MyElectricalData
j’ai tout appliqué en long en large , nouveau token sur la nouvelle passerelle
résultat :
Starting...
/etc/cont-init.d/00-banner.sh: executing
 Add-on: Enedisgateway2mqtt Dev
 use Enedis Gateway API to send data in your MQTT Broker (latest-dev channel)
 Add-on version: 0.8.0-dev
 You are running the latest version of this add-on.
 System: Debian GNU/Linux 11 (bullseye)  (amd64 / qemux86-64)
 Home Assistant Core: 2022.11.4
 Home Assistant Supervisor: 2022.11.2
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums
 https://github.com/alexbelgium/hassio-addons
/etc/cont-init.d/00-global_var.sh: executing
CONFIG_LOCATION='/config/enedisgateway2mqtt_dev/config.yaml'
TZ='Europe/Paris'
/etc/cont-init.d/01-custom_script.sh: executing
[11:43:36] INFO: Execute /config/enedisgateway2mqtt-dev.sh if existing
[11:43:36] INFO: ... no script found
/etc/cont-init.d/99-run.sh: executing
[11:43:36] INFO: Using config file found in /config/enedisgateway2mqtt_dev/config.yaml
Config file is a valid yaml
creating symlink
[11:43:36] INFO: Using database file found in /config/enedisgateway2mqtt_dev/enedisgateway.db
[11:43:36] INFO: Starting the app
INFO  [alembic.runtime.migration] Context impl SQLiteImpl.
INFO  [alembic.runtime.migration] Will assume non-transactional DDL.
2022-11-24 11:44:15.736 -  WARNING : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ▲ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:15.736 -  WARNING :  MIGRATION DE L'ANCIENNE BASE DE DONNÉES VERS LA NOUVELLE STRUCTURE.
2022-11-24 11:44:15.737 -  WARNING :  Migration des "consumption_daily"
2022-11-24 11:44:15.767 -  WARNING :   - 2022 => 18.85kW
2022-11-24 11:44:15.795 -  WARNING :  Migration des "consumption_detail"
2022-11-24 11:44:15.833 -  WARNING :   - 2022-01 => 0.15kW
2022-11-24 11:44:15.889 -  WARNING :   - 2022-02 => 347.3kW
2022-11-24 11:44:15.977 -  WARNING :   - 2022-03 => 386.99kW
2022-11-24 11:44:16.126 -  WARNING :   - 2022-04 => 393.43kW
2022-11-24 11:44:16.243 -  WARNING :   - 2022-05 => 334.18kW
2022-11-24 11:44:16.340 -  WARNING :   - 2022-06 => 226.75kW
2022-11-24 11:44:16.461 -  WARNING :   - 2022-07 => 242.79kW
2022-11-24 11:44:16.557 -  WARNING :   - 2022-08 => 252.74kW
2022-11-24 11:44:16.650 -  WARNING :   - 2022-09 => 218.93kW
2022-11-24 11:44:16.767 -  WARNING :   - 2022-10 => 267.5kW
2022-11-24 11:44:16.889 -  WARNING :   - 2022-11 => 283.67kW
2022-11-24 11:44:17.253 -  WARNING :  Migration des "production_daily"
2022-11-24 11:44:17.254 -  WARNING :  Migration des "production_detail"
2022-11-24 11:44:17.257 -     INFO :  Configure Databases
2022-11-24 11:44:19.091 -     INFO :   => day
2022-11-24 11:44:19.094 -     INFO :   => call_number
2022-11-24 11:44:19.095 -     INFO :   => max_call
2022-11-24 11:44:19.097 -     INFO :   => version
2022-11-24 11:44:19.099 -     INFO :   => lock
2022-11-24 11:44:19.101 -     INFO :   => lastUpdate
2022-11-24 11:44:19.101 -     INFO :   Success
2022-11-24 11:44:19.393 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:19.393 -     INFO : ▌│█║▌║▌║  __  __         _____  _              _          _               _  ____          _           ║▌║▌║█│▌
2022-11-24 11:44:19.393 -     INFO : ▌│█║▌║▌║ |  \/  | _   _ | ____|| |  ___   ___ | |_  _ __ (_)  ___   __ _ | ||  _ \   __ _ | |_   __ _  ║▌║▌║█│▌
2022-11-24 11:44:19.393 -     INFO : ▌│█║▌║▌║ | |\/| || | | ||  _|  | | / _ \ / __|| __|| '__|| | / __| / _` || || | | | / _` || __| / _` | ║▌║▌║█│▌
2022-11-24 11:44:19.393 -     INFO : ▌│█║▌║▌║ | |  | || |_| || |___ | ||  __/| (__ | |_ | |   | || (__ | (_| || || |_| || (_| || |_ | (_| | ║▌║▌║█│▌
2022-11-24 11:44:19.394 -     INFO : ▌│█║▌║▌║ |_|  |_| \__, ||_____||_| \___| \___| \__||_|   |_| \___| \__,_||_||____/  \__,_| \__| \__,_| ║▌║▌║█│▌
2022-11-24 11:44:19.394 -     INFO : ▌│█║▌║▌║          |___/        ║▌║▌║█│▌
2022-11-24 11:44:19.394 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:19.394 -     INFO : ▌│█║▌║▌║                                      VERSION : 0.8.0-dev                                      ║▌║▌║█│▌
2022-11-24 11:44:19.394 -     INFO :  Display configuration :
2022-11-24 11:44:19.394 -     INFO :    cycle: 14400
2022-11-24 11:44:19.394 -     INFO :    debug: True
2022-11-24 11:44:19.394 -     INFO :    home_assistant:
2022-11-24 11:44:19.394 -     INFO :      card_myenedis: True
2022-11-24 11:44:19.394 -     INFO :      discovery_prefix: homeassistant
2022-11-24 11:44:19.394 -     INFO :      enable: True
2022-11-24 11:44:19.395 -     INFO :    mqtt:
2022-11-24 11:44:19.395 -     INFO :      client_id: myelectricaldata
2022-11-24 11:44:19.395 -     INFO :      enable: True
2022-11-24 11:44:19.395 -     INFO :      hostname: core-mosquitto
2022-11-24 11:44:19.395 -     INFO :      password: ** hidden **
2022-11-24 11:44:19.395 -     INFO :      port: 1883
2022-11-24 11:44:19.395 -     INFO :      prefix: myelectricaldata
2022-11-24 11:44:19.395 -     INFO :      qos: 0
2022-11-24 11:44:19.395 -     INFO :      retain: True
2022-11-24 11:44:19.395 -     INFO :      username: Hassio
2022-11-24 11:44:19.395 -     INFO :    myelectricaldata:
2022-11-24 11:44:19.395 -     INFO :      ** hidden **:
2022-11-24 11:44:19.396 -     INFO :        token: ** hidden **
2022-11-24 11:44:19.396 -     INFO :        name: Maison
2022-11-24 11:44:19.396 -     INFO :        cache: True
2022-11-24 11:44:19.396 -     INFO :        consumption: True
2022-11-24 11:44:19.396 -     INFO :        consumption_detail: True
2022-11-24 11:44:19.396 -     INFO :        consumption_price_base: 0.174
2022-11-24 11:44:19.396 -     INFO :        consumption_price_hc: 0
2022-11-24 11:44:19.396 -     INFO :        consumption_price_hp: 0
2022-11-24 11:44:19.396 -     INFO :        enable: False
2022-11-24 11:44:19.396 -     INFO :        offpeak_hours_0:
2022-11-24 11:44:19.396 -     INFO :        offpeak_hours_1:
2022-11-24 11:44:19.396 -     INFO :        offpeak_hours_2:
2022-11-24 11:44:19.397 -     INFO :        offpeak_hours_3:
2022-11-24 11:44:19.397 -     INFO :        offpeak_hours_4:
2022-11-24 11:44:19.397 -     INFO :        offpeak_hours_5:
2022-11-24 11:44:19.397 -     INFO :        offpeak_hours_6:
2022-11-24 11:44:19.397 -     INFO :        plan: BASE
2022-11-24 11:44:19.397 -     INFO :        production: False
2022-11-24 11:44:19.397 -     INFO :        production_detail: False
2022-11-24 11:44:19.397 -     INFO :        production_price: 0
2022-11-24 11:44:19.397 -     INFO :        refresh_addresse: True
2022-11-24 11:44:19.397 -     INFO :        refresh_contract: True
2022-11-24 11:44:19.397 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:19.397 -     INFO :  Check config.yaml :
2022-11-24 11:44:19.397 -     INFO :   => Config valid
2022-11-24 11:44:19.402 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:19.402 -     INFO :  LOADING CONFIGURATION...
2022-11-24 11:44:19.403 -     INFO :  ** hidden **
2022-11-24 11:44:19.407 -     INFO :    => Success
2022-11-24 11:44:19.407 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:19.407 -     INFO :  Connect to MQTT broker core-mosquitto:1883
2022-11-24 11:44:19.410 -     INFO :   => Connection success
 * Serving Flask app 'main'
 * Debug mode: off
2022-11-24 11:44:19.537 -     INFO : WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
 * Running on all addresses (0.0.0.0)
 * Running on http://127.0.0.1:5000
 * Running on http://172.30.33.8:5000
2022-11-24 11:44:19.537 -     INFO : Press CTRL+C to quit
2022-11-24 11:44:19.538 -     INFO :  * Restarting with stat
2022-11-24 11:44:20.674 -     INFO :  Configure Databases
2022-11-24 11:44:20.699 -     INFO :   => day
2022-11-24 11:44:20.702 -     INFO :   => call_number
2022-11-24 11:44:20.704 -     INFO :   => max_call
2022-11-24 11:44:20.705 -     INFO :   => version
2022-11-24 11:44:20.708 -     INFO :   => lock
2022-11-24 11:44:20.709 -     INFO :   => lastUpdate
2022-11-24 11:44:20.709 -     INFO :   Success
2022-11-24 11:44:20.966 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:20.966 -     INFO : ▌│█║▌║▌║  __  __         _____  _              _          _               _  ____          _           ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO : ▌│█║▌║▌║ |  \/  | _   _ | ____|| |  ___   ___ | |_  _ __ (_)  ___   __ _ | ||  _ \   __ _ | |_   __ _  ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO : ▌│█║▌║▌║ | |\/| || | | ||  _|  | | / _ \ / __|| __|| '__|| | / __| / _` || || | | | / _` || __| / _` | ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO : ▌│█║▌║▌║ | |  | || |_| || |___ | ||  __/| (__ | |_ | |   | || (__ | (_| || || |_| || (_| || |_ | (_| | ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO : ▌│█║▌║▌║ |_|  |_| \__, ||_____||_| \___| \___| \__||_|   |_| \___| \__,_||_||____/  \__,_| \__| \__,_| ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO : ▌│█║▌║▌║          |___/        ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:20.967 -     INFO : ▌│█║▌║▌║                                      VERSION : 0.8.0-dev                                      ║▌║▌║█│▌
2022-11-24 11:44:20.967 -     INFO :  Display configuration :
2022-11-24 11:44:20.967 -     INFO :    cycle: 14400
2022-11-24 11:44:20.967 -     INFO :    debug: True
2022-11-24 11:44:20.968 -     INFO :    home_assistant:
2022-11-24 11:44:20.968 -     INFO :      card_myenedis: True
2022-11-24 11:44:20.968 -     INFO :      discovery_prefix: homeassistant
2022-11-24 11:44:20.968 -     INFO :      enable: True
2022-11-24 11:44:20.968 -     INFO :    mqtt:
2022-11-24 11:44:20.968 -     INFO :      client_id: myelectricaldata
2022-11-24 11:44:20.968 -     INFO :      hostname: core-mosquitto
2022-11-24 11:44:20.968 -     INFO :      password: ** hidden **
2022-11-24 11:44:20.968 -     INFO :      port: 1883
2022-11-24 11:44:20.968 -     INFO :      prefix: myelectricaldata
2022-11-24 11:44:20.968 -     INFO :      qos: 0
2022-11-24 11:44:20.969 -     INFO :      retain: True
2022-11-24 11:44:20.969 -     INFO :      username: ** hidden **
2022-11-24 11:44:20.969 -     INFO :    myelectricaldata:
2022-11-24 11:44:20.969 -     INFO :      ** hidden **:
2022-11-24 11:44:20.969 -     INFO :        token: ** hidden **
2022-11-24 11:44:20.969 -     INFO :        name: Maison
2022-11-24 11:44:20.969 -     INFO :        cache: True
2022-11-24 11:44:20.969 -     INFO :        consumption: True
2022-11-24 11:44:20.969 -     INFO :        consumption_detail: True
2022-11-24 11:44:20.969 -     INFO :        consumption_price_base: 0.174
2022-11-24 11:44:20.969 -     INFO :        consumption_price_hc: 0
2022-11-24 11:44:20.969 -     INFO :        consumption_price_hp: 0
2022-11-24 11:44:20.970 -     INFO :        enable: False
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_0:
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_1:
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_2:
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_3:
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_4:
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_5:
2022-11-24 11:44:20.970 -     INFO :        offpeak_hours_6:
2022-11-24 11:44:20.970 -     INFO :        plan: BASE
2022-11-24 11:44:20.970 -     INFO :        production: False
2022-11-24 11:44:20.970 -     INFO :        production_detail: False
2022-11-24 11:44:20.970 -     INFO :        production_price: 0
2022-11-24 11:44:20.971 -     INFO :        refresh_addresse: True
2022-11-24 11:44:20.971 -     INFO :        refresh_contract: True
2022-11-24 11:44:20.971 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:20.971 -     INFO :  Check config.yaml :
2022-11-24 11:44:20.971 -     INFO :   => Config valid
2022-11-24 11:44:20.976 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:20.976 -     INFO :  LOADING CONFIGURATION...
2022-11-24 11:44:20.977 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:20.977 -     INFO :  ** hidden **
2022-11-24 11:44:20.981 -     INFO :    => Success
2022-11-24 11:44:20.982 -     INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2022-11-24 11:44:20.982 -     INFO :  Connect to MQTT broker core-mosquitto:1883
2022-11-24 11:44:20.984 -     INFO :   => Connection success
Aucun sensor de crée !
et aucune info de Enedis ne remontent.
Alors que la fin du journal
2022-11-24 11:24:26.837 -     INFO :  Connect to MQTT broker core-mosquitto:1883
2022-11-24 11:24:26.839 -     INFO :   => Connection success
Tu as probablement déployé la version où j’ai oublier de réactiver le job d’import au boot du conteneur :smiley:
Je viens de changer le fonctionnement pour ne plus push ce genre de merde ^^
Je vais pas tarder à push la 0.8.2-dev avec quelques fix.
EDIT 0.8.2-dev en ligne
installe de la 0.8.2 :+1:
ca fonctionne
mais une sacrée différence entre gateway enedis et myelectradata
J’ai fait parreil mais chez moi tout est bon, je suis en BASE
moi aussi
en base
a 0.1740 €
Selon les instructions de migration par @M4dm4rtig4n plus haute
tu peux me mettre ton config.yaml
que je compare avec le mien au cas ou j’aurais une erreur
Vire tes info perso dessus
merci
EDIT
c’est bon , j’ai tout viré est reparti de zéro
J’ai une remontée erreur
@Felix62
tu as bien stoppé gateway Enedis ?
J’ai les 2 module mais l’autre est inactif
ok
voici la copie de ma config
cycle: 14400
debug: false
home_assistant:
  card_myenedis: true
  enable: true
influxdb:
  bucket: myelectricaldata
  enable: false
  host: influxdb
  org: myelectricaldata
  port: 8086
  token: XXXXXXXXXXX
mqtt:
  enable: true
  password: EdfeXXXXXX
  port: 1883
  qos: 0
  retain: true
  username: XXXX
myelectricaldata:
  212XXXXX42249:
    cache: true
    consumption: true
    consumption_detail: true
    consumption_price_base: 0.1740
    enable: true
    plan: BASE
    token: NNuI3xiMCbyhB-bvjXXXXXXXX6ZnF6IYAmyZw-c=
    refresh_addresse: true
    refresh_contract: true
p.i…je n;ai jamais stoppé Enedisgateway2mqtt…ça marche bien à côte de myelectricaldata :slight_smile:
possible , mais je préfère la joué sécurité !!
Et pourquoi faire un doublon ??
Merci c’est bon j’ai les infos qui remonte dans le sensor !
doublon: en tant que l’autre ne marche pas 100%…
Je viens d’installer le plugin mais pas de data dans influxdb pourtant pas d’erreurs dans les logs, ca met du temps a arriver ?
Non…< 30s chez moi, je pense que t’as pas bien configuré la connection…le poster dedans et voir aussi le logs du container myelectricaldata
les logs indiquent que ca s’insert bien mais je vois rien dans influxdb, pourtant j’ai bien les mesures et tags dans ma bdd
Nous sommes dimanche soir et les dernières donné date de lundi de la semaine précédente
Récupération des données impossible je viens de renouveler le consentement « my électric data »
Voici un screen des logs si sa peux aider au développement.
