Bonjour à tous
Depuis hier mes modules Zigbee sont figés, plus d’action possible.
J’ai une clé Conbee II je suis ne Z2M et un brocker MQTT
Voici une partie des logs Z2M
{timeout:10000,disableResponse:false,disableRecovery:false,disableDefaultResponse:false,direction:0,reservedBits:0,writeUndiv:false}) failed (no response received (229) waiting for response TIMEOUT)'|
|[2024-09-29 07:58:27] info: |z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{message:Publish 'set' 'state' to 'prise_pc' failed: 'Error: ZCL command 0xa4c138198fb8cf1f/1 genOnOff.on({}, {\timeout\:10000,\disableResponse\:false,\disableRecovery\:false,\disableDefaultResponse\:false,\direction\:0,\reservedBits\:0,\writeUndiv\:false}) failed (no response received (229) waiting for response TIMEOUT)',meta:{friendly_name:prise_pc},type:zigbee_publish_error}'|
|[2024-09-29 07:58:27] error: |z2m: Publish 'set' 'state' to 'prise_tv' failed: 'Error: ZCL command 0xa4c13803cc0b6d6f/1 genOnOff.on({}, {timeout:10000,disableResponse:false,disableRecovery:false,disableDefaultResponse:false,direction:0,reservedBits:0,writeUndiv:false}) failed (no response received (228) waiting for response TIMEOUT)'|
|[2024-09-29 07:58:27] info: |z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{message:Publish 'set' 'state' to 'prise_tv' failed: 'Error: ZCL command 0xa4c13803cc0b6d6f/1 genOnOff.on({}, {\timeout\:10000,\disableResponse\:false,\disableRecovery\:false,\disableDefaultResponse\:false,\direction\:0,\reservedBits\:0,\writeUndiv\:false}) failed (no response received (228) waiting for response TIMEOUT)',meta:{friendly_name:prise_tv},type:zigbee_publish_error}'|
et Mosquitto Brocker
2024-09-29 07:58:49: New connection from 172.30.32.1:58202 on port 1883.
error: received null username or password for unpwd check
2024-09-29 07:58:49: Client nodered_70351af87a2b8266 disconnected, not authorised.
2024-09-29 07:58:58: New connection from 95.214.27.31:42464 on port 1883.
2024-09-29 07:58:58: Client <unknown> disconnected due to protocol error.
2024-09-29 07:59:02: New connection from 178.215.236.87:51864 on port 1883.
2024-09-29 07:59:04: New connection from 172.30.32.1:49548 on port 1883.
2024-09-29 07:59:04: Client nodered_70351af87a2b8266 disconnected, not authorised.
2024-09-29 07:59:19: New connection from 172.30.32.1:42422 on port 1883.
2024-09-29 07:59:19: Client nodered_70351af87a2b8266 disconnected, not authorised.
2024-09-29 07:59:26: New connection from 147.185.133.40:60766 on port 1883.
2024-09-29 07:59:26: Client <unknown> disconnected due to protocol error.
2024-09-29 07:59:26: New connection from 147.185.133.40:60780 on port 1883.
2024-09-29 07:59:34: New connection from 172.30.32.1:47146 on port 1883.
2024-09-29 07:59:34: Client nodered_70351af87a2b8266 disconnected, not authorised.
2024-09-29 07:59:43: New connection from 104.168.32.95:48578 on port 1883.
2024-09-29 07:59:46: Client <unknown> closed its connection.
2024-09-29 07:59:49: New connection from 172.30.32.1:57026 on port 1883.
2024-09-29 07:59:49: Client nodered_70351af87a2b8266 disconnected, not authorised.
Je vois une erreur dans mon user et MDP mais je n’ai rien changer.
Je suis perdu
J’espère avoir mis les bonnes choses pour une analyse.
En attendant vos retours
David
