beh, tu utilises ZHA, il ne faut pas se plaindre ![]()
Tu serais sur Z2M, tu n’aurais aucun soucis, au pire attendre 1 mois pour l’ajout des nouveaux matériels.
Pas comme ZHA, ou tu peux attendre 1 an et toujours rien…
Si tu as besoin des DP Tuya je peux leur demander…
Je vais tout migrer, je vais en profiter pour changer mon mini pc et refaire une installation propre de HA.
Voici le debug file de Tuya - liste des DP et ranges / description:
"Pro_Key": "",
"Dp_Data": [
"id": 1,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "forward_energy_total",
"defaultValue": "0",
"editPermission": true,
"extContent": "{\"trigger\":\"direct\"}",
"mode": "ro",
"property": {
"unit": "kW·h",
"min": 0,
"max": 999999999,
"scale": 2,
"step": 1,
"type": "value"
"name": "正向总有功电量",
"attr": 1152,
"trigger": "direct"
"id": 2,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "reverse_energy_total",
"mode": "ro",
"property": {
"unit": "kW·h",
"min": 0,
"max": 999999999,
"scale": 2,
"step": 1,
"type": "value"
"name": "反向总有功电量",
"attr": 1152,
"trigger": "direct"
"id": 9,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "power_total",
"defaultValue": "-999999999",
"mode": "ro",
"property": {
"unit": "kW",
"min": -999999999,
"max": 999999999,
"scale": 3,
"step": 1,
"type": "value"
"name": "总有功功率",
"attr": 1152,
"trigger": "direct"
"id": 101,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "forward_energy_circuit_1",
"editPermission": false,
"extContent": "",
"mode": "ro",
"property": {
"unit": "kW·h",
"min": 0,
"max": 999999999,
"scale": 2,
"step": 1,
"type": "value"
"name": "正向有功电量1",
"attr": 0
"id": 102,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "reserve_energy_circuit_1",
"extContent": "",
"mode": "ro",
"property": {
"unit": "kW·h",
"min": 0,
"max": 999999999,
"scale": 2,
"step": 1,
"type": "value"
"name": "反向有功电量1",
"attr": 0
"id": 103,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "forward_energy_circuit_2",
"extContent": "",
"mode": "ro",
"property": {
"unit": "kW·h",
"min": 0,
"max": 999999999,
"scale": 2,
"step": 1,
"type": "value"
"name": "正向有功电量2",
"attr": 0
"id": 104,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "reserve_energy_circuit_2",
"extContent": "",
"mode": "ro",
"property": {
"unit": "kW·h",
"min": 0,
"max": 999999999,
"scale": 2,
"step": 1,
"type": "value"
"name": "反向有功电量2",
"attr": 0
"id": 105,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "current_total",
"extContent": "",
"mode": "ro",
"property": {
"unit": "A",
"min": 0,
"max": 999999999,
"scale": 3,
"step": 1,
"type": "value"
"name": "总电流",
"attr": 0
"id": 106,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "voltage",
"extContent": "",
"mode": "ro",
"property": {
"unit": "V",
"min": 0,
"max": 999999999,
"scale": 1,
"step": 1,
"type": "value"
"name": "电压",
"attr": 0
"id": 107,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "current_circuit_1",
"extContent": "",
"mode": "ro",
"property": {
"unit": "A",
"min": 0,
"max": 999999999,
"scale": 3,
"step": 1,
"type": "value"
"name": "电流1",
"attr": 0
"id": 108,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "power_circuit_1",
"extContent": "",
"mode": "ro",
"property": {
"unit": "kW",
"min": -999999999,
"max": 999999999,
"scale": 3,
"step": 1,
"type": "value"
"name": "有功功率1",
"attr": 0
"id": 109,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "pf_circuit_1",
"extContent": "",
"mode": "ro",
"property": {
"unit": "",
"min": 0,
"max": 100,
"scale": 2,
"step": 1,
"type": "value"
"name": "功率因数1",
"attr": 0
"id": 110,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "current_circuit_2",
"extContent": "",
"mode": "ro",
"property": {
"unit": "A",
"min": 0,
"max": 999999999,
"scale": 3,
"step": 1,
"type": "value"
"name": "电流2",
"attr": 0
"id": 111,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "power_circuit_2",
"extContent": "",
"mode": "ro",
"property": {
"unit": "kW",
"min": -999999999,
"max": 999999999,
"scale": 3,
"step": 1,
"type": "value"
"name": "有功功率2",
"attr": 0
"id": 112,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "pf_circuit_2",
"extContent": "",
"mode": "ro",
"property": {
"unit": "",
"min": 0,
"max": 100,
"scale": 2,
"step": 1,
"type": "value"
"name": "功率因数2",
"attr": 0
"id": 113,
"iconname": "",
"subType": "value",
"desc": "",
"type": "obj",
"code": "frequency",
"extContent": "",
"mode": "ro",
"property": {
"unit": "Hz",
"min": 0,
"max": 999999999,
"scale": 0,
"step": 1,
"type": "value"
"name": "频率",
"attr": 0
