Bonjour à toutes et à tous,
Rien de plus simple que d’intégrer motioneye a HA via les add-ons et pourtant
Motioneye ne démarre pas !
si dessous le log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: motionEye
Simple, elegant and feature-rich CCTV/NVR for your cameras
Add-on version: 0.18.0
You are running the latest version of this add-on.
System: Home Assistant OS 9.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.10.4
Home Assistant Supervisor: 2022.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] motioneye.sh: executing...
backing up /data/motioneye/motioneye.conf
[cont-init.d] motioneye.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[05:49:52] INFO: Starting motionEye...
INFO: hello! this is motionEye server 0.42.1
INFO: cleanup started
INFO: wsswitch started
INFO: tasks started
INFO: mjpg client garbage collector started
INFO: smb mounts started
INFO: server started
[05:49:54] INFO: Starting NGinx...
[05:49:54] INFO: Successfully send discovery information to Home Assistant.
D’après le log il semblerait que motioneye a démarré et pourtant le voyant rest rouge et pas d’acces au lien d’ouverture de la page web.
Un appui sur motioneye dans la barre latérale dit que motioneye n’est pas démarré.
Merci par avance
Cordialement Jacquot
version | core-2022.10.4 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.5 |
os_name | Linux |
os_version | 5.15.61-v8 |
arch | aarch64 |
timezone | Europe/Paris |
config_dir | /config |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 9.2 |
update_channel | stable |
supervisor_version | supervisor-2022.10.0 |
agent_version | 1.4.1 |
docker_version | 20.10.17 |
disk_total | 116.7 GB |
disk_used | 3.2 GB |
healthy | true |
supported | true |
board | rpi4-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | Mosquitto broker (6.1.3), TasmoAdmin (0.20.0), File editor (5.4.1), motionEye (0.18.0) |
dashboards | 1 |
resources | 0 |
views | 2 |
mode | storage |
oldest_recorder_run | 17 octobre 2022 à 16:11 |
current_recorder_run | 18 octobre 2022 à 11:58 |
estimated_db_size | 8.85 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
