Bonsoir,
cela fait un moment que j’avais pas joué avec influx, mais voilà, j’ai rajouté la config dans configuration.yaml
influxdb:
host: xxx
port: 8086
database: xxx
username: xxx
password: xxx
max_retries: 3
default_measurement: state
mais j’ai l’erreur suivante dans le log :
2020-12-27 22:23:14 ERROR (influxdb) [root] Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 579, in run
self.write_to_influxdb(json)
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 555, in write_to_influxdb
self.influx.write(json)
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 423, in write_v1
influx.write_points(json, time_precision=precision)
File "/usr/local/lib/python3.8/site-packages/influxdb/client.py", line 525, in write_points
return self._write_points(points=points,
File "/usr/local/lib/python3.8/site-packages/influxdb/client.py", line 594, in _write_points
self.write(
File "/usr/local/lib/python3.8/site-packages/influxdb/client.py", line 331, in write
data = make_lines(data, precision).encode('utf-8')
File "/usr/local/lib/python3.8/site-packages/influxdb/line_protocol.py", line 156, in make_lines
for field_key, field_value in sorted(iteritems(point['fields'])):
TypeError: '<' not supported between instances of 'int' and 'str'
une idée ?
sachant que j’ai quand meme un ou deux sensors de créé dans influx
