Y a plus qu’à…Merci Thomas. Pas simple pour un débutant comme moi, ton code m’aurait vraiment facilité la vie
Après ce n’est qu’une adaptation de la documentation de la carte button-card
(stylisé différemment) :
- type: custom:button-card
entity: 'sensor.raspi_temp'
icon: 'mdi:raspberry-pi'
aspect_ratio: 1/1
styles:
card:
- background-color: '#000044'
- border-radius: 10%
- padding: 10%
- color: ivory
- font-size: 10px
- text-shadow: 0px 0px 5px black
- text-transform: capitalize
grid:
- grid-template-areas: '"i temp" "n n" "cpu cpu" "ram ram" "sd sd"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: 1fr min-content min-content min-content min-content
name:
- font-weight: bold
- font-size: 13px
- color: white
- align-self: middle
- justify-self: start
- padding-bottom: 4px
img_cell:
- justify-content: start
- align-items: start
- margin: none
icon:
- color: >
if (entity.state < 60) return 'lime';
if (entity.state >= 60 && entity.state < 80) return 'orange';
else return 'red';
- width: 70%
- margin-top: -10%
custom_fields:
temp:
- align-self: start
- justify-self: end
cpu:
- padding-bottom: 2px
- --text-color-sensor: '[[[ if (states["sensor.raspi_cpu"].state > 80) return "red"; ]]]'
ram:
- --text-color-sensor: '[[[ if (states["sensor.raspi_ram"].state > 80) return "red"; ]]]'
sd:
- --text-color-sensor: '[[[ if (states["sensor.raspi_sd"].state > 80) return "red"; ]]]'
custom_fields:
temp: >
return `<ha-icon
icon="mdi:thermometer"
style="width: 12px; height: 12px; color: yellow;">
</ha-icon><span>${entity.state}°C</span>`
cpu: >
return `<ha-icon
icon="mdi:server"
style="width: 12px; height: 12px; color: deepskyblue;">
</ha-icon><span>CPU: <span style="color: var(--text-color-sensor);">${states['sensor.raspi_cpu'].state}%</span></span>`
ram: >
return `<ha-icon
icon="mdi:memory"
</ha-icon><span>RAM: <span style="color: var(--text-color-sensor);">${states['sensor.raspi_ram'].state}%</span></span>`
sd: >
return `<ha-icon
icon="mdi:harddisk"
</ha-icon><span>SD: <span style="color: var(--text-color-sensor);">${states['sensor.raspi_sd'].state}%</span></span>`
Désolé il fallait que je fasse un peu de ménage dans le code.
@Clemalex a déjà donné une idée du code mais voici exactement le code que j’utilise :
entity: binary_sensor.updater
icon: mdi:home-assistant
name: HOME ASSISTANT
# tap_action: !include popup_card/ha.yaml
double_tap_action:
action: call-service
service: homeassistant.restart
card_mod:
style: |
ha-card {
--paper-card-background-color: 'rgba(11, 11, 11, 0.00)';
box-shadow: 2px 2px rgba(0,0,0,0.0);
border-radius: 15px;
aspect_ratio: 1/1
styles:
card:
- color: 'var(--text-medium-color)'
- text-shadow: 0px 0px 0px white
- background-color: var(--primary-background-color)
- padding-left: 10px
- border-radius: 20px
- padding: 10%
- font-size: 15px
grid:
- grid-template-areas: '"i i" "n n" "cpu cpu" "ram ram" "sd sd"'
name:
- font-weight: bold
- font-size: 13px
- color: 'var(--text-color)'
icon:
- color: >
if (entity.state == 'on') return 'orange';
return 'deepskyblue';
- width: 70%
- animation: >
[[[ if (entity.state == 'on') return 'blink 2s ease infinite'; ]]]
custom_fields:
cpu:
- --text-color-sensor: '[[[if (states["sensor.version_disponible"].state != states["sensor.version_installee"].state) return "red";else return "deepskyblue"]]]'
ram:
sd:
custom_fields:
cpu: >
return `<ha-icon icon="mdi:home-assistant" style="width: 20px; height: 20px; color: deepskyblue;"></ha-icon>
<span>Disponible: <span style="color: var(--text-color-sensor);">${states['sensor.version_disponible'].state}</span></span>`
ram: >
return `<ha-icon icon='mdi:home-assistant' style='width: 20px; height: 20px; color: deepskyblue;'></ha-icon>
<span>Instalée: <span style='color: var(--text-color-sensor);'>${states['sensor.version_installee'].state}</span></span>`
sd: >
return `<ha-icon icon='hacs:hacs' style='width: 20px; height: 20px; color: deepskyblue;'></ha-icon>
<span>MàJ HACS: <span style='color: var(--text-color-sensor);'>${states['sensor.hacs'].state} intégrations</span></span>`
@JournaldeThomas pour la partie docker cela n’est possible que pour les containers qui se trouve sur le meme host que ton ha / addon hacs ?
car perso j’utilise ceci pour savoir si il sont up ou down au niveau http pure sachant que c’est sur une autre machine/host que les dockers sont installer :
- platform: command_line
command: response=$(curl -LIk -m 3 http://192.168.52.27:9000 -o /dev/null -w "%{http_code}\n" -s); test "$response" -ge 200 && echo "Online" || echo "Offline"
scan_interval: 90
value_template: "{{ value }}"
par contre pour l’image de fond c’est quel card que tu utiliser ?
car de mon coter j’ai fait comme ça :
et si j’ai un soucis sur un container, voici le résultat : (merci à @Clemalex )
Oui je pense que la partie Docker n’est possible que pour les containers qui se trouve sur le même host car si j’ai bien compris il s’appuie sur le daemon Docker.
Pour l’image de fond j’utilise en fait picture-elements
- type: picture-elements
image: /local/lovelace/background/docker2.png
elements:
XXXXXX
C’est un peu chiant à mettre en place au départ pour le bon position de tous les docker mais j’ai trouvé que le visuel en valait la peine
Sympa le clignotement et la mise en avant lorsque le container s’arrête. C’est sur ma to do
merci thomas.
voilà le résultat avec une légère modif sur les ombres de la police et une petite faute à « installée » corrigée.
Par contre le bouton est énorme…
type: 'custom:button-card'
icon: 'mdi:home-assistant'
card_mod: null
style: |
ha-card {
aspect_ratio: 1/1
styles:
card:
- color: var(--text-medium-color)
- padding: 10%
- font-size: 15px
- border-radius: 12px
- size: 50px
- border: 2px solid red
grid:
name:
- font-weight: bold
- font-size: 13px
- color: var(--text-color)
icon:
- color: |
- width: 70%
- animation: |
custom_fields:
cpu:
- '--text-color-sensor': >-
"deepskyblue"]]]
ram:
sd:
custom_fields:
cpu: |
ram: |
<span>Installée: <span style='color: var(--text-color-sensor);'>${states['sensor.version_installee'].state}</span></span>`
sd: |
Bonjour, tu peux utiliser une image qui évite de mettre docker en mode daemon tcp.
https://github.com/Tecnativa/docker-socket-proxy
je vous remercie tous pour votre aide, votre temps, et les partages.
Sans vous je ne serais pas sous Ha ou voir meme en domotique a la maison.
Merci pour le partage. Pour le boutton système, est il possible de mettre le nombre de module complémentaire pouvant bénéficier d’une mise à jour ?
Dans mon cas, 1 par exemple :
Aurais tu aussi ton code pour le nas et raspberry ?
Super taff !!!
Salut @JournaldeThomas,
J’ai vu sur le screenshot de ton dépôt GitHub des jauges imbriquées comme sur WatchOS pour suivre les paramètres de tes machines.
Est une carte de ta création ou une custom trouvée sur Internet ?
Il s’agit de l’apexcard avec le mode radialbar. Je n’avais pas fait le rapprochement avec wathOS mais oui tu as raison c’est ressemblant
J’avance doucement mais surement sur mon dashboard. C’est fou le temps que ça peut prendre
J’ai pas mal revisité mes principaux onglets. J’ai essayé d’homogénéiser les différentes cartes malgré le fait que j’ai pioché des idées à droite et à gauche. Je trouve notamment la première page plus conviviale que précédemment tout en ayant de très nombreuses informations. Il me reste à peaufiner les popup qui s’ouvrent lorsqu’on double clic sur les différentes cartes des pièces.
De même la page système a été un peu revu en essayant de définir une spécificité pour chaque colonne. La première colonne concerne le réseau local avec la remontée d’infos du matériel Unifi pour lequel j’ai craqué dernièrement. La deuxième colonne concerne la baie technique et le serveur. Et enfin la dernière colonne concerne plus spécifiquement Home Assistant et les différents conteneurs que j’ai installé sur le serveur.
Un nouvel onglet a fait son apparition suite à l’achat d’une imprimante 3D. Depuis Home Assistant via Octoprint je peux donc contrôler mon imprimante : une prise connectée me permet de l’allumer et de l’éteindre. Un automatisme fait que lorsque la prise est allumé alors la connexion entre l’imprimante et Octoprint se fait aussi. Une caméra sur le raspberry me permet de suivre l’impression. De même j’essaie de suivre ma consommation de filament et d’estimer la quantité de filament qu’il me reste. Pour cela j’ai suivi l’excellent tuto de @jybi89
Dernièrement j’ai également installer un raspberry pi pour surveiller une maison de famille. En fait sur ce raspberry pi je ne fais tourner que zigbee2mqtt qui envoie toutes les informations sur mon broker MQTT et je n’ai eu qu’à faire un petit dashboard tout simple pour avoir les visualiser facilement. D’autres capteurs seront ajoutés au fur et à mesure du temps mais d’ores et déjà cela me permet d’avoir une certaine visibilité.
Toute cette configuration est désormais en partage sur GitHub comme le préconise @oncleben31 dans son tuto
Bien sûr c’est toujours « En cours » et je me demande si cela sera vraiment terminé un jour j’ai bien en tête quelques petites améliorations sur les onglets présentés ici pour plus de visibilité sur certaines données. Et puis il me faut finaliser les autres onglets : sécurité / surveillance ; plantes / jardin ; données diverses. Je ne manquerais pas de vous tenir au courant
J’aime vraiment ton interface ! Merci pour le partage !
Par contre je ne peux m’empêcher de commenter la taille de la base de données…
=> Elle est énorme !
Pas de soucis avec une telle taille ?
C’est superbe tout ça.
Tu peux donner la source de toutes les icones des dockers ?
Merci d’avance
Philippe
Je les ai faites moi même en prenant les logo des différents produits.
Je viens de les mettre à dispo sur le github : home-assistant-config/www/icons at main · journaldethomas/home-assistant-config · GitHub
Super merci beaucoup.
Je vais les intégrer pour les dockers communs aux votres.
Pour les autres j’ai aussi fait des montages ! Ça va m’être utile aussi pour les icônes de Dashy
Amitiés
Philippe
Bonjour Thomas,
Merci pour tes tutos toujours instructifs.
Intéressé par le monitoring/contrôle des containers Docker, j’ai installé le custom_component Monitor Docker
Il me reste visiblement une étape que je n’arrive pas à faire : celle de déclarer un volume /var/run/docker.sock en container Home Assistant
Pour information, je suis en Home Assistant Supervised
Pas familier avec portainer, quelqu’un saurait-il me guider pour créer ce volume ? merci par avance pour votre aide
Félicitations pour ton super thème. Beau travail.
J’aimerai bien ajouter la card docker au mon dashboard mais je bloque.
Mon HA est installé sur mon Synology via un VMM (virtual machine)
J’ai installé l’intégration monitor_docker
J’ai ajouté le code dans mon configuration.yaml
Mais aucun sensor ne remonte dans mon HA.
Est-ce que quelqu’un a une configuration similaires et a trouvé une solution ?
Bonjour Christian,
Pour moi il n’y a pas de volume à créer… en tout cas je n’ai rien fait de tel de mon côté. Juste à déclarer le volume dans la configuration du container :
volumes:
- /var/run/docker.sock:/var/run/docker.sock
Mais je ne suis pas sur une installation HA Supervised. Il faudrait que je teste sur une telle configuration.
