Ce matin j’ai cliqué un peu trop vite sur les mises à jour et hop enedisgateway2mqtt mis à jour de 0.77 à 0.8.10… Du coup, dans l’addon qui s’appelle désormais MyElectricalData, j’ai le message d’erreur suivant:
2022-12-13 07:10:00.142 - WARNING : - 2021-03 => 677.93kW
2022-12-13 07:10:00.601 - WARNING : - 2021-04 => 517.41kW
2022-12-13 07:10:00.897 - WARNING : - 2021-05 => 535.23kW
2022-12-13 07:10:01.208 - WARNING : - 2021-06 => 592.03kW
2022-12-13 07:10:01.462 - WARNING : - 2021-07 => 572.22kW
2022-12-13 07:10:01.753 - WARNING : - 2021-08 => 743.8kW
2022-12-13 07:10:02.060 - WARNING : - 2021-09 => 674.66kW
2022-12-13 07:10:02.503 - WARNING : - 2021-10 => 599.27kW
2022-12-13 07:10:02.776 - WARNING : - 2021-11 => 518.04kW
2022-12-13 07:10:03.062 - WARNING : - 2021-12 => 445.21kW
2022-12-13 07:10:03.306 - WARNING : - 2022-01 => 653.49kW
2022-12-13 07:10:03.564 - WARNING : - 2022-02 => 969.45kW
2022-12-13 07:10:03.837 - WARNING : - 2022-03 => 584.71kW
2022-12-13 07:10:04.145 - WARNING : - 2022-04 => 392.62kW
2022-12-13 07:10:04.447 - WARNING : - 2022-05 => 230.16kW
2022-12-13 07:10:04.745 - WARNING : - 2022-06 => 189.82kW
2022-12-13 07:10:05.236 - WARNING : - 2022-07 => 187.94kW
2022-12-13 07:10:05.547 - WARNING : - 2022-08 => 375.99kW
2022-12-13 07:10:05.847 - WARNING : - 2022-09 => 349.84kW
2022-12-13 07:10:06.147 - WARNING : - 2022-10 => 267.82kW
2022-12-13 07:10:06.464 - WARNING : - 2022-11 => 231.04kW
2022-12-13 07:10:06.757 - WARNING : - 2022-12 => 346.34kW
2022-12-13 07:10:08.804 - WARNING : Migration des "production_daily"
2022-12-13 07:10:08.812 - WARNING : Migration des "production_detail"
2022-12-13 07:10:08.832 - INFO : Configure Databases
/app/models/database.py:114: SAWarning: Column 'consumption_daily.id' is marked as a member of the primary key for table 'consumption_daily', but has no Python-side or server-side default generator indicated, nor does it indicate 'autoincrement=True' or 'nullable=True', and no explicit value is passed. Primary key columns typically may not store NULL.
day = self.session.scalars(query).one_or_none()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1900, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 736, in do_execute
cursor.execute(statement, parameters)
sqlite3.IntegrityError: NOT NULL constraint failed: consumption_daily.id
The above exception was the direct cause of the following exception:
File "/app/main.py", line 9, in <module>
from models.ajax import Ajax
File "/app/models/ajax.py", line 3, in <module>
from models.jobs import Job
File "/app/models/jobs.py", line 6, in <module>
from models.database import Database
File "/app/models/database.py", line 1141, in <module>
Database().init_database()
File "/app/models/database.py", line 114, in init_database
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1771, in scalars
return self.execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1660, in execute
) = compile_state_cls.orm_pre_session_exec(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/context.py", line 312, in orm_pre_session_exec
session._autoflush()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 2257, in _autoflush
util.raise_(e, with_traceback=sys.exc_info()[2])
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 208, in raise_
raise exception
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 2246, in _autoflush
self.flush()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 3386, in flush
self._flush(objects)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 3526, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/langhelpers.py", line 70, in __exit__
compat.raise_(
raise exception
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 3486, in _flush
flush_context.execute()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/unitofwork.py", line 456, in execute
rec.execute(self)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/unitofwork.py", line 630, in execute
util.preloaded.orm_persistence.save_obj(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/persistence.py", line 245, in save_obj
_emit_insert_statements(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/persistence.py", line 1238, in _emit_insert_statements
result = connection._execute_20(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1705, in _execute_20
return meth(self, args_10style, kwargs_10style, execution_options)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/elements.py", line 333, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1572, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1943, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2124, in _handle_dbapi_exception
util.raise_(
raise exception
sqlalchemy.exc.IntegrityError: (raised as a result of Query-invoked autoflush; consider using a session.no_autoflush block if this flush is occurring prematurely)
(sqlite3.IntegrityError) NOT NULL constraint failed: consumption_daily.id
[SQL: INSERT INTO consumption_daily (usage_point_id, date, value, blacklist, fail_count) VALUES (?, ?, ?, ?, ?)]
[parameters: ('24390738009939', '2019-01-15 00:00:00.000000', 0, 0, 0)]
(Background on this error at: https://sqlalche.me/e/14/gkpj)
[07:10:11] FATAL: The app has crashed. Are you sure you entered the correct config options?
Je crois comprendre que la migration s’est correctement réalisée mais avant de faire une grosse con…rie, je préfère vous demander la conduite à tenir sachant que du coup je n’ai pas fait de sauvegarde de la base de données avant cette mise à jour (clic trop rapide!!)
bizarrement dans le répertoire /local/config/enedisgateway2mqtt je n’ai pas de enedisgateway.db.migrate mais toujours le fichier initial. Je ne sais pas où trouver ce fameux fichier cache.db non plus.
Du coup je me demande si la migration s’est bien déroulée… bref je pensais que les deux pouvaient tourner indépendamment mais visiblement non. Donc là je suis un peu pommé…
Je n’ai pas encore fait une demande de consentement pour la nouvelle version tant que je ne suis pas sure de l’odre des actions à réaliser au vue de mon cas particulier.
Quelqu’un pourrait il m’aiguiller sur les différentes étapes ? Merci
