaité, afin de l’alléger, déplacer cette modification dans le dossier thèmes, mais cela ne fonctionne pas o_O
Mon configuration.yaml
#Load frontend themes from the themes folder
frontend:
#  themes: !include_dir_merge_named themes
  themes:
    theme_couleurs_tempo:
      #primary-color: "#264269"
      modes:
        light:
          energy-grid-consumption-color-5: "#8B0000"  # HP ROUGE
          energy-grid-consumption-color-4: "#FF0000"  # HC ROUGE
          energy-grid-consumption-color-3: "#fbfbfb"  # HP BLANC
          energy-grid-consumption-color-2: "#d7d7d7"  # HC BLANC
          energy-grid-consumption-color-1: "#9BE1FD"  # HP BLEU
          energy-grid-consumption-color-0: "#039DE0"  # HC BLEU
        dark:
          energy-grid-consumption-color-5: "#FF0000"  # HP ROUGE
          energy-grid-consumption-color-4: "#aa2424"  # HC ROUGE
          energy-grid-consumption-color-1: "#2a81eb"  # HP BLEU
          energy-grid-consumption-color-0: "#0c57b4"  # HC BLEU
Mon fichier thème dans le dossier themes
# themes/theme_couleurs_tempo.yaml
  modes:
    light:
    dark:
Merci de vos lumières !
[center]## System Information
version core-2024.1.6
python_version 3.11.6
os_version 6.1.71-haos
Installed Version 1.34.0
Available Repositories 1456
Downloaded Repositories 21
logged_in true
subscription_expiration 16 janvier 2025 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled true
google_enabled false
remote_server eu-central-1-2.ui.nabu.casa
certificate_status ready
instance_id 9b1354271d894ddab777f6bfe47bce87
host_os Home Assistant OS 11.4
supervisor_version supervisor-2023.12.1
agent_version 1.6.0
docker_version 24.0.7
disk_total 28.0 GB
disk_used 9.2 GB
board green
installed_addons Terminal & SSH (9.8.1), Linky (1.2.0), Home Assistant Google Drive Backup (0.112.1), Studio Code Server (5.15.0), Silicon Labs Multiprotocol (2.4.4), Mosquitto broker (6.4.0)
dashboards 2
resources 21
views 9
oldest_recorder_run 26 janvier 2024 à 05:46
current_recorder_run 4 février 2024 à 06:54
estimated_db_size 2211.20 MiB
database_version 3.41.2
Spotify
api_endpoint_reachable ok
[/center]
Est ce que tu as appelé ton thème dans ton profil ?
Capture d'écran 2024-02-04 071441
Dans mon fichier de thème :
   # Bleu nuit: HC Bleu
  energy-grid-consumption-color-0: '#0f056b'
  # Bleu -magenta : HP Bleu
  energy-grid-consumption-color-1: '#3737e9'
  # Gris: HC Blanc
  energy-grid-consumption-color-2: '#cccccc'
  # Blanc : HP Blanc
  energy-grid-consumption-color-3: '#fff'
  # Rouge sang: HC Rouge
  energy-grid-consumption-color-4: '#850606'
  # Red : HP Rouge
  energy-grid-consumption-color-5: '#E60000'
  # Standard : Tarif Base
  energy-grid-consumption-color-6: '#9eb75c'
Configuration.yaml :
frontend:
  themes:
Oui en faisant la même chose que toi et en rechargeant tout le yaml, j’ai ça :
Pas de thème dispo
Tu as un répertoire theme avec ton fichier yaml dedans ?
Capture d'écran 2024-02-04 073622
Le mien est un mix du thème de caule mélangé avec les couleurs tempo
Oui, fichier couleurs_tempo dans dossier themes
Il n’y a pas l’extension .yaml ?
Ah quelle buse !!!
Alors oui pas d’extension :confused:
C’est corrigé, mais il me met ceci désormais :
Erreurs de configuration
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 11: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-4', got '#850606'
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 13: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-5', got '#E60000'
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 15: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-6', got '#9eb75c'
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 3: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-0', got '#0f056b'
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 5: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-1', got '#3737e9'
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 7: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-2', got '#cccccc'
Invalid config for 'frontend' at themes/couleurs_tempo.yaml, line 9: expected a dictionary for dictionary value 'frontend->themes->energy-grid-consumption-color-3', got '#fff'
Cela marche avec ce code pour le thème :
couleurs_tempo:
  # Bleu - magenta: HP Bleu
  # Gris: HC Blanc
  # Blanc: HP Blanc
  # Red: HP Rouge
  # Standard: Tarif Base
Mais du coup en sélectionnant ce thème, je perds le dark mode :confused:
Edit :
Non c’est bon, j’ai enfin compris :
couleurs_tempo:
  modes:
    light:
    dark:
Merci @Ludoc de ton aide :pray:
