Achete chez Domadoo 2 capteurs 3 en 1 NEO modele NAS PD01Z01
Ma cle Zwawe z stick gen 5 les a bien récupérés mais ils ne renvoient aucune information
Mes autres capteurs fonctionnent normalement
version |
core-2025.3.2 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.13.2 |
os_name |
Linux |
os_version |
6.6.73-haos |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
2.0.5 |
Stage |
running |
Available Repositories |
1583 |
Downloaded Repositories |
2 |
logged_in |
true |
subscription_expiration |
14 mars 2025 à 01:00 |
relayer_connected |
true |
relayer_region |
eu-central-1 |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
true |
cloud_ice_servers_enabled |
true |
remote_server |
eu-central-1-27.ui.nabu.casa |
certificate_status |
ready |
instance_id |
4b4ee88f7f0849d0bf48b99d40b55396 |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 14.2 |
update_channel |
stable |
supervisor_version |
supervisor-2025.03.2 |
agent_version |
1.6.0 |
docker_version |
27.2.0 |
disk_total |
28.0 GB |
disk_used |
4.7 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
board |
green |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Z-Wave JS |
oldest_recorder_run |
27 février 2025 à 17:11 |
current_recorder_run |
12 mars 2025 à 15:11 |
estimated_db_size |
46.50 MiB |
database_engine |
sqlite |
database_version |
3.48.0 |
___Etant novice sur HA j ai passé pas mal de temps sur ces 2 capteurs et je n arrive a rien !
J ai essayé plusieurs fous de les exclure / reinclure sans succès
Merci d avance !
