Salut à tous j’ai cette erreur depuis je ne sais quand et je trouve rien dans les log. Une idée du problème ?
Logger: homeassistant.helpers.state
Source: helpers/state.py:107
First occurred: 16:16:17 (13 occurrences)
Last logged: 16:21:08
Integration device_tracker does not support reproduce state
Integration sensor does not support reproduce state
System Health
version |
core-2022.2.9 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.9.7 |
os_name |
Linux |
os_version |
5.10.92-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4770 |
Installed Version |
1.23.0 |
Stage |
running |
Available Repositories |
1054 |
Downloaded Repositories |
38 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 7.4 |
update_channel |
stable |
supervisor_version |
supervisor-2022.01.1 |
docker_version |
20.10.9 |
disk_total |
111.1 GB |
disk_used |
7.8 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Duck DNS (1.14.0), File editor (5.3.3), RPC Shutdown (2.2), Samba share (9.5.1), ESPHome (2022.2.4), Home Assistant Google Drive Backup (0.105.2), Terminal & SSH (9.3.0), Glances (0.14.2), Check Home Assistant configuration (3.10.0) |
Lovelace
dashboards |
5 |
resources |
26 |
views |
8 |
mode |
storage |
