Merci pour ta confirmation @ClassicRed .
Du coup, depuis que j’ai migré sur MyElectricalData (Version : 0.8.8-dev), l’addon bloque au chargement de la configuration.
Quelqu’un a déjà eu ce problème ?
2022-12-03 09:36:49.726 - INFO : LOADING CONFIGURATION...
2022-12-03 09:36:49.727 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-12-03 09:36:49.727 - INFO : 22149782812123
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1900, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 736, in do_execute
cursor.execute(statement, parameters)
sqlite3.OperationalError: no such column: usage_points.consentement_expiration
The above exception was the direct cause of the following exception:
File "/app/main.py", line 46, in <module>
DB.set_usage_point(usage_point_id, data)
File "/app/models/database.py", line 205, in set_usage_point
usage_points = self.session.scalars(query).one_or_none()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1771, in scalars
return self.execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1712, in execute
result = conn._execute_20(statement, params or {}, execution_options)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1705, in _execute_20
return meth(self, args_10style, kwargs_10style, execution_options)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/elements.py", line 333, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1572, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1943, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2124, in _handle_dbapi_exception
util.raise_(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 208, in raise_
raise exception
sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) no such column: usage_points.consentement_expiration
[SQL: SELECT usage_points.usage_point_id, usage_points.name, usage_points.cache, usage_points.consumption, usage_points.consumption_detail, usage_points.production, usage_points.production_detail, usage_points.consumption_price_base, usage_points.consumption_price_hc, usage_points.consumption_price_hp, usage_points.production_price, usage_points.offpeak_hours_0, usage_points.offpeak_hours_1, usage_points.offpeak_hours_2, usage_points.offpeak_hours_3, usage_points.offpeak_hours_4, usage_points.offpeak_hours_5, usage_points.offpeak_hours_6, usage_points."plan", usage_points.refresh_addresse, usage_points.refresh_contract, usage_points.token, usage_points.progress, usage_points.progress_status, usage_points.enable, usage_points.consentement_expiration, usage_points.call_number, usage_points.quota_reached, usage_points.quota_limit, usage_points.quota_reset_at, usage_points.last_call, usage_points.ban, usage_points.consumption_max_date, usage_points.consumption_detail_max_date, usage_points.production_max_date, usage_points.production_detail_max_date
FROM usage_points
WHERE usage_points.usage_point_id = ?]
[parameters: ('22149782812123',)]
(Background on this error at: https://sqlalche.me/e/14/e3q8)
[09:36:50] FATAL: The app has crashed. Are you sure you entered the correct config options?
Voici ma conf:
cycle: 14400
debug: true
wipe_influxdb: false
home_assistant:
enable: true
discovery: true
discovery_prefix: homeassistant
influxdb:
enable: true
hostname: influxdb
port: 8086
token: token:token
org: "-"
bucket: "DATABASE/RETENTION"
asynchronous: "false"
mqtt:
enable: true
hostname: momo
port: 1883
username: "test"
password: "test"
prefix: myelectricaldata
client_id: myelectricaldata
retain: true
qos: 0
myelectricaldata:
"22149782812540":
enable: "true"
token: 1XUPTOKEN
addresses: "true"
cache: "true"
consumption: "true"
consumption_detail: "true"
consumption_price_base: "0.1679"
consumption_price_hc: "0.1422"
consumption_price_hp: "0.1769"
consumption_max_date: "2021-07-03"
consumption_detail_max_date: "2021-07-03"
offpeak_hours_0: 01H36-8H06;12H06-13H36 # LUNDI
offpeak_hours_1: 01H36-8H06;12H06-13H36 # MARDI
offpeak_hours_2: 01H36-8H06;12H06-13H36 # MERCREDI
offpeak_hours_3: 01H36-8H06;12H06-13H36 # JEUDI
offpeak_hours_4: 01H36-8H06;12H06-13H36 # VENDREDI
offpeak_hours_5: 01H36-8H06;12H06-13H36 # SAMEDI
offpeak_hours_6: 01H36-8H06;12H06-13H36 # DIMANCHE
plan: HC/HP
production: "false"
production_detail: "false"
production_price: "0.0"
production_max_date: "2021-06-01"
production_detail_max_date: "2021-06-01"
refresh_addresse: "false"
refresh_contract: "false"
