Quelqu’un d’autre a-t-il noté une changement sur la collecte des infos netatmo (weathermap)?
Donnés présentes il y a moins de 24h mais depuis, plus rien, sans changement particulier, mais avec la mise à jour 2021.7.2
2021-07-14 10:04:34 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up netatmo platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 250, in async_setup_entry
await add_public_entities(False)
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 220, in add_public_entities
await data_handler.register_data_class(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 181, in register_data_class
await self.async_fetch_data(data_class_entry)
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 139, in async_fetch_data
await self.data[data_class_entry].async_update()
File "/usr/local/lib/python3.9/site-packages/pyatmo/public_data.py", line 248, in async_update
self.process(resp_data)
File "/usr/local/lib/python3.9/site-packages/pyatmo/public_data.py", line 49, in process
self.time_exec = to_time_string(resp["time_exec"])
KeyError: 'time_exec'
ça ressemble plus un changement d’api. Les stations (et les données) sont toujours dispo depuis la visu web
Je te conseille d’alimenter l’issue :
opened 07:01PM - 13 Jul 21 UTC
closed 02:01AM - 23 Jul 21 UTC
integration: netatmo
### The problem
I recently added the netatmo integration and it was working f… ine until today. When I noticed that the sensors were unavailable I looked at the logs and found this.
### What is version of Home Assistant Core has the issue?
2021.7.2
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
Netatmo
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/netatmo/
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
2021-07-13 19:35:58 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up netatmo platform for sensor
### Additional information
_No response_
J’étais pas tombé dessus !
Merci, ça y ressemble beaucoup !
EDIT:
ça devrait pas tarder à être corrigé :
Bon la 2021.7.4 est là mais la correction pas encore
Steve
Juillet 23, 2021, 10:16
7
en 2021 7.2 ca marche toujours …
Je vais attendre pour la MAJ
Oui merci. Par ailleurs, le correctif ne devrait plus tarder, il a été intégré sur la branche de dev
home-assistant:dev
← cgtobi:netatmo_pyatmo_522
opened 08:02PM - 22 Jul 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Bump pyatmo to v5.2.3 to fix a bug caused by slight API changes.
Changelog: https://github.com/jabesq/pyatmo/blob/v5.2.3/CHANGELOG.md
Changes: https://github.com/jabesq/pyatmo/compare/v5.2.1...v5.2.3
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [x] Dependency upgrade
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #52982
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [x] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [x] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [x] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
il y a un issue qui est en cours le correctif est fait mais il n’est pas remonter dans la mise 2021 7.4 on espere qu’il sera la dans la prochaine.
on patiente pour le moment
