Je suis juste aller dans la page de Spook sur HACS, pour que ça actualise les informations et de retour dans la page d’accueil de HACS, pour voir la maj proposer.
J’ai plus d’erreur avec spook pour l’entité sensor.backup_state fourni par Google drive backup. ![]()
La doc a été mise a jour.
These are some Spook-specific features that don’t fit in any of the other categories. They are not particularly useful, but they are fun to play with (and maybe you actually have a use case for them).
They originally served as the proof of concept for Spook and left them in for the fun of it.
Services
Spook offers the following services useless services:
Boo!
This service will just always scare Home Assistant, causing this service call to fail. Calling this service in any of your automations will thus cause your automation to stop and error.
C’est plus qu’une simple mise à jour !!: https://spook.boo/
On est passé de « attention ce truc fait ce qu’il veut » à une doc complète avec historique de spook, FAQ, et la liste de l’ensemble des fonctionnalités et services !!
Bon c’est en Anglais, mais là spook fait nettement moins peur et risque de devenir sacrément utile !!
Nouvelle version pour l’anniversaire de spook. Spook deviens notre amis maintenant ![]()
Birthday release!
Spook
recently had his first birthday, and I’m celebrating that with some major changes that justifies this release to be a major release ![]()
Many have complained that Spook has an annoying license and an unfriendly tone that is discouraging and scary. Well, honestly, the scary part is a bit part of running custom integrations, I guess, the reason why he is a ghost in the first place… but… Agreed.
Therefore, as of today, Spook is MIT Licensed ![]()
And not just that, Spook is no longer « Not your homie »… as of today, Spook is your homie! ![]()
Yes, feel free to run it and use it. He is your friend.
Compatibility with Home Assistant 2024.5
This release fixes a few compatibility issues with Home Assistant 2024.5.
Upgrading Spook before Home Assistant is recommended but not critical.
If you swap the upgrade order, there will be no sweat!
Labels & Floors
Home Assistant 2024.4 brought your new organizational features: Floors & Labels.
This release of Spook
adds support for those too!
Spook is able to detect the use of unknown labels & floors being used in your automations and script (and creates repairs for those), but also provides you a shitload of services that allows you to manage both floors and labels programmatically.
Read more about it in the label management and floor management documentation.
Changelog
There are many other small changes and improvements. Thanks everyone for contributing! ![]()
New features
- Detect unknown labels used in automations @frenck (#694)
- Detect unknown floors used in automations @frenck (#695)
- Detect unknown labels used in scripts @frenck (#696)
- Detect unknown floors used in scripts @frenck (#697)
- Allow setting icon on homeassistant.create_area service @frenck (#699)
- Add homeassistant.create_floor service @frenck (#702)
- Add homeassistant.add_alias_to_floor service @frenck (#703)
- Add homeassistant.remove_alias_from_floor service @frenck (#704)
- Add homeassistant.set_floor_aliases service @frenck (#705)
- Add homeassistant.add_area_to_floor service @frenck (#706)
- Add homeassistant.remove_area_from_floor service @frenck (#707)
- Add homeassistant.delete_floor service @frenck (#708)
- Add homeassistant.delete_label service @frenck (#712)
- Add homeassistant.create_label service @frenck (#713)
- Add homeassistant.add_label_to_area service @frenck (#715)
- Add homeassistant.add_label_to_device service @frenck (#716)
- Add homeassistant.add_label_to_entity service @frenck (#717)
- Add homeassistant.remove_label_from_area service @frenck (#718)
- Add homeassistant.remove_label_from_device service @frenck (#719)
- Add homeassistant.remove_label_from_entity service @frenck (#720)
Bug fixes
- Fix gathering of all floor IDs @frenck (#710)
- Fix blocking I/O on event loop while importing modules @frenck (#722)
- Fix area and floor registry service calls @cdce8p (#732)
Enhancements
- Migrate from Poetry to rye @frenck (#673)
- Use floor selector in floor related services @frenck (#711)
- Misc typing improvements @cdce8p (#731)
- Add EventType annotations @cdce8p (#733)
- Change Description dataclasses to frozen @cdce8p (#730)
- Make AbstractSpookEntityService and AbstractSpookEntityComponentService generic @cdce8p (#729)
Maintenance
- Switch Spook to MIT license @frenck (#671)
- Spook: Your homie - Brand assets @frenck (#687)
- Spook: Your homie @frenck (#688)
- Require at least Home Assistant 2024.4.0 @frenck (#692)
- Clean up Poetry from Renovate configuration @frenck (#693)
- Require at least Home Assistant 2024.4.0 @frenck (#721)
- Move license to root of repo so GitHub picks it up @frenck (#723)
- Translations update from Hosted Weblate @weblate (#682)
- Translations update from Hosted Weblate @weblate (#685)
Documentation
Bonjour @WarC0zes
Je vois compatibilité avec HA 2024.5 vous avez recu cette mise a jour ? car je suis toujours en 2024.4.4
Comment faire la mise à jour de spook ? je n’ai rien de mentionné.
Merci de ton aide
La maj sort ce soir mais comme pour toutes les .0 pas de précipitation.
Salut @pascal_ha,
tu peu me tutoyer depuis le temps ![]()
Non pas de maj 2024.4.5 dispo, ca sort tout les 1er mercredi du mois ( pas le samedi
Donc patience, et comme le dit @Idaho947 faut pas ce jeter sur les versions xxxx.x.0 car souvent elle sont bugger.
Merci à vous 2
J’ai vu deux fois cette semaine l’annonce de cette version, du coup, je me suis étonné de rien voir dans les mises à jour.
Comme je ne vois pas celle de spook non plus, je me suis dit il y a un souci.
Mais je vais patienter au moins une semaine avant de faire la mise à jour de HA.(pour être sur
Oui, mais dans ma tête, je posais la question à toute la communauté ![]()
D’ailleurs, j’ai fini par « Merci de ton aide » C’est un peu mélangé, comme dans ma tête des fois…
La V3.0.0 est sortie hier et aujourd’hui la v3.0.1 et HACS actualise tout les 24H.
toute facon , la mise a jour aura aucun impacte, suivant laquelle tu fera en premier.
Compatibilité avec Home Assistant 2024.5
Cette version corrige quelques problèmes de compatibilité avec Home Assistant 2024.5.
La mise à niveau de Spook avant Home Assistant est recommandée mais pas critique.
Si vous échangez l’ordre de mise à niveau, il n’y aura pas de problème !
Moi, juste en rentrant dans la page de spook et revenir dans le menu prinicpale de HACS actualise aussi.
Dans HACS je suis bien passé en V3.0.1 Spook your Homie
Mais dans les intégrations, c’est écrit Spook not your homie
Alors c’est your Homie ou c’est not your homie ![]()
homie or not homie c’est la question ?
A ce niveau, ç’est à toi de le renommer ![]()
3 points, renommer.
Comme ta déjà installer une ancienne version, tu dois pas avoir de changement de nom ( bug ?).
Bon, c’est corrigé (enfin renommé). Me voilà rassuré ![]()
vu les reports, vaut mieux pas installer la 2024.5.0 ! ![]()
