Je ne parviens a installer ma clé CONBEE 2 Zigbee
Novice je viens d’installer via Docker Home Assitant (pas d’acces à la « boutique » donc)
Je dispose d’un clé CONBEE 2 je tente sans succès de l’intégrer pourriez vous m’aider ?
Voici ma démarche
Ajout (intégration)
Paramétrage type de radio (info trouvé sur le web)
Puis il me demande un chemin
J’ai fais plusieurs tentatives mais rien
HELP !!
Ma configuration LINUX
**sb_release -a**
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 23.04
Release:        23.04
Codename:       lunar
**sudo lshw -short**
H/W path           Device     Class          Description
                              system         90C2004KFR (LENOVO_PN_Lenovo H30-00)
/0                            bus            Aptio CRB
/0/0                          memory         64KiB BIOS
/0/28                         memory         4GiB System Memory
/0/28/0                       memory         4GiB DIMM DDR3 1333 MHz (0,8 ns)
/0/32                         memory         224KiB L1 cache
/0/33                         memory         2MiB L2 cache
/0/34                         processor      Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz
/0/100                        bridge         Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register
/0/100/2           /dev/fb0   display        Atom Processor Z36xxx/Z37xxx Series Graphics & Display
/0/100/13          scsi0      storage        Atom Processor E3800 Series SATA IDE Controller
/0/100/13/0.0.0    /dev/sda   disk           120GB SSD 120GB
/0/100/13/0.0.0/1  /dev/sda1  volume         72GiB Linux filesystem partition
/0/100/13/0.0.0/2  /dev/sda2  volume         6000MiB Linux swap volume
/0/100/13/0.0.0/3  /dev/sda3  volume         16GiB Linux filesystem partition
/0/100/14                     bus            Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI
/0/100/14/0        usb1       bus            xHCI Host Controller
/0/100/14/0/3                 bus            USB2.0 Hub
/0/100/14/0/3/3               communication  ConBee II
/0/100/14/0/4                 bus            Dell Multimedia Pro Keyboard Hub
/0/100/14/0/4/1    input4     input          Dell Dell Multimedia Pro Keyboard System Control
/0/100/14/0/4/2    input7     input          Primax Kensington Eagle Trackball
/0/100/14/1        usb2       bus            xHCI Host Controller
/0/100/1a                     generic        Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine
/0/100/1b          card0      multimedia     Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
/0/100/1b/0        input10    input          HDA Intel PCH Line
/0/100/1b/1        input11    input          HDA Intel PCH Line Out
/0/100/1b/2        input12    input          HDA Intel PCH Front Headphone
/0/100/1b/3        input8     input          HDA Intel PCH Front Mic
/0/100/1b/4        input9     input          HDA Intel PCH Rear Mic
/0/100/1c                     bridge         Atom Processor E3800 Series PCI Express Root Port 1
/0/100/1c.2                   bridge         Atom Processor E3800 Series PCI Express Root Port 3
/0/100/1c.2/0      enp2s0     network        RTL810xE PCI Express Fast Ethernet controller
/0/100/1c.3                   bridge         Atom Processor E3800 Series PCI Express Root Port 4
/0/100/1c.3/0      wlp3s0     network        AR9285 Wireless Network Adapter (PCI-Express)
/0/100/1f                     bridge         Atom Processor Z36xxx/Z37xxx Series Power Control Unit
/0/100/1f/0                   system         PnP device PNP0b00
/0/100/1f/1                   system         PnP device PNP0c02
/0/100/1f/2                   system         PnP device PNP0c02
/0/100/1f/3                   communication  PnP device PNP0501
/0/100/1f/4                   system         PnP device PNP0c02
/0/100/1f.3                   bus            Atom Processor E3800/CE2700 Series SMBus Controller
/1                 input0     input          Power Button
/2                 input1     input          Sleep Button
/3                 input2     input          Power Button
/4                 input3     input          Video Bus
Ma configuration HA
Version core-2023.9.2
Type d’installation Home Assistant Container
Développement false
Supervisor false
Docker true
Utilisateur root
Environnement virtuel false
Version de Python 3.11.5
Version du système d’exploitation 6.2.0-35-generic
Architecture du processeur x86_64
Fuseau horaire Europe/Paris
J’ai aussi une conbee2 et HA docker.
La déclaration de la clé, je la fait dans le compose Zigbee2mqtt :(je n’utilise pas conbee car Z2M est plus efficace)
version: '3.5'
services:
  zigbee2mqtt:
    image: koenkk/zigbee2mqtt:latest
    container_name: zigbee2mqtt
    network_mode: host
    restart: unless-stopped
    ports:
      # Frontend port
      - 8082:8080
    volumes:
      - /srv/dev-disk-by-uuid-e1xxxx9f-cb11-4ca8-b08fxxxxxxxxxxx/docker/volume/zigbee2mqtt/data:/app/data
      - /run/udev:/run/udev:ro
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Europe/Paris
    privileged: true
    devices:
      # Make sure this matched your adapter location
      #- /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2461910-if00:/dev/ttyACM0
  mosquitto:
    image: eclipse-mosquitto
    container_name: mosquitto
    ports:
      - 1883:1883
      - 9001:9001
    volumes:
      - /srv/dev-disk-by-uuid-e132609fxxxxxxxx08f-xxxxx/docker/volume/mosquitto/config:/mosquitto/config
      - /srv/dev-disk-by-uuid-e132609f-cb11-4ca8-b08f-3f1x/docker/volume/mosquitto/data:/mosquitto/data
      - /srv/dev-disk-by-uuid-e132609f-cb11-4ca8-b08f-3f19x/docker/volume/mosquitto/log:/mosquitto/log
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Europe/Paris
C’est expliquer dans la doc, pour le chemin de la clé.
Most devices need at the very least the serial device path, like /dev/ttyUSB0 , but it is recommended to use device path from /dev/serial/by-id folder, e.g., /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C0F003D3-if01-port0 A list of available device paths can be found in Settings > System > Hardware > dot menu > All Hardware .
merci je viens de tester la même procédure avec les chemins :
  • /dev/ttyUSB0
  • /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2416901-if00
  • /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2416901-if00-port0
SANS SUCCÈS
Concernant " A list of available device paths can be found in Settings > System > Hardware > dot menu > **All Hardware"
J’ai bien PARAMETRE > SYSTEME > MATERIEL et cet écran rien de plus
Merci pour ce retour
Matériel (Cle USB) & config. identique : TOP
Par contre je suis un GRAND débutant du coup je ne comprends pas ce qu’il faut que je fasse.
Possible de m’expliquer ?
Cdt
Assurément, t’es un débutant en Docker, et peut-être en HA aussi.
Si tu ne comprend pas le fichier de @Oles67, tu devrais peut-être commencer par une installation plus simple comme HAOS. Et plus tard te mettre à Docker. Mais attaquer les 2 en même temps, ç’est du suicide.
Docker compose : Docker Compose overview | Docker Docs
Installation HAOS : Generic x86-64 - Home Assistant
Sinon pour ton problème, ton docker HA doit avoir accès au port usb.
Comment as-tu configuré ton docker (à priori sans Docker compose) ?
Encore merci
Pas rassurant tout cela
Je vais tenté une fois au bord du suicide je passe a plus simple
A suivre…
RE
Après analyse je suis reparti de 0 en réinstallant la totale.
Me voila avec
docker-compose.yml
version: ‹ 3.8 ›
services:
#Conteneur Home Assistant
homeassistant:
image: homeassistant/home-assistant:stable
container_name: homeassistant
environment:
- TZ=Europe/Paris
ports:
#Le port sur lequel sera accessible l’interface web PORT_EXPORTE:PORT_CONTENEUR
- 8123:8123
#On définit un « bind mount » pour conserver la configuration de Home-Assistant
volumes:
- ./home-assistant:/config
restart: always
#Conteneur du broker MQTT Mosquitto
mosquitto:
container_name: mqtt
#Pas besoin d’exporter de port vers l’extérieur
#ports:
# - 1883:1883
volumes:
#Bind mount pour la configuration
- ./mosquitto/config:/mosquitto/config
#Volumes pour les logs et les données persistantes
- mosquitto_data:/mosquitto/data
- mosquitto_log:/mosquitto/log
#Conteneur ZigBee2MQTT
zigbee2mqtt:
depends_on:
#Le conteneur mosquitto doit être démarré pour lancer le conteneur ZigBee2MQTT
- mosquitto
volumes:
- ./zigbee2mqtt:/app/data
ports:
#Port Zigbee2MQTT
- 8080:8080
devices:
#Adresse de votre dongle usb ZigBee à changer par la votre (uniquement avant les ‹ : ›)
- /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2416901-if00:/dev/ttyUSB0
volumes:
mosquitto_config:
mosquitto_data:
mosquitto_log:
zigbee_data:
et une configuration :
Version core-2023.10.5
Développement false
Supervisor false
Docker true
Utilisateur root
mais où trouver et/ou installer ma clé ConBee 2 ?
Cdt
