Le module myelectricaldata ne veut pas démarrer
J’ai installé le dépôt Alexbelgium, rempli le consentement et installé le module complémentaire.
Impossible de démarrer le module, le fichier config.yaml ne se cré pas.
Add-on: MyElectricalData
Use Enedis Gateway API to send data in your MQTT Broker (latest channel)
Add-on version: 0.9.2
You are running the latest version of this add-on.
System: Home Assistant OS 11.1 (amd64 / qemux86-64)
Home Assistant Core: 2023.10.5
Home Assistant Supervisor: 2023.10.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums
Provided by: GitHub - alexbelgium/hassio-addons: My homeassistant addons
/etc/cont-init.d/00-global_var.sh: executing
CONFIG_LOCATION=‹ /config/myelectricaldata/config.yaml ›
TZ=‹ Europe/Paris ›
mqtt_autodiscover=‹ true ›
verbose=‹ true ›
/etc/cont-init.d/01-custom_script.sh: executing
[18:20:08] INFO: Execute /config/addons_autoscripts/enedisgateway2mqtt.sh if existing
[18:20:08] INFO: … no script found
/etc/cont-init.d/32-nginx_ingress.sh: executing
/etc/cont-init.d/91-mqtt_autodiscover.sh: executing
[18:20:08] INFO: mqtt_autodiscover is defined in options, attempting autodiscovery…
[18:20:08] INFO: … MQTT service found, fetching server detail (you can enter those manually in your config file) …
MQTT_HOST=core-mosquitto
MQTT_PORT=1883
MQTT_SSL=false
MQTT_USERNAME=addons
MQTT_PASSWORD=cibohchoi5Zijaegi9ighahNoar9aiGooheeth5iPh5uuThe2xieyoo6lah8nah5
/etc/cont-init.d/99-run.sh: executing
[18:20:08] FATAL: Config file not found. The addon will create a new one, then stop. Please customize the file in /config/myelectricaldata/config.yaml before restarting.
[18:20:08] INFO: Starting nginx
[18:20:08] INFO: Starting the app
2023-10-29 18:20:09.518 - CRITICAL : Config file is not found (/data/config.yaml)
version core-2023.10.5
python_version 3.11.5
os_version 6.1.59
arch x86_64
GitHub API Calls Remaining 4951
Installed Version 1.33.0
Available Repositories 1321
Downloaded Repositories 7
host_os Home Assistant OS 11.1
supervisor_version supervisor-2023.10.1
agent_version 1.6.0
docker_version 24.0.6
disk_total 30.8 GB
disk_used 9.5 GB
board ova
installed_addons File editor (5.6.0), ESPHome (2023.10.3), Samba share (10.0.2), Terminal & SSH (9.7.1), Mosquitto broker (6.3.1), MyElectricalData (0.9.2)
dashboards 1
resources 4
views 4
oldest_recorder_run 25 octobre 2023 à 19:21
current_recorder_run 29 octobre 2023 à 18:00
estimated_db_size 101.30 MiB
database_version 3.41.2
Bj
Houla , modifie la police d’ecriture :wink:
Il te suffit d’aller voir la , tu as tout ce qui te faut , au besoin si tu as toujours des soucis viens nous le dire
tu n’as pas créer et configurer le fichier config.yaml dans le dossier /config/myelectricaldata/.
Merci pour votre réponse rapide!
Je pensais que le fichier config allait se créer quand on cliquait sur « enregistrer » dans l’onglet « configuration »…
J’ai suivi le tuto, j’avoue ne pas tout maitriser mais ça fonctionne avec la saniho card !
Il faut maintenant que je me penche sur l’intégration energy de HA qui ne me propose que le sensor myenedis.
J’aimerai aussi essayer influxdb. Apparemment il y a des choses sympa comme :https://github.com/HermesHonshappo/MyElectricalData-dashboard/blob/main/README.md
Les cartes de herveaurel ont l’air bien aussi!
Encore merci !
Pourrais-tu m’indiquer comment tu as réussi ?
Je ne comprends pas où mettre le fichier config pour que le module myelectricaldata fonctionne? Quand je le lance, j’ai droit a des erreurs, jusqu’à l’erreur fatale qui provoque l’arrêt du module
Merci d’avance pour ton aide
Finalement, en faisant bien attention à bien lire et relire et relire les tutos, c’est passé. Importation des données en cours
