j’ai essayé d’installer Influxdb. Comme je n’avais pas accès à la configuration sur ce module complémentaire ni sur les autres j’ai fait comme indiqué, un redémarrage de mon rasp 4.
Depuis, je n’ai plus l’accès au menu des modules complémentaire.
le log des erreurs:
sais2023-03-14 12:45:05.143 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-14 12:45:09.394 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-03-14 12:45:09.711 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=32 from 2023-03-14 10:52:55.942237)
2023-03-14 12:45:10.167 WARNING (MainThread) [homeassistant.components.hassio] Not connected with the supervisor / system too busy!
2023-03-14 12:45:12.998 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: System is not ready with state: setup
2023-03-14 12:45:13.222 ERROR (MainThread) [homeassistant.components.hassio.addon_panel] Can't read panel info: System is not ready with state: setup
2023-03-14 12:45:13.272 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
File "/usr/src/homeassistant/homeassistant/setup.py", line 256, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 586, in async_setup
await repairs.setup()
File "/usr/src/homeassistant/homeassistant/components/hassio/repairs.py", line 149, in setup
await self.update()
File "/usr/src/homeassistant/homeassistant/components/hassio/repairs.py", line 157, in update
data = await self._client.get_resolution_info()
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: System is not ready with state: setup
2023-03-14 12:45:24.499 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio
2023-03-14 12:45:24.503 ERROR (MainThread) [homeassistant.setup] Setup failed for raspberry_pi: (DependencyError(...), 'Could not setup dependencies: hassio')
2023-03-14 12:50:13.231 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 560, in _async_setup_hardware_integration
if (os_info := get_os_info(hass)) is None:
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 320, in get_os_info
return hass.data.get(DATA_OS_INFO)
AttributeError: 'datetime.datetime' object has no attribute 'data'issez ou collez du code ici
Merci pour votre aide
## System Information
version | core-2023.3.3
installation_type | Home Assistant Container
dev | false
hassio | false
docker | true
user | root
virtualenv | false
python_version | 3.10.10
os_name | Linux
os_version | 5.15.84-v8
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4951
Installed Version | 1.31.0
Stage | running
Available Repositories | 1247
Downloaded Repositories | 3
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
dashboards | 2
resources | 1
views | 1
mode | storage
</details>
oldest_recorder_run | 12 mars 2023 à 15:19
current_recorder_run | 14 mars 2023 à 12:45
estimated_db_size | 23.37 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
