en Node red ça donnerai un truc comme cela :
[{"id":"4185f335.4f68cc","type":"tab","label":"shadow","disabled":false,"info":""},{"id":"549948ee.639f08","type":"server-state-changed","z":"4185f335.4f68cc","name":"capt luminosite >50 lumens","server":"a537137.2d98df","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"capt luminosite","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"50","halt_if_type":"num","halt_if_compare":"gt","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":140,"y":209,"wires":[["c97d12c.a79fcf"],["c3672542.1af828"]]},{"id":"7455f892.32eeb8","type":"api-call-service","z":"4185f335.4f68cc","name":"group.marquisette_ext fermeture","server":"a537137.2d98df","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"group.marquisette_ext","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":870,"y":169,"wires":[[]]},{"id":"a2b5cb2c.5f4ca8","type":"api-call-service","z":"4185f335.4f68cc","name":"group.marquisettes_ext Ouverture","server":"a537137.2d98df","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_on","entityId":"group.marquisettes_ext","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":880,"y":269,"wires":[[]]},{"id":"84acaf17.15d69","type":"server-state-changed","z":"4185f335.4f68cc","name":"capt temperature ext <10°","server":"a537137.2d98df","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"capt temperature ext","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"10","halt_if_type":"num","halt_if_compare":"lt","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":150,"y":440,"wires":[["e64b802.7aac18"],[]]},{"id":"853a7e5b.97658","type":"api-call-service","z":"4185f335.4f68cc","name":"group.marquisettes_plissees Fermetture","server":"a537137.2d98df","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"group.marquisettes_plissees","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":680,"y":440,"wires":[[]]},{"id":"c7b512d7.91a5a","type":"comment","z":"4185f335.4f68cc","name":"Avec un capteur de lumière (Aeotec en Z-wave) je mesure la lumière et au moment qu’il depasse un seuil - je fais descendre les marquisette (extérieur). ","info":"","x":570,"y":40,"wires":[]},{"id":"6267a3f6.25e3ac","type":"comment","z":"4185f335.4f68cc","name":"Par contre si a l’extérieur il fait en dessous de 10degres, je veut que les plissé (intérieur) se ferme","info":"","x":410,"y":380,"wires":[]},{"id":"e64b802.7aac18","type":"looptimer","z":"4185f335.4f68cc","duration":"90","units":"Second","maxloops":"10","maxtimeout":"1","maxtimeoutunits":"Hour","name":"","x":400,"y":440,"wires":[["853a7e5b.97658"],[]]},{"id":"c97d12c.a79fcf","type":"looptimer","z":"4185f335.4f68cc","duration":"90","units":"Second","maxloops":"10","maxtimeout":"1","maxtimeoutunits":"Hour","name":"","x":360,"y":169,"wires":[["7455f892.32eeb8"],[]]},{"id":"c3672542.1af828","type":"looptimer","z":"4185f335.4f68cc","duration":"90","units":"Second","maxloops":"10","maxtimeout":"1","maxtimeoutunits":"Hour","name":"","x":360,"y":269,"wires":[["a2b5cb2c.5f4ca8"],[]]},{"id":"2b046bca.beec64","type":"comment","z":"4185f335.4f68cc","name":"verification ttes les 90sec, 10 changements de statut / heure","info":"","x":500,"y":229,"wires":[]},{"id":"bdf828c3.e2a728","type":"comment","z":"4185f335.4f68cc","name":"verification ttes les 90sec, 10 changements de statut / heure","info":"","x":500,"y":129,"wires":[]},{"id":"90bd9701.0288a8","type":"comment","z":"4185f335.4f68cc","name":"Et si lumières en dessous du seuil - les marquisette remonte.","info":"","x":291,"y":80,"wires":[]},{"id":"a537137.2d98df","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
mais @Shadow , utilises tu Node red?
