bonjour a tous,
Depuis quelques jours une prise INNR SP220 me renvoie son état mais n’est plus pilotable via HA.
Si je passe directement par Z2M elle m’affiche un message d’erreur:
Est ce un problème de prise ou simplement de communication entre la prise et Z2M?
merci d’avance
version |
core-2022.10.4 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.5 |
os_name |
Linux |
os_version |
5.15.61-v8 |
arch |
aarch64 |
timezone |
UTC |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.27.2 |
Stage |
running |
Available Repositories |
1124 |
Downloaded Repositories |
8 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 9.2 |
update_channel |
stable |
supervisor_version |
supervisor-2022.10.0 |
agent_version |
1.4.1 |
docker_version |
20.10.17 |
disk_total |
28.5 GB |
disk_used |
7.6 GB |
healthy |
true |
supported |
true |
board |
rpi3-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Duck DNS (1.15.0), Zigbee2MQTT (1.28.0-1), Mosquitto broker (6.1.3), Terminal & SSH (9.6.1), Node-RED (13.4.0), File editor (5.4.1), AirCast (3.4.1), Samba share (10.0.0) |
dashboards |
2 |
resources |
2 |
views |
15 |
mode |
storage |
oldest_recorder_run |
8 octobre 2022 à 12:29 |
current_recorder_run |
15 octobre 2022 à 16:43 |
estimated_db_size |
140.34 MiB |
database_engine |
sqlite |
database_version |
3.38.5 |
